How to build an aircraft
Old August 19th 09, 08:45 PM
me123 me123 is offline
Junior Member
First recorded activity by AviationBanter: May 2009
Default How to build an aircraft
Hi I noticed the forum decription says "...building aircraft" so I would just like to know how to build an aircraft
Old August 20th 09, 02:03 AM posted to rec.aviation.homebuilt
Robert Barker
"me123" wrote in message
me123
Start by taking a sheet of copy paper and fold it in half length-wise......
http://www.youtube.com/watch?v=KZmUaFBCoa0
Old August 20th 09, 03:59 AM posted to rec.aviation.homebuilt
[email protected][_2_]
Looks like it has a dutch roll problem.
Before you star building try to anticipate what kind of flying you
actually will do. Then decide what what material you are comfortable
with, or wish to learn. Aluminum? Wood? Composite (fiberglass)? Then
start looking for plans or kits that fit you needs. Don't forget to
factor in needed build space, heat, and tools needed.
Some of us like to build. For the rest keep in mind the old saying
"If you want to build, build. If you want to fly....BUY."
Leon McAtee
Old August 20th 09, 02:56 AM posted to rec.aviation.homebuilt
BobR
me123
One part at a time and after a few hundred to a few thousand hours and
many parts, you assemble, get it inspected and fly it.
Seriously, it is a learning process that you learn as you go and the
end result is a smile that will be a very long time fixture of your
person.
Old August 21st 09, 02:04 AM posted to rec.aviation.homebuilt
Brian Whatcott
Just like many another homebuilt, you need an iron and a pair of
scissors, scotch tape to stick the pattern on....
http://www.instructables.com/id/Foam-Walkalong-Glider/
You start with a scrap of pink rafter insulation -
then you iron it flat (!)
and end up with a flying wing with a L/D of maybe 30:1
at a flying speed of two MPH....
Brian W
Old August 21st 09, 06:39 AM posted to rec.aviation.homebuilt
Atheist Chaplain[_2_]
"brian whatcott" wrote in message
Just like many another homebuilt, you need an iron and a pair of scissors,
Brian W
I just read that instructable last night :-)
[This comment is no longer available due to a copyright claim by Church of
Scientology International]
"I like your Christ. I do not like your Christians. They are so unlike your
Christ." Gandhi
Old August 21st 09, 08:23 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
Begin at the beginning.
Go on till the end.
Then stop.
Each of these takes some doing, some more, some less, all depending on
the mission, as already rehearsed.
Old August 21st 09, 11:04 PM posted to rec.aviation.homebuilt
Robert Barker
"jan olieslagers" wrote in message
Go on till the end.
Then stop.
Each of these takes some doing, some more, some less, all depending on the
The problem is, once you start, you CAN'T stop!
Old August 22nd 09, 04:01 AM posted to rec.aviation.homebuilt
"Robert Barker" wrote in message
Go on till the end.
Then stop.
Yup :-)
There are a lot of "I'll finish that one day" sitting in sheds all over the
world, I doubt that any would be classed as "Ahhh fuggit, I'm going to stop
working on that now" :-)
Christ." Gandhi
Old August 28th 09, 05:54 AM posted to rec.aviation.homebuilt
me123
Get a real big billet of aluminum and cut away everything that
doesn't look like an airplane.
Portable Aircraft HF Radio Build (Going to Be Long) Multiple Posts.... NW_Pilot Piloting 35 February 6th 08 05:18 AM
Build an RV of ??? William Snow Owning 12 September 8th 06 03:12 AM
Build an RV of ??? Jim Logajan Home Built 1 September 8th 06 03:12 AM
How to build a P-38 ? ? ? Hans-Marc Olsen Home Built 42 December 11th 04 04:06 PM
RV Quick Build build times... [email protected] Home Built 2 December 17th 03 03:29 AM
