Blackbird v. Mig-25
Old August 16th 04, 09:19 PM
Vello Kala
Default Blackbird v. Mig-25
Aircraft Speed Altitude Mach Number
SR-71 Blackbird 2,275 mph
(3,660 km/h) 80,000 ft
(24,385 m) Mach 3.35
MiG-25 2,110 mph
(3,390 km/h) 42,650 ft
(13,000 m) Mach 3.2
This data is from Aerospaceweb. Question: SR-71 looks like alien plane, have
very special design (incl tanks what start to keep fuel on flight only)etc
etc. Mig-25 looks as pretty usual plane. But difference in speeds is
relative minor, expecially if to look at what altitude it is reached. How it
is possible? Do anybody have more data? Say, about SR-71 performance at 40
000 feet?
Old August 16th 04, 09:47 PM
Stop SPAM
MiG-25 2,110 mph
(13,000 m) Mach 3.2
000 feet?
Most reports I've read said the Mig-25 could only do over Mach 3 for a
very short period of time, and it destroyed the engines in doing so.
With no comments on its veracity, see, for example:
Mig-25
PERFORMANCE:
Max permitted Mach No. at height: Mach 2.83
Max level speed at 13000 m (42,650 ft): 1,620 knots 3,000 km/h 1,865 mph
at S/L: 647 knots (1200 km/h; 745 mph)
Max cruising speed at height: Mach 2.35
Econ cruising speed: Mach 0.85
Service ceiling: 21,000 m (68,900 ft)
The MiG-25 that was clocked at Mach 3.2 by the Israelis achieved this
speed while running from an intercepting F-4 (which can barely manage
Mach 2 on a good day--before running out of fuel). Upon landing, both
engines in the MiG had to be replaced.
Victor Belenko, the Foxbat pilot who defected in 1976, stated that the
top speed of the MiG-25 was Mach 2.8, but flight above Mach 2.6 was
difficult because of a tendency of the engines to overspeed. Victor
related that MiG-25 pilots were in fact restricted to flying below Mach
2.5 except with special permission.
- http://www.espacetickets.com/foxbat.htm
Old August 16th 04, 10:06 PM
Ragnar
"Vello Kala" wrote in message
MiG-25 2,110 mph
(13,000 m) Mach 3.2
have
it
000 feet?
You only think the engine performance is similar. The SR-71 could maintain
Mach 3-plus for several hours at a time, but the MiG-25 could do mach 3.2
for only about 5 minutes before burning the engines up.
Old August 17th 04, 02:54 AM
Nele VII
Here MiG-25 goes again... mixture of old 70-80'es data.
The story about burning engines is from that date. The published story is
that test-pilot Bezevec on the pre-production MiG-25R went beyond M3 because
he was painted by Hawk missile radar. In that time '25 was still in
test-phase with limited max speed endurance and when arrived to Egypt it was
just cleared from 3min flight to 8min. While in Egypt, it was cleared
further to 40 min up to unlimited when necessary. MiG-25 engines have
Chekunov's electronical system for fuel and engine RPM management-the FADEC
forerunner. There was a MiG-25 version that could "normally" travel up to
M3.2 known as MiG-25M, but was abandoned late in development in favour of
MiG-25MP (known as MiG-31 today). However, it was this MiG25M prototype that
under a "official" name tangled with F-15 Streak Eagle in speed, height and
speed to height records.
Cruising speed (in terms of best range/perfomance/economics) is around 2.500
km/h, NOT M 0.85-it is another blunder or a mix-up with MiG-31 (MiG-25
RB-15-300 engines are awfully inefficient subsonically). Another mix-up or
disinformation is that MiG-25 cannot travel more than M 2.3 with four R-40
missiles-actually, it can carry them up to the placarded (M 2.83) limit
(MiG-25P/PD/PDS interceptors) or even four 500kg bombs (RB/RBS/RBT
recce/strike versions) up to that speed. The speed of the MiG-25 at
low-level is limited by a pressure that is simply too high at such low
altitudes, so the temperature at the inlet (as well as in the engine) raises
above limits.
Although MiG-25 looks ordinary and extremely "boxy", its shape is very
efficient for high-mach regime. It is a different approach than one in
SR-71. While SR-71 had fuel tanks that got sealed by the airfame stretching,
MiG-25 has inboard tanks separated from the airfame-just like a car fuel
reservoirs (with a difference that it's tanks are pressured, filled with
inert gas and cooled).
MiG-25 can produce up to 5g (or 5.5) in supersonic regime. Sustained
altitude is around 20,000 m. SR-71 can manage around 2g (which is no
discredit, because it was not necessary for SR-71 to turn better).
Now, comparing MiG-25 and SR-71 is comparing apples and oranges. MiG-25
project was initialized to -counter- a Blackbird (not Valkirye as many
sources described!). Later (but early in develoment), it was "split" to
produce both inteceptor and recce variant . SR-71 is strategic recce
aircraft (although it evolved from A-12 that further produced a basis for
both SR-71 recce aircraft and YF-12 interceptor). MiG-25 is quite limited in
range, SR-71 is not. SR-71 had much wider and sophisticated recce equipment
than MiG-25R and could travel at M3+ until ran out of gas. MiG-25 was
produced massively (in order of around 600 aircraft), SR-71 just a handful.
