I have a little problem that has been discussed here before. Every
time I press my push to talk my vario freaks out. I have a Dittel FSG 2T radio and an LX 1600 vario. We typically fly on 123.5 or 123.3. any Ideas on how to get rid of the interference? Any help will be appreciated. |
ryanglover1969 wrote:
I have a little problem that has been discussed here before. Every time I press my push to talk my vario freaks out. I have a Dittel FSG 2T radio and an LX 1600 vario. We typically fly on 123.5 or 123.3. any Ideas on how to get rid of the interference? Any help will be appreciated. Probably not RF interference, but current draw from the radio sucking down the input voltage to the vario which makes the vario unstable. One solution might be to put a large capacitor accross the input voltage supply to the vario and see if that helps. |
Ferrite beads may help. Run the power and any data lines which may
go to the vario, and the power line for the radio through separate ferrite beads, close to the instrument end of the cable. You can buy ones which are split in two, making it easy to thread the cable through twice then clip the two halves together and hold with cable ties. The tubular ones are better, but it necessitates removal of the connector from one end of the cable. You've probably seen ferrite beads on many computer USB cables. An (electric) ground loop cannot be ruled out. If both the radio and vario have the -12v connected to their chassis and you have a metal instrument panel, there is the possibility of a ground loop. Ground loops will provide wild readings when current is drawn on the radio. Ages ago I had a CAI audio module which had a built-in ground loop, installed in a metal panel. One person told me to run two separate power systems for radio and varios, and add capacitors which I thought a bit foolish. Dave Ellis had me cut a trace on the audio's circuit board (a prior design to Dave's involvement). This fixed the problem immediately. Jim |
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario | ufmechanic | Soaring | 0 | March 24th 09 05:31 PM |
GPS interference and contests | Bill Daniels | Soaring | 25 | January 25th 08 05:57 AM |
B40 rf interference problem | mborgelt | Soaring | 9 | March 13th 05 03:49 PM |
GPS / radio interference | Cub Driver | Piloting | 2 | October 31st 04 10:57 PM |
radio / vario interference - HELP! | Chris Davison | Soaring | 13 | November 3rd 03 06:09 AM |
