A wooden control stick grip
Old September 16th 19, 02:55 AM posted to rec.aviation.soaring
Tom BravoMike
Default A wooden control stick grip
On Sunday, September 15, 2019 at 8:10:53 PM UTC-5, Scott Williams wrote:
On Sunday, September 15, 2019 at 5:24:14 PM UTC-5, wrote:
On Friday, September 13, 2019 at 11:32:33 PM UTC-4, Tom BravoMike wrote:
The grip in my 1984 Ventus is worn out and a bit sticky. I have always thought it would be nice to have a wooden one, e.g.:
https://www.cps-parts.com/catalog/el...ipstandard.php
Anyone has tried something like that? Are they much bigger/thicker than the factory ones? BTW, which inner size is it, 3/4" or 7/8" (before I get to the glider to measure it myself?) Thanks in advance for sharing your thoughts.
Wrapping the existing grip with Tennis Racquet " grip wrap" worked nicely for me in a Standard Cirrus with that sticky grip problem.
So FB closed? how about SSA,
https://www.ssa.org/photogallery.asp...mbr=1392883062
Wow! Now that is interesting! Somehow reading about 'plexiglass' I didn't imagine the grips to be actually transparent. Thanks!
Old September 16th 19, 04:05 PM posted to rec.aviation.soaring
Dan Marotta
Yes!Â* Now you can see the chipped paint on the steel tube beneath the grip.
Where are the Canadians with their beaver tails and flannel when we need
a fix to this vexing problem, eh?
Dan, 5J
Old September 17th 19, 04:47 AM posted to rec.aviation.soaring
Scott Williams
Dan, 5J
So, the transparent acrylic I used was, in part, just for looks. I remember seeing a clear acrylic rotational control grip that one of the original mercury astronauts had kept as a souvenir, and I think some aircraft landing gear retract handles were clear acrylic. On my standard Cirrus the stick is 22mm in diameter, which is close enough to 7/8 inch to use a demming drill bit to center bore the hole before shaping it. you could also use black acrylic stock to have a plain jane black grip.
what's the Canadian dig? Is it a reference to making your own parts or something?
good lift,
Scott
Wooden ClearNav stick grip Dan Mockler Soaring 0 November 13th 17 10:53 PM
adding speed/vario switch into ASW-19 control stick grip Kimmo Hytoenen Soaring 15 December 21st 12 11:54 PM
adding speed/vario switch into ASW-19 control stick grip Kimmo Hytoenen Soaring 0 December 19th 12 01:28 PM
control stick (complete not only grip) from mig-21 papcio Aviation Marketplace 0 May 3rd 04 07:08 PM
FA Infinity Military Style Control Stick Grip Terry Ladouceur Home Built 3 October 8th 03 12:52 AM
