Looking for AR4201 radio
Old October 9th 19, 10:24 AM posted to rec.aviation.soaring
Default Looking for AR4201 radio
I'm looking for AR4201 radio for sale.
Any Offer for me? Please contact me at
Thanks
Aviram
Old October 11th 19, 12:54 AM posted to rec.aviation.soaring
Steve Bralla
Thanks
Aviram
There is now a 4201 listed on Glider Source
http://glidersource.com/index.shtml
Old October 11th 19, 05:49 AM posted to rec.aviation.soaring
Please see this first...
https://www.federalregister.gov/docu...m-transceivers
Old October 11th 19, 04:34 PM posted to rec.aviation.soaring
John Foster
First of all, this is from 2004, and is a PROPOSED rule. Does anyone know what the final decision on this is?
Second, the PROPOSED AD would read:
(g) If the transceiver has an affected SN, and does not have Change Index 02 or higher index number marked on it, do the following:
(1) Add an aircraft flight manual (AFM) limitation to the Limitations Section of the AFM, that restricts transceiver usage to VFR operations, and add a placard to the cockpit within view of the pilot that states, in 1/4 inch-high or higher characters, “Use of Becker Comm Equipment AR 4201 is restricted to VFR operations”; or
(2) Remove the transceiver from service.
Pretty much all glider flying is under VFR, so if I read this correctly, all you'd need to do would be to add the above text to the POH/AFM under the limitations section, and carry on.
Old October 11th 19, 05:34 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
The AD was enacted as proposed.
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/0/fd19ce6bc6c0b3b986256f2e0050819c/$FILE/042104.pdf
Steve Leonard
Old October 12th 19, 08:17 AM posted to rec.aviation.soaring
krasw
Are you serious? Maybe you should also stay away of any aircraft that had an AD in it's history?
Old November 14th 19, 12:54 AM posted to rec.aviation.soaring
If you read the AD, it states:
(h) After the effective date of this AD, do not install any Becker Flugfunkwerk GmbH AR 4201 VHF AM transceiver with an affected SN that does not have Change Index 02 or higher index number marked on it, unless it was removed to determine the SN or to check for Change Index 02 or higher index number..
So I think the concern is quite relevant. Even if you are VFR only, according to the AD, it should not be installed after the AD date.
Old November 17th 19, 11:11 PM posted to rec.aviation.soaring
Dave Nadler
Steve Leonard
The AD says good units must have "Change Index 2" or greater.
Where is this "Change Index" marking?
Anybody have an example?
Thanks,
Best Regards, Dave
Old November 18th 19, 12:24 AM posted to rec.aviation.soaring
Duster[_2_]
Dave,
Mine has “Change Index 01” Printed just beneath the serial number.
Becker AR4201 John Williams Soaring 3 August 12th 17 03:09 PM
Becker AR4201 Radio Transmission Problem RMM Soaring 11 April 28th 14 08:59 AM
Becker AR4201 Robin Birch[_2_] Soaring 0 April 21st 14 06:22 PM
BECKER AR4201 guts Soaring 1 April 23rd 12 08:50 PM
VHF Becker AR4201 Philippe Home Built 2 July 9th 04 08:30 PM
