Howling sound when flying
Old October 12th 19, 04:42 PM posted to rec.aviation.soaring
Armand Charbonneau
Default Howling sound when flying
My Ventus 2c makes a howling sound when flying at 0 flap setting. It is significantly less noticeable immediately after changing the flap setting either positive or negative. Pilots tell me they can hear it when flying overhead or landing. I can hear it seemingly behind me, inside the cockpit. Gear up or down does not seem to make a difference.
The glider was refinished with poly in 2012, so I suspect the wing seals are seven years old. Otherwise the ship in very good condition and soars nicely.
Does anyone know what could be causing this sound? I can replace all the seals this winter, but they appear to be in good condition, except maybe on the tail plane.
Old October 12th 19, 04:57 PM posted to rec.aviation.soaring
krasw
Ventus-2c (and D2b) has an extremely loud cockpit. You cannot do much for it.
Old October 12th 19, 05:11 PM posted to rec.aviation.soaring
Might also try rudder left and right, elevator, etc.
Old October 12th 19, 05:44 PM posted to rec.aviation.soaring
Armand Charbonneau
My Ventus 2c makes a howling sound when flying at 0 flap setting. It is significantly less noticeable immediately after changing the flap setting either positive or negative. Pilots tell me they can hear it when flying overhead or landing. I can hear it seemingly behind me, inside the cockpit.. Gear up or down does not seem to make a difference.
It is not just in the cockpit. I am told it is loud on the ground when flown overhead.
Old October 12th 19, 06:18 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Well that sucks, literally. Start sealing. I have owned two SH gliders (N4, V2C) and they both benefited from gear well sealing, canopy, rudder, and control surfaces needed S-tape under mylar.
Old October 12th 19, 08:17 PM posted to rec.aviation.soaring
john firth
On Saturday, October 12, 2019 at 11:42:44 AM UTC-4, Armand Charbonneau wrote:
It is surprising that this has not been aired before.
When I first flew my PIK 20 E there was a similar loud howl
at zero and neg flap settings. I speculated that this was resonant
vortex shedding from the top surface; the flap had an internal fabric seal
but this will not stop oscillatory flow.
The Aerodynamics prof at my alma mater replied that I was probably right;
resonant vortex shedding on the BAE 146 stol transport was close to
ending sales due to passenger complaints; when CU dept eng. found a solution.
Old October 12th 19, 11:57 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Armand Charbonneau wrote on 10/12/2019 8:42 AM:
Did the howl start recently? Are the zig zag tapes in the correct position? Does
the back edge of the Mylar fairing strip (top and bottom) press against the
flap/ailerons in the Flap 0 position?
Old October 13th 19, 01:52 AM posted to rec.aviation.soaring
Armand Charbonneau
Howling has been there since I started flying about 105 hours ago. zig zag tapes look okay.
I will check the mylar strips (top and bottom) carefully with the wings assembled looking at flap 0.
Old October 13th 19, 03:22 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Armand Charbonneau wrote on 10/12/2019 5:52 PM:
Did the howling exist before the refinish? Perhaps the zig-zag was not placed in
the correct location, or it's the wrong zig-zag (too thin, perhaps).
Old October 13th 19, 04:13 AM posted to rec.aviation.soaring
GliderCZ
I own and fly V2C s/n 51 and have never experienced that problem. I also find the cockpit reasonably quiet if everything is well sealed; even more so since having a Hank Nixon turtleback vent installed.
But what initially struck me about your question though, is your use of the 0 flap setting. My SH flight manual doesn't even acknowledge 0-flaps as a cruise setting. By virtue of that (and advice from other V2C pilots) I never routinely use it. It's just a transit point between positive and negative settings. Sorry, if I steer the conversation off-topic.
Howling noise from nose vent toad Soaring 9 February 23rd 09 02:23 PM
What a sight...and what a sound Roger (K8RI) Piloting 15 July 4th 07 03:53 PM
What a sight...and sound. Roger (K8RI) Piloting 1 July 2nd 07 01:11 PM
What is this sound? gatt Piloting 14 June 9th 04 04:37 AM
F-86 and sound barrier VH Military Aviation 43 September 26th 03 02:53 AM
