Hi all
I am now the owner of a lovely 1973 Grob built Standard Cirrus - a thing of beauty. What intrigues me is that the the glider has no water ballast in the wings and looks as if it came straight from the factory like this. No connector in the wing root and nothing in the cockpit to indicate there was ever water ballast functionality. I always assumed that a run of manufactured gliders such as Std Cirrus would have water ballast in the wings across the whole range, but obviously not. Has anyone else come across this? Very curious. Thanks for any info. All the best Ian |
Wikipedia says water ballast came to standard class in '72. Maybe this one was commissioned before the rule was adopted. Alternatively a previous owner may have removed it.
DT |
According to my copy of "Segelflugzeuge vom Wolf zum Discus" by Peter Selinger, water ballast tanks were offered as an option by Schempp-Hirth since July 4th 1971. I suppose Grob followed the same policy.
On Sunday, September 29, 2019 at 5:34:08 PM UTC+2, wrote:
According to my copy of "Segelflugzeuge vom Wolf zum Discus" by Peter Selinger, water ballast tanks were offered as an option by Schempp-Hirth since July 4th 1971. I suppose Grob followed the same policy. My father used to own Std Cirrus #11 - 1969. It was fitted with water ballast. Clinton |
The earli Cirri did not come from the factory with ballast. Many were retrofitted in the field with bags.
On Mon, 30 Sep 2019 08:43:16 -0700, Tony wrote:
The earli Cirri did not come from the factory with ballast. Many were retrofitted in the field with bags. Yep. Initial Standard class rules said no water ballast and no retractable landing gear. I don't know whether the rule changes to allow water ballast and retractable gear were simultaneous or not. -- Martin | martin at Gregorie | gregorie dot org |
On Monday, September 30, 2019 at 5:19:18 PM UTC+1, Martin Gregorie wrote:
On Mon, 30 Sep 2019 08:43:16 -0700, Tony wrote: The earli Cirri did not come from the factory with ballast. Many were retrofitted in the field with bags. Yep. Initial Standard class rules said no water ballast and no retractable landing gear. I don't know whether the rule changes to allow water ballast and retractable gear were simultaneous or not. -- Martin | martin at Gregorie | gregorie dot org Many thanks for all your replies. I have contacted Schemp Hirth as well to see if they can shed any information on it. I will post here if I find out any more nuggets of information. All the best Ian |
On Mon, 30 Sep 2019 13:37:34 -0700, Ian Simmonds wrote:
I have contacted Schemp Hirth as well to see if they can shed any information on it. According to Wikipedia, so this MUST be right!, the Standard Class started in the late '50s, so think of a Ka6 as the archetypical original spec Standard Class glider. The rules changed to allow retracts in 1970 and water ballast in 1972. My 201 Libelle was built in late '69 so must have been one of the first to have retracts fitted as standard and was not fitted for water ballast, which is just as well since my wing skins are glass/balsa/glass laminates. However, it is a little odd that your '73 Std Cirrus didn't originally carry water. After all, it was built after water ballast became legal for the class in 1972. Maybe, as somebody said, it was an optional extra? -- Martin | martin at Gregorie | gregorie dot org |
Schempp-Hirth TN 278-3 indicates that from serial numbers 1-134 water ballast was optional, and standard equipment from 135 onwards.
Nick. |
Having said this, yours is likely later serial number than 135 & doesn't have water ballast. Presumably if a customer ordering a brand new Cirrus stated that they didn't want water, Schempp would comply.
Cheers, Nick. On Tuesday, October 1, 2019 at 10:17:51 AM UTC+9:30, Nick Gilbert wrote: Schempp-Hirth TN 278-3 indicates that from serial numbers 1-134 water ballast was optional, and standard equipment from 135 onwards. Nick. |
Jantar Standard 3 water ballast tank repair | elandra650@gmail.com | Soaring | 6 | June 5th 17 12:25 PM |
ASK-21 and Grob 103 cockpit ballast weights | kirk.stant | Soaring | 12 | September 2nd 15 08:57 PM |
water ballast | 6PK | Soaring | 16 | July 15th 15 01:43 PM |
Grob 103 Ballast Weights | Roger Fowler[_2_] | Soaring | 0 | January 16th 12 12:18 PM |
Who first used water ballast and when? | John McCullagh | Soaring | 9 | October 18th 06 09:36 AM |
