Tow planes and ADS-B Out
Old October 27th 19, 04:29 PM posted to rec.aviation.soaring
Larry Ruggiero
Default Tow planes and ADS-B Out
I realize our operational environments are varied, but what’s the trend for equipping tow planes with ADS-B out? The broad requirement distilled down is that it’s “required in airspace where transponders are required,” which for us is pretty rare. There are relatively easy/cheap (by aviation standards anyway) installs available, so there’s that.
Larry Ruggiero, Carolina Soaring
Old October 27th 19, 10:02 PM posted to rec.aviation.soaring
Charles Longley
The two tow planes I maintain have different ADS-B out. On one I installed a Stratus ESG transponder. (The original transponder had failed.) The other tow plane I just installed a skyBeacon.
My preference if it’s my airplane is to install an Stratus ESGi. That way you have a new transponder with both in and out. The tow pilots can pick up the ADS-B in along with AHRS and weather on their iPads.
The uAvionix tailBeacon will not work on a stock Pawnee rudder FYI.
Old October 28th 19, 01:23 AM posted to rec.aviation.soaring
2G
Bare in mind that the biannual transponder check may be more expensive with ADS-B as new, much more expensive, test equipment is required.
Tom
Old October 28th 19, 02:00 AM posted to rec.aviation.soaring
Charles Longley
You’re very incorrect. Having ADS-B out has nothing to do with the biennial transponder check. If your transponder is mode S as opposed to mode C there’s a slightly higher cost. $125 compared to $90 where I am at. All of the ADS-B out transponders are mode S.
Old October 28th 19, 02:34 AM posted to rec.aviation.soaring
Charles Longley
Well I guess you’re not totally incorrect. You’ll probably pay $35 more per year if you currently have a mode c transponder.
Old October 28th 19, 02:47 AM posted to rec.aviation.soaring
2G
Just reporting what my avionics tech told me.
Tom
Old October 28th 19, 03:33 AM posted to rec.aviation.soaring
Tony[_5_]
There are quite a few operations inside mode C veils around the country...
Old October 28th 19, 03:04 PM posted to rec.aviation.soaring
Dan Marotta
Tow pilots with iPads.* What a hoot!
Dan, 5J
Old October 28th 19, 03:28 PM posted to rec.aviation.soaring
Charles Longley
At least half of our tow pilots use them. We do quite a bit of cross country for retrieves and expeditions.
Old October 28th 19, 08:39 PM posted to rec.aviation.soaring
Larry Ruggiero
Good to know the tail beacon; I assume it’s because the rudder isn’t stable enough.
High Wing Planes are Better Than Low Wing Planes [email protected] Piloting 15 October 29th 18 03:05 AM
(??] [01/11] - Float Planes.jpg (0/1) Miscellaneous float planes Indrek[_4_] Aviation Photos 0 September 3rd 11 03:49 PM
(??] [01/11] - Float Planes.jpg (1/1) Miscellaneous float planes Indrek[_4_] Aviation Photos 0 September 3rd 11 03:49 PM
some planes [11 of 11] "old-air-planes-crashed-underwater-photos-pictures.jpg" yEnc (1/1) No Name Aviation Photos 0 August 9th 09 09:36 PM
Underwater planes are the most dangerous planes !!!!! Bruno Beam Naval Aviation 0 December 14th 04 04:01 AM
