The big problem here is that air cooled engines are different from
water cooled engines, and while we can find lots of good information of breaking-in a newly assembled engine, it turns out that 99% of it has to do with WATER COOLED engines. Which turns out to be Bum Dope when you're talking about Flying Volkswagens. How an air cooled engine is broken in has a lot to do with how long it lasts. I've already written quite a bit on the subject of breaking in an engine and won't bore you with it again but the key is to keep things cool. The first run is never more than two or three minutes and that charge of oil is then discarded. I consider this to be the last step in the ASSEMBLY procedure rather than the first step in wearingin since it serves as a kind of Emergency Flush of the finished engine. The wear-in cycle is the hardest part of your engine's life. Machined surfaces are NOT all that smooth; there is considerable metal-to-metal contact and that produces some enormous heat loads. So you run the engine just a few minutes at a time then allow it to cool. This is unique to air cooled engines; with a waterpumper you simply size the radiator accordingly... or add cold coolant when it beings to boil. With an air cooled engine the key factor in the cooling equation is TIME. To make matters worse, VW's having larger than stock displacements experience even more wearin heating than the stock engine. And if it's for an airplane, being cooled by the blast from a propeller, the task of wearing it in properly becomes even more difficult. I have spent as long as two weeks (!) accumulating five or six hours on a newly built flying Volkswagen. Although half that amount is more the norm, it is the ENGINE which decides, not some manual devoted to cars. Allowing the engine to cool to the point where you can place your hand on the heads takes about half an hour in cool weather but can take twice that long on a hot day. Then too, the other purpose of wearingin the engine is to detect problems and there will always be a few. The timing and valve lash will change slightly from run to run, reflecting the vastly accelerated wear rate during breakin and those things must be attended to. Unless you are using a knowngood carb that has run on other engines and you know to properly adjusted, then there is the ohsocautious tweaking of the mix. You want it rich during wearin. But not too rich. (I use an oxygen sensor.) After the engine has accumulated an hour or so of run time, which may have taken six or even eight runs over a span of three or four hours, it will become obvious that the temperatures are rising more slowly and not going quite so high. The oil pressure will also be up. In effect, the engine is telling you it is ready to do a bit more work. Now the runs can become longer. But in no case should you run the thing more than twenty minutes or so, and NEVER at a constant speed. It drives the neighbors crazy (and the guys at the airport too) but you have to sit right there, protected by your ear muffs and cycle the throttle slowly up and down across a range of 500 rpm or thereabouts. (It is the decelleration involved here that is the other half of properly seating the rings.) Somewhere around three hours of running the engine gets a new charge of oil and a new filter. During the wearin cycle the engine should be fitted with 'bat wing' air scoops and a club optimized for pumping them full of air. You should have fitted the largest oil cooler you have available, positioned perpendicular to the air blast. (As the wearin proceeds you'll probably cover some portion of the cooler to keep your oil temperature above 170.) You actually wearin the engine according to what it tells you in the way of temperatures and pressures, including manifold pressure. After five or six hours, the engine SINGS. It starts at a flip, has a lovely, throaty idle, accelerates smoothly and once at full throttle (about 26" on the manifold) it will sit there and roar. THEN you can start paying attention to the torqueometer. For me, building engines is more fun than building airplanes. The engines talk to me, not only when they are running but laying there on the bench in pieces. Not talktalk of course. But pick up the cam and you can hear what it's saying. It comes through your hands and the way the thing snuggles into its bearing shells. You KNOW when it's comfortable, when it's looking forward to doing its job. All of the parts are like that. A gang of guys brought together to form a team. It takes... as long as it takes to assemble an engine. Most go together after three or four trial assemblies, some insist on more. The goal is harmony, for want of a better word. The parts have to learn to live and work together. It's difficult to describe exactly how that happens; what transformation takes place between a set of lifters from Brazil and a cam from Los Angeles and jugs from Japan under heads cast in Spain... but you know when things are good. The engine tells you so. R.S.Hoover |
Veeduber wrote:
The big problem here is that air cooled engines are different from water cooled engines, and while we can find lots of good information of breaking-in a newly assembled engine, it turns out that 99% of it has to do with WATER COOLED engines. Which turns out to be Bum Dope when you're talking about Flying Volkswagens. now there is one we can fully agree on. |
| Thread Tools | |
| Display Modes | |
| Engine break-in??? | Tri-Pacer | Home Built | 1 | September 26th 07 06:30 PM |
| Break out the champagne | Jim | Naval Aviation | 2 | June 13th 05 12:01 PM |
| Break-in Period for 0200A Continental Engine? | Larry | Home Built | 2 | April 19th 05 06:07 AM |
| IO-360 break-in and oil recommendations? | [email protected] | Owning | 7 | August 24th 04 05:54 AM |
| How to break in a new engine? | Baron Man | Owning | 8 | January 8th 04 12:09 AM |
