https://en.wikipedia.org/wiki/Lockheed_F-94_Starfire
The Lockheed F-94 Starfire was a first-generation jet aircraft of the United States Air Force. It was developed from the twin-seat Lockheed T-33 Shooting Star in the late 1940s as an all-weather, day/night interceptor. The aircraft reached operational service in May 1950 with Air Defense Command, replacing the piston-engined North American F-82 Twin Mustang in the all-weather interceptor role. The F-94 was the first operational USAF fighter equipped with an afterburner and was the first jet-powered all-weather fighter to enter combat during the Korean War in January 1953. It had a relatively brief operational life, being replaced in the mid-1950s by the Northrop F-89 Scorpion and North American F-86D Sabre. The last aircraft left active-duty service in 1958 and Air National Guard service in 1959. The F-94C Starfire was extensively modified from the early F-94 variants. In fact, it was initially designated F-97, but it was ultimately decided to treat it as a new version of the F-94. USAF interest was lukewarm, so Lockheed funded development themselves, converting two F-94B airframes to YF-94C prototypes for evaluation. To improve performance, a completely new, much thinner wing was designed, along with a swept tail surface. The J33 engine was replaced with a more powerful Pratt & Whitney J48, a license-built version of the afterburning Rolls-Royce Tay, which dramatically increased power, producing a dry thrust of 6,350 pounds-force (28.2 kN) and approximately 8,750 lbf (38.9 kN) with afterburning. The fire control system was upgraded to the new Hughes E-5 with an AN/APG-40 radar in a much larger nose. The guns were removed and replaced with all-rocket armament consisting of four groups of six rockets in a ring around the nose. The rockets were carried in four panels that could be hinged upwards and outwards for ground reloading. In flight these rockets were normally hidden aft of four fold-in doors that folded inwards for combat. According to Lockheed test pilot Tony LeVier, the F-94C was capable of supersonic flight in a steep dive with afterburner engaged. The F-94C was the only variant to be officially named Starfire. With time, the entire F-94 family has adopted the name. The first production F-94C aircraft were delivered in July 1951, 387 examples being delivered before May 1954. The largest problem discovered in service was the nose-mounted rockets, which blinded the crew with their smoke and fire. The most severe problem associated with firing the nose-mounted rockets was that the exhaust could cause a flameout of the jet engine, which could lead to loss of the aircraft. Mid-wing rocket pods were added, holding 12 rockets apiece. Most of the time, the nose rockets were not fitted, and the mid-wing pod rockets were the sole armament. This version of the aircraft was extensively used within the Semi Automatic Ground Environment (SAGE) air defense system. Role All-weather interceptor National origin United States Manufacturer Lockheed Corporation First flight 16 April 1949 Introduction May 1950 Retired 1958 (USAF) 1959 (ANG) Primary users United States Air Force Air National Guard Number built 855 Unit cost US$196,248 (F-94B) US$534,073 (F-94C) Developed from Lockheed T-33 Shooting Star The primary user of the F-94 were the squadrons of Air Defense Command (ADC), eventually equipping 26 squadrons of interceptors. The first F-94As were assigned to the 325th Fighter-All Weather Group at McChord AFB and Moses Lake AFB, Washington. It replaced the propeller-driven F-82F Twin Mustangs that were in use by its 317th, 318th, and 319th squadrons. The F-82s had been pressed into interceptor service in 1949 after the Soviet Union displayed the Tupolev Tu-4 strategic bomber, a reversed-engineered version of the B-29 Superfortress, some of which had landed and were impounded in the Soviet Far East during World War II. The F-82Fs proved to be an excellent day/night all-weather interceptor, with long range, but it lacked any logistics support which resulted in a chronic shortage of parts. The jet-powered F-94As, however, had shorter legs than the F-82s and relied more on Ground Control Interception Radar (GCI) sites to vector them to intruding aircraft. Retirement The F-94A/B models were replaced in the active-duty inventory beginning in mid-1954 by a combination of the Northrop F-89C/D Scorpion and the North American F-86D Sabre interceptors. They were sent to Air National Guard units where they replaced North American F-80C Shooting Stars and F-51D/H Mustangs, which in most cases marked the end of the line for the venerable Mustang in United States military service. When sent to the ANG, the F-94As were sent to Lockheed for modification to F-94B standards and then returned to the ANG as B models. Also in the late 1950s, F-94Cs were passed along to the Air National Guard, supplementing the F-94A/B models. Eventually 22 ANG Fighter-Interceptor squadrons were equipped with the Starfire interceptor. The last F-94C was retired by the active-duty Air Force in November 1957 when the 319th Fighter-Interceptor Squadron at Bunker Hill Air Force Base, Indiana converted to the F-89J Scorpion interceptor. The last F-94C Starfires were phased out of ANG service by the 179th Fighter-Interceptor Squadron at the Duluth Municipal Airport, Minnesota during the summer of 1959 when it converted to the F-89J Scorpion; the last aircraft being sent to AMARC in December 1959. Specifications (F-94C Starfire) General characteristics Crew: 2 Length: 44 ft 6 in (13.6 m) Wingspan: 42 ft 5 in (12.9 m) Height: 14 ft 11 in (4.5 m) Wing area: 232.8 ft² (21.63 m²) Empty weight: 12,708 lb (5,764 kg) Loaded weight: 18,300 lb (8,300 kg) Max. takeoff weight: 24,184 lb (10,970 kg) Powerplant: 1 × Pratt & Whitney J48-P-5 turbojet Dry thrust: 6,350 lbf (28.2 kN) Thrust with afterburner: 8,750 lbf (38.9 kN) Performance Maximum speed: 640 mph (556 kn, 1,030 km/h, Mach .84) Range: 805 mi (700 nmi, 1,300 km) combat Ferry range: 1,275 mi (1,100 nmi, 2,050 km) Service ceiling: 51,400 ft (15,670 m) Rate of climb: 7,980 ft/min (40.5 m/s) Wing loading: 78.6 lb/ft² (384 kg/m²) Thrust/weight: 0.48 Armament Rockets: 24 or 48 × 2.75 in (70 mm) Mk 4/Mk 40 Folding-Fin Aerial Rockets Avionics AN/APG-40 radar * |
| Lockheed F-94 Starfire vid - 1956 F-94 Starfire Pilots Garner Rocket Skill-pFaktkMIJTc_x264.mp4 (01/19) | [email protected] | Aviation Photos | 3 | September 2nd 16 09:28 AM |
| Lockheed F-94 Starfire pics [21/21] - lockheed-f94c-starfire cockpit.jpg (1/1) | Miloch | Aviation Photos | 0 | September 1st 16 06:29 PM |
| Lockheed F-94 Starfire pics [14/21] - Lockheed F-94 Starfire Drawings.jpg (1/1) | Miloch | Aviation Photos | 0 | September 1st 16 06:29 PM |
| Lockheed F-94 Starfire pics [13/21] - Lockheed F-94 Starfire cutaway.png (1/1) | Miloch | Aviation Photos | 0 | September 1st 16 06:29 PM |
| Lockheed F-94 Starfire pics [12/21] - Lockheed F-94 Starfire cutaway ru.jpg (1/1) | Miloch | Aviation Photos | 0 | September 1st 16 06:29 PM |
