Gliding risk....
Old December 6th 19, 01:48 PM posted to rec.aviation.soaring
rudolph stutzmann
Default Gliding risk....
Many years ago I read an old book that was a collection of self submitted/reported stories from glider pilots that had a good outcome from a potentially disaterous situation. I think it was called "Glider accidents that almost happened".
It's a short book, more of a complication of short stories, but provided experiences of others that all people can learn from.
  #122
Old December 6th 19, 02:19 PM posted to rec.aviation.soaring
Never Again 2
from
It's called Soaring Accidents That Almost Happened and there happens to be
a
copy listed on ebay
  #123
Old December 6th 19, 09:53 PM posted to rec.aviation.soaring
2G
On Friday, December 6, 2019 at 3:15:05 AM UTC-8, Terry Slater wrote:
At 22:33 05 December 2019, 2G wrote:
On Thursday, December 5, 2019 at 11:15:08 AM UTC-8, Dave Walsh wrote:
At 16:14 05 December 2019, 2KA wrote:
Yeah, the entire fleet was inspected and repaired as required=20
(years ago),
and SH paid for the whole thing. Gliders built at the factory=20
in Germany
were found to be affected, as well as those built at=20
contractors.
Lynn Alley
"2KA"
=20
You were lucky! I was in a UK owned DuoDiscus based at=20
Sisteron, France, a few years ago. Wing spar de-bonding was=20
discovered at an annual inspection even though the glider had,=20
in theory, been inspected previously, looking for this specific=20
manufacturing fault. SH DECLINED TO PAY FOR THIS REPAIR;=20
if I recall correctly each of us in the 8 man syndicate had to=20
cough up about =C2=A3700.......
Dave Walsh
This is particularly disturbing, raising the question of the
effectiveness
of the original inspection method(s). Do the logbook(s) detail how and
when=
this inspection was done? How did the current annual discover the
de-bondi=
ng?
Tom
The inspections were performed with an endoscope, and the full length of
the spar bonding was inspected visually. SH issued a very comprehensive
guide to the process.
Terry
Yeah, I read their TN 396-08 that covered the process. This required cutting several holes in each wing for access by the endoscope. Of course, these holes had to be repaired and refinished. It would have been so much easier and cheaper to have done this inspection by ultrasonic NDT.
Tom
  #124
Old December 6th 19, 10:13 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
2G wrote on 12/6/2019 1:53 PM:
Tom
Terry
If the SH wing is constructed like the ASH26E wing, there is a layer of foam
between the outer skin and inner skin that is glued (hopefully) to spar. I suspect
ultrasound would not be effective, so what would kind of NDT would be used?
  #125
Old December 7th 19, 10:09 AM posted to rec.aviation.soaring
krasw
Reading this forum, sounds like biggest safety risks in gliding a
- Any glider or radio that has had an AD in it's history
- Rogue thermals
- Mysterious medical symptoms that occur only when flying
Other that that, we are pretty safe.
  #126
Old December 9th 19, 06:29 AM posted to rec.aviation.soaring
2G
Tom
Terry
Ultrasonic NDT with with sufficient energy to penetrate to the suspect layer.
  #127
Old December 9th 19, 06:30 AM posted to rec.aviation.soaring
2G
- Rogue thermals
The biggest safety risks have been, and continue to be, pilot error.
Tom
  #128
Old December 9th 19, 02:55 PM posted to rec.aviation.soaring
PGS
Tom
Terry
between the outer skin and inner skin that is glued (hopefully) to spar.. I suspect
Tom
Ultrasonic will not work through a foam layer.
  #129
Old December 9th 19, 11:07 PM posted to rec.aviation.soaring
Dave Walsh[_2_]
cough up about £700.......
Dave Walsh
I inspected this glider in compliance with the AD, and was
accused of
not inspecting it correctly! It was subsequently discovered an
undocumented wing change had taken place. Not all inspectors
or repair
shops are honest!
Terry Slater
I never recall being told that an "undocumented wing change" had
actually taken place; all I heard was a rumour. I was told that
there was no truth in the rumour. The facts remains that SH built
this Duo wing and we, the syndicate partners at the time, ended
up paying for its repair. Who inspected what and whether it was
done competently is not relevant: our wing WAS defective, it had
defective wing spar bonding, we ended up footing the bill. A ****
poor result.
Dave Walsh
  #130
Old December 10th 19, 12:10 AM posted to rec.aviation.soaring
Bob T
- Rogue thermals
Regarding the rogue thermal comment... they can occur. I came VERY close to becoming a statistic a few years ago while thermalling about 1500 ft. agl and wrote a feature article for SOARING MAGAZINE dealing with it. Rather than stalling an inside wing in a thermal turn (as one would expect if you happened to fly too slowly), while thermalling at about 10-15 kts above stall speed my INSIDE (lower) wing suddenly was pushed up and over, resulting in a steep dive / spiral. Subsequent research showed that some thermals can have strong down cores inside of overall lift, and if a glider happened to hit the sheer boundary, with suddenly one wing in the up air and the other in the down air, your day could quickly end.
See https://www.danlj.org/~danlj/Soaring...b_Thompson.pdf
and Dr. Dan Johnson had a good one, too https://www.danlj.org/~danlj/Soaring...Jan-p12-15.pdf
There are 2 books I referred to in my classes that have some pretty good info, too, although they are mostly intended for business folks:
1. Will Your Next Mistake Be Fatal? by Robert E. Mittelstaedt, Jr. for example - on page 160 - Insight #29 - Culture is powerful - what creates success may kill you. Think about this one seriously, for a long time! What you, or others, have gotten away with for a number of times can lead to complacency... and you becoming a statistic... that you couldn't tell anyone about ... from the grave. I recently attended a "celebration of life" for a friend that I suspect may have either lost his life due to his prior successes or rogue air.
2.Why We Make Mistakes by Joseph T. Hallinan
YOUR safety is at risk BR549 Instrument Flight Rules 0 December 13th 07 12:21 AM
At risk of starting a religious war. Bruce Soaring 14 August 20th 07 08:41 AM
NGA US navigational data at risk? Doug Vetter Piloting 16 April 19th 07 01:46 AM
Safety at risk in FAA Peterpan Piloting 7 February 24th 05 08:58 PM
U.S. SCHOOLKIDS AT RISK Cribsheet Piloting 0 December 5th 04 05:29 PM