Nele
NULLA ROSA SINE SPINA
Ragnar wrote in message ...
MiG-25 2,110 mph
(13,000 m) Mach 3.2
have
only)etc
it
40
000 feet?
Old August 17th 04, 12:31 AM
Krztalizer
You are comparing one performance parameter on two entirely different types of
aircraft. It doesn't matter what the SR's speed is at 40,000' -- it doesn't
fly there. How good of imagery coverage can the MiG 25 provide, from 90,000'?
Apples and oranges. A better question would be, how many times did a MiG 25
manage to catch the SR?
v/r
Gordon
====(A+C====
USN SAR
Its always better to lose -an- engine, not -the- engine.
Old August 17th 04, 01:59 AM
John Carrier
The advertised max speed of the Mig 25 is 2.83, The SR-71 design limit was
3.2, but 3.3 was attainable. The 3.2 number attributed to the Mig was based
on radar tracking data (not exactly precise and subject to wind errors).
The Mig dashed to that speed, the SR lived there. Big difference.
R / John
Old August 17th 04, 01:52 AM
Peter Stickney
"Vello Kala" writes:
MiG-25 2,110 mph
(13,000 m) Mach 3.2
Standard Admonition - beware of the data. Context is everything, and
there's not enough there.
000 feet?
SR-71's don;t fool around at a mere 40,000'. The purpose of the SR-71
is to carry a set of reconnaisance sensors at Mach 3+ at 80,000+ ft
(Mostly plus) for several hours. (Acturally, take off, top up from a
tanker, cruise out a Mach 3+/80K+ for a couple hours, hit another
tanker, Mach 3+ for another couple hours, all the way to wherever and
back. (Oh, yeah, all while having a radar signature equivalent to a
glider) Prepping an SR-71 for flight takes hours. It has a lot of
exotic materials and systems, and is more akin to a spaceship than a
normal airplane. I requires special fuels special lubricants and
hydraulic fluids, and weird stuff like TriEthyl Borane to keep the
fires lit. It flies in a delicate balance of shockwaves, all expertly
positioned to provide balanced flight and peak performance.
A MiG-25 is a bomber interceptor (Although it did find secondary roles
as a recon airplane and a bomber). It's intended to sit at the end of
a runway, make a scramble takeoff, and roar straight at an incoming
B-58, guided by a data link from its GCI (Ground Control Intercept)
site, and shooting the bomber in the face with large Air-to-Air
missiles, and return directly to its base.
(Many accounts claim that the MiG-25 was intended to intercept B-70s,
the Mach 3 Bomber that North American built in the late 1950s adn
early 1960s, and which never went into service. I, quite frankly,
doubt it, Even with the B-70's huge radar signature, its closing
speeds would be so fast that a minor course change by the bomber
wouldn't be able to be countered by the MiG, (Or if the B-70 wasn't
kind enough to fly straight at the MiG's base) and the MiG didn't
have any speed advantage in the almost inevitable tail chase that
would result. It does, however, have the perfect performance envelope
for taking on a Mach 2, 60,000' airplane like a B-58.)
The MiG was intended to be flown by normal service pilots, use normal
fuels and systems, and be maintained by 20 year old conscripts in
Siberia. Making an airplane that can do all those things wasn't a
trivial acheivement.
Another way to look at it is that the MiG-25 has pretty much the
ultimate perforance that can be acheived with a normal shape, and
fairly normal materials. (Stainless Steel, for the most part)
If you're going to go faster and higher, you need to start making
exotic airplanes like the SR-71.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old August 17th 04, 11:36 AM
Vello
"Peter Stickney" wrote in message
Thank you all for making things clear! One more strange thing: russians have
a lot of titanium, they even built submarine hulls from that - strange
airframe builders in SU find so little use for titanium. Do anybody know the
reason?
Pete Stickney
Old August 17th 04, 07:00 PM
w.a. manning
despite it's relative abundance, titanium is very difficult (and thus
costly) to manufacture and machine.
"Vello" wrote in message ...
reason?
Old August 18th 04, 12:00 AM
Ragnar
"w.a. manning" wrote in message
om...
Exactly. The reason the Soviets used it is because the Ministry of Defense
got everything it wanted in the 2 and 5-year plans. Money was literally no
object for them.
Blackbird books (was: hi-speed ejections) Paul A. Suhler Military Aviation 0 February 5th 04 03:39 PM
Victor Belenko's Narrative of Blackbird Activity in Soviet Far East frank wight Military Aviation 3 January 8th 04 12:07 AM
Refuting blackbird folklore frank wight Military Aviation 42 December 3rd 03 09:24 AM
SR- 71/ Blackbird lore Larry Dighera Military Aviation 28 July 31st 03 02:20 PM
Blackbird lore Air Force Jayhawk Military Aviation 3 July 26th 03 02:03 AM
