Best Oxygen Setup?
Old October 3rd 19, 01:57 AM posted to rec.aviation.soaring
Dan Marotta
Default Best Oxygen Setup?
As I said in my original post:Â* The pilot was either lighting up or the
regulator gave a blast of oxygen, maybe while he was taking a drag.Â* The
mask did not combust spontaneously and I never said such.
If I had to guess, I'd say he was lighting up and, just after removing
the mask, there would be pure oxygen within the mask.Â* It would be easy
to light.
On 10/2/2019 10:17 AM, wrote:
On Wednesday, October 2, 2019 at 4:38:10 PM UTC+1, Dan Marotta wrote:
You are correct.Â* Oxygen doesn't burn.Â* But it really supports combustion!
When I was in AF flight school (early 70s, so everyone smoked), they
warned us about smoking with a mask dangling along side one's face.
Seems one fighter jock had his mask catch fire (maybe while lighting up,
maybe due to a cabin depressurization causing the O2 system to go into
pressure mode, who knows?).Â* The point was that he suffered serious
burns to his face.
Personally I never felt the need to smoke during a 2-hour flight with a
pressure demand mask and regulator.
An oxygen mask that combusts on exposure to oxygen would be a bit of a design flaw! There will have been something else that ignited before the mask. In the context of medical or general aviation oxygen use I would be far more concerned about oxygen exposure to petroleum based products (e.g. vaseline, Vicks, Chapstick on the face) than smoking
https://www.thoughtco.com/flammability-of-oxygen-608783
Dan, 5J
Old October 3rd 19, 07:59 AM posted to rec.aviation.soaring
John Foster
burns to his face.
On 10/2/2019 12:09 AM, wrote:
Many moons ago when I was a junior hospital doctor in a chest ward the preferred oxygen mask for low concentration O2 was the "Edinburgh mask" which had a circular hole in the front with the O2 nozzle entering at its lower circumference. Some of the chest patients loved it because they could smoke through the hole. As was demonstrated to me by a marginally less junior doctor, if you held the lit cig tip directly in the O2 outlet flow it just glowed brighter. Oxygen doesn't burn, it burns.
Dan, 5J
I've seen this twice in my career so far. Both times the person was smoking while oxygen was being administered through a nasal cannula. In one case, the cigarette actually exploded, sending the person the the ICU burn ward with 3rd degree burns to the face. NOT PRETTY!!!
The oxygen causes accelerated combustion of the tobacco, resulting in a flash of flame that can cause serious injury. I imagine this happens while they are taking a drag, and not just having it passively smolder in the presence of higher oxygen concentration though.
Old October 3rd 19, 04:20 PM posted to rec.aviation.soaring
Jonathan St. Cloud
burns to his face.
Dan, 5J
Natural selection at work.
Old October 3rd 19, 05:55 PM posted to rec.aviation.soaring
Jonathon May
Marotta wrote:
You are correct.=C2=A0 Oxygen doesn't burn.=C2=A0 But it
really
support=
s combustion!
=20
smoked), they=20
one's face.=20
lighting
up=
,=20
to go into=
=20
pressure mode, who knows?).=C2=A0 The point was that he
suffered
seriou=
s=20
burns to his face.
=20
flight with
a=
=20
=20
chest ward
th=
"Edinburgh mask"
w=
its
lo=
they could
marginally less
jun=
j=
=20
--=20
Dan, 5J
=20
was
smok=
In one
ca=
ICU burn
wa=
=20
resulting in a
f=
happens while
pre=
Natural selection at work. =20
I have been using a Dive type cylinder because they are easier to
get re filled.
Last Saturday I was flying with the bottle on but the regulator off
above a ridge trying to connect to the wave system.
About 1 hour in and 2700ft asl there was a loud pop and bottle
pressure O2 started blowing into the cockpit .
I could not turn the bottle off so I opened the DV window put a
Pan call out and got it back on the glider field in about 3 minuets .
