Is this a special platform for testing JSF hovering?
Old August 20th 04, 11:11 PM
Venik
Default Is this a special platform for testing JSF hovering?
hobo wrote:
http://www.codeonemagazine.com/photo...y/photo12.html
In this photo the JSF is hovering over what looks like a giant metal
grill. Is this a special test site for testing JSF hovering? I imagine
that such a grill would allow you to simulate higher altitude hovering
without the dangers.
This grill is a part of an air vent system to reduce the re-entry of hot
exhaust into the air intakes. This system was devised to allow for
prolonged hovering tests.
Regards,
Venik
Visit my site: http://www.aeronautics.ru
If you need to e-mail me, please use the following subject line:
?Subject=Newsgr0ups_resp0 nse
Old August 21st 04, 12:22 AM
NoHoverStop
It's a VTOL pit. The one I know about was just a big hole in the ground
with a grid over it flush with the surface of the runway it was located
in (and a waterproof lining and a little pump to stop it becoming a
swimming pool). The intent was (and is) to remove ground effects, which
can cause control and engine thrust/surge-margin problems. On the basis
that your new VL-capable jet has enough grunt to hover without ground
effects (which can also be used to boost performance, as in the Harrier
II), it's good to be able to test VTO and/or VL without the potential
problems ground effects can cause. I know a tale of someone who tried to
drive a hovercraft over one. Not a good idea.
Sport Pilot cuts off special issuance at the knees Juan~--~Jimenez Home Built 40 August 10th 04 02:19 PM
Showstoppers (long, but interesting questions raised) Anonymous Spamless Military Aviation 0 April 21st 04 06:09 AM
Night of the bombers - the most daring special mission of Finnishbombers in WW2 Jukka O. Kauppinen Military Aviation 4 March 23rd 04 12:19 AM
Combat Related Special Compensation update for Sept. 8-12 Otis Willie Military Aviation 0 September 17th 03 04:38 AM
Pitts Special - info and photo's required. Darryl Gibbs Aerobatics 1 August 5th 03 09:05 PM
