Can only CFIs teach flying?
Old October 6th 19, 08:30 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Default Can only CFIs teach flying?
Thread drift light on here.
When your paying for and getting training you have to search out good instructors you can connect with.
When I was getting my initial Cezzna training in Broomfield Colorado { Jeffco } in 1983 I had a instructor that was extremely nervous and didn't have a good feel for the airplane, I had been flying airplanes like a Cezzna T210 and V Tail Beechcraft Bonanza since I was about 13, so I kinda had a good feel for how things were suppose to go.
I don't know how that guy ever got his CFI rating. He seems to be scared to me!
That said I've been very fortunate to have had some really excellent instructors through out my career, not all were CFI rated.
Old October 6th 19, 08:31 PM posted to rec.aviation.soaring
Bob Youngblood
On Sunday, October 6, 2019 at 12:07:25 PM UTC-4, Dan Marotta wrote:
I can roll up into a 90 degree bank and, if I don't apply up or down
elevator, the plane won't turn.Â* The nose will simply knife downward..Â*
So, am I clinging to something?Â* Think vectors and the vertical and
horizontal components of lift.
I read a story on one of the aviation newsletters recently where a young
FAA inspector was riding jump seat in an airliner.Â* As they waited for
takeoff clearance, she asked the captain which controlled speed, the
elevators or throttle.Â* Then the captain said that the throttles
controlled speed, she corrected him saying that throttle controls
altitude and elevator controls speed.
The captain thought about that and then said to the copilot:Â* " When
we're cleared for takeoff, I'll push the yoke full forward and, when we
attain takeoff speed, you push the throttles up so we can get
airborne."Â* The moral - what they taught you in class ain't always the
way it works in reality.
On 10/5/2019 6:42 PM, Tango Eight wrote:
On Saturday, October 5, 2019 at 6:59:20 PM UTC-4, WB wrote:
Even CFI’s sometimes put out some really bad info. A local old timer CFI was notorious for teaching students that if they have an engine fail on takeoff, that they could easily make a turn back to the field at low altitude by holding the wings level and doing a 180 with just the rudder! I actually heard this guy teaching that and his whole explanation of why it should work.
We had a local 'barnstormer', a charming and persuasive fellow, convince a few of our student pilots that in a steep enough turn, the rudder and elevator swap functions. And of course, once they'd bought that explanation, they really didn't want to let go.
T8
Dan, 5J
Well stated Dan, don't you just love it when the so called know it all eats a bit of humble pie!
Old October 6th 19, 10:50 PM posted to rec.aviation.soaring
5Z
elevator, the plane won't turn.Â* The nose will simply knife downward.Â*
T8
Dan, 5J
But.... When on final approach, the elevator does control airspeed and throttle (spoilers) the altitude (rate of descent). There's a lot of nuance to flying well. :-)
Tom
Old October 8th 19, 08:28 AM posted to rec.aviation.soaring
Bruce Hoult
If you are flying straight and level and then roll into a 90 degree bank while keeping the same elevator position then you will enjoy turning with 1G of centripetal acceleration. Until the nose falls through. And then you'll enjoy a 1G pullout (more as the speed builds).
The only way you can *not* turn in that 90 degree bank is if you actually moved the stick forward to the position that would give you a zero-G pushover in level flight.
Old October 8th 19, 12:44 PM posted to rec.aviation.soaring
Tango Eight
You haven't tried explaining this to a student, have you? :-)
Here's what really happens if you bank to 90 degrees while holding the elevator control in one place: the nose drops starts dropping the moment you begin to bank, the aircraft begins to accelerate and the g forces increase. There is -no- period of time that "you will enjoy turning at 1G of centripetal acceleration."
Langewiesche (Stick and Rudder) has it right. Think of the elevator control as your angle of attack control. Chapter one, "How a wing is flown". What a great place to start the explanation of the art of flying.
best,
Evan Ludeman
Old October 8th 19, 06:37 PM posted to rec.aviation.soaring
James Lambert
down=20
elevator, the plane won't turn.=C2=A0 The nose will simply knife
downwa=
rd.=C2=A0=20
So, am I clinging to something?=C2=A0 Think vectors and the vertical
an=
d=20
=20
bank
1=
you'l=
=20
actually=
pusho=
elev=
b=
increase.
centrip=
etal acceleration." =20
=20
contro=
Wh=
best,
Evan Ludeman
Funnily enough.... the assumption is made that the tail is acting with a
'downward' force, counterbalancing the mass ahead of the lift... with
neutral stability, the elevator actually exerts no force in pitch. And it
is also possible that the tail generates lift to support a rearward C of G
Banking to 90 deg and holding that angle changes the whole dynamic of the
weight and lift distribution, the fin and rudder now come out to play....
Old October 8th 19, 08:41 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
it is also possible that the tail generates lift to support a rearward C
of G !!!
Indeed, but every glider I know the W&B for has the CG in front of the CL
at all flying speeds (CL approaches 30% MAC at the stall, but as airspeed
rises it moves further back.
I'm far from certain that I'd want to fly anything with the CL at or
behind the CG. Here's why:
I know quite a lot about trimming small aircraft with rear CG positions -
virtually all competition free flight models are set up this way because
having both wing and tail providing lift adds efficiency, especially if
the tail is flying at its minimum drag AOA. Which is the case for a well-
designed model. Numbers: the F1A gliders (F1A is the international class
for towline gliders - typically 2.2-2.7m span, min weight 420g) all flew
best with the CG at 55% of MAC, a main wing AOA of about 8 degrees and
the flat bottomed lifting tail at about 3.5 dergees AOA. The stability
was good - it has to be to handle rough thermals and the turbulence you
get below 50-100ft on a windy day. But I would not want to fly an
aircraft with that trim set-up because the trim sensitivity was extreme -
my tail had a 90 mm chord and I used a 10BA bolt as the trim adjuster
(thats 1.7mm diameter, with a 0.35mm pitch). I could easily see the
effect of half a turn on the trim (both still air duration and dynamic
recovery from upsets) and so used to fine tune them in terms of 1/4 turn
adjustments. That gives a 0.09mm movement at the TE of a 90mm chord
tailplane, so a very small angular change indeed. 1-2 turns took it from
stalling to an under-elevated over fast glide.
On the other hand, similarly sized models with the CG in front of the CL,
so flying with down force on the tail, are easy to trim by adding or
removing pieces of 0.8mm or 1.6mm balsa under the TE of the tailplane.
Bottom line: I would not want to hand-fly anything with that amount of
pitch sensitivity so am happy to leave anything with its CG behind the CL
in the hands of other, better and braver pilots than myself.
Martin | martin at
Gregorie | gregorie dot org
  #28
Old October 9th 19, 12:25 AM posted to rec.aviation.soaring
Errrrm: this should, of course, read:
I'm far from certain that I'd want to fly anything with the CG at or
behind the CL. Here's why:
Martin | martin at
Opportunities for CFIs [email protected] Piloting 0 July 5th 17 04:49 PM
mechanics and CFIs fredsez Soaring 0 March 12th 08 01:14 AM
CFIs fredsez Soaring 2 December 30th 07 06:14 PM
CFIs fredsez Soaring 11 December 30th 07 05:19 PM
Question for CFIs Casey Wilson Piloting 11 February 24th 05 10:29 PM