I have never been so scared ,and I have loads of field landings and
thousands of hours in gliders.
I blame it on lack of maintenance and use, the cylinders has been
sitting in the glider since March turned off while I flew thermals in
the UK.
My bad just need the bottle re-filling and probably a new O ring.
Old October 3rd 19, 07:22 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Jonathon May wrote on 10/3/2019 9:55 AM:
get re filled.
the UK.
What is a Dive type cylinder, and why is it easier to get it refilled with oxygen?
What failed and caused the pop?
Old October 3rd 19, 09:17 PM posted to rec.aviation.soaring
Jonathon May
to
get re filled.
off
minuets .
and
been
in
the UK.
with
oxygen?
to email
me)
https://sites.google.com/site/motorg...ions/download-
the-guide-1
I assume the O ring displaced,I took it off and it sealed OK on the
ground, but its going to be checked before I use it again I assure
you.
Dive cylinder has a square top with an outlet and 2 indexing pins.
The regulator does over the top with a yoke and a screw pushes an
inlet with O ring positioned with the index pins against the outlet.
They are common to compressed air dive bottles ,quick to change
bottles and no chance of a cross thread.Very robust compared with
our threaded connector mountain high cylinders.
In the Uk many dive shops will not charge a DOT cylinder, they want
a DIN number and date.
Old October 3rd 19, 11:21 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Jonathon May wrote on 10/3/2019 1:17 PM:
to
get re filled.
off
minuets .
and
been
in
the UK.
with
oxygen?
you.
That sounds like what is called a "medical bottle" in the US. I used them for
several years because I could exchange them at almost any pharmacy, which are much
more plentiful than airports (with oxygen) or welding shops. Unfortunately, they
began to require a prescription from a doctor to get oxygen. A prescription for
something everyone is breathing? Did not see that one coming; anyhow, I now
transfill my bottles from welding bottles, which is easy and cheap. For traveling,
I carry a medium size welding bottle, good for 2 or 3 fills.
  #28
Old October 4th 19, 01:49 AM posted to rec.aviation.soaring
Dan Marotta
I've never heard of a dive shop supplying oxygen.Â* During my scuba
training in the early 60s, I was taught that oxygen is toxic at high
ambient pressure as below some depth which I didn't bother to research.Â*
Imagine filling a scuba tank (dive bottle) with oxygen and killing the
diver!
Now I know that things are different on the east side of the Atlantic,
but are you sure you're getting oxygen and not just compressed air at
the dive shop?
to
get re filled.
off
minuets .
and
been
in
the UK.
with
oxygen?
to email
me)
the-guide-1
you.
Dan, 5J
  #29
Old October 4th 19, 02:45 AM posted to rec.aviation.soaring
diver!
Divers keep a bottle of O2 around in the boat to treat bends or just to get rid of nitrogen in blood faster to be able to dive more in a day.
  #30
Old October 4th 19, 10:09 AM posted to rec.aviation.soaring
Tango Whisky
Le jeudi 3 octobre 2019 22:30:05 UTC+2, Jonathon May a écritÂ*:
to
get re filled.
off
minuets .
and
I had a similar experience thus summer - the connector on the MH regulator obviously had worn out over the about 20 years of use and decided to let go the connecting hose to the EDS unit.
I can't reach the cylinder inflight without an immense effort of wiggling myself, and as I was close to the rocks trying to get the first climb of the day, I just kept on flying. The oxygene pressure on the outlet of the regulator is 2 bars or less, so it can't do any harm.
LXNav V7 Setup svelusive Soaring 9 February 22nd 15 04:29 PM
A-37 Dragonfly smoke setup Glenn[_4_] Aviation Photos 0 December 27th 12 03:00 AM
Vario setup brianDG303 Soaring 1 April 3rd 08 05:20 PM
FS 2004 setup Dave Hetteen Simulators 4 June 25th 04 10:40 PM
WX Works setup Paul Tomblin Piloting 16 December 8th 03 04:23 AM
