Gliding risk....
Old December 10th 19, 06:31 AM posted to rec.aviation.soaring
2G
Default Gliding risk....
On Monday, December 9, 2019 at 4:10:16 PM UTC-8, Bob T wrote:
On Saturday, December 7, 2019 at 3:09:19 AM UTC-7, krasw wrote:
Reading this forum, sounds like biggest safety risks in gliding a
- Any glider or radio that has had an AD in it's history
- Rogue thermals
- Mysterious medical symptoms that occur only when flying
Other that that, we are pretty safe.
Regarding the rogue thermal comment... they can occur. I came VERY close to becoming a statistic a few years ago while thermalling about 1500 ft. agl and wrote a feature article for SOARING MAGAZINE dealing with it. Rather than stalling an inside wing in a thermal turn (as one would expect if you happened to fly too slowly), while thermalling at about 10-15 kts above stall speed my INSIDE (lower) wing suddenly was pushed up and over, resulting in a steep dive / spiral. Subsequent research showed that some thermals can have strong down cores inside of overall lift, and if a glider happened to hit the sheer boundary, with suddenly one wing in the up air and the other in the down air, your day could quickly end.
See https://www.danlj.org/~danlj/Soaring...b_Thompson.pdf
and Dr. Dan Johnson had a good one, too https://www.danlj.org/~danlj/Soaring...Jan-p12-15.pdf
There are 2 books I referred to in my classes that have some pretty good info, too, although they are mostly intended for business folks:
1. Will Your Next Mistake Be Fatal? by Robert E. Mittelstaedt, Jr. for example - on page 160 - Insight #29 - Culture is powerful - what creates success may kill you. Think about this one seriously, for a long time! What you, or others, have gotten away with for a number of times can lead to complacency... and you becoming a statistic... that you couldn't tell anyone about ... from the grave. I recently attended a "celebration of life" for a friend that I suspect may have either lost his life due to his prior successes or rogue air.
2.Why We Make Mistakes by Joseph T. Hallinan
A thermal may not be your standard British thermal, but a confluence of several, competing mini-thermals. I have seen up to six, or more, dust devils converging to make a single thermal. However, in 40 years of flying, much in the very dynamic high western desert, I have never been upset in the manner you describe. This is not to say it can't happen, but I think the typical glider accident is much more mundane and the direct result of poor airmanship.
Tom
  #132
Old December 10th 19, 02:03 PM posted to rec.aviation.soaring
Tango Whisky
Le mardi 10 décembre 2019 07:31:14 UTC+1, 2G a écrit*:
- Rogue thermals
Tom
In 39 years of flying, I have once been upset by a thermal (entering at a speed of 130 kph, 300 m over the rocks in the central Alps, 4 m/s climb after recovery).
A second time such an upset was caused by a rotor (vertical speeds varying between -12 m/s and +12 m/s, trying to work it at 150 kph), but it didn't really come as a surprise.
  #133
Old December 10th 19, 02:38 PM posted to rec.aviation.soaring
I have been literally thrown out of thermals and rolled partially inverted by rotor while flying a very light (1-26) ship multiple times in NV . As a previous poster said, not much of a surprise, i think the “death-by-unusual wx condition” scenario is somewhat overblown. If flying on an extremely gusty day or with rotor condx or in monster thermals, a guy needs to factor that into his margins. If he does’nt then he’s setting himself up for an “unexpected” issue where in reality, it should’nt be unexpected at all. As 2g says, its just another part of proper and proactive airmanship.
  #134
Old December 10th 19, 03:30 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Tango Whisky wrote on 12/10/2019 6:03 AM:
Le mardi 10 dcembre 2019 07:31:14 UTC+1, 2G a crit :
airmanship.
Tom
recovery). A second time such an upset was caused by a rotor (vertical speeds
In 45 years of flying, I've never been upset by a thermal. I attribute that to
lack of exposure, as I rarely thermal below 1000' over mountains and ridges, or
below ridge top. That's where the "rogue thermals" exist, and where you are so
close to the ground that even a very capable pilot may not recover in time.
  #135
Old December 10th 19, 04:33 PM posted to rec.aviation.soaring
SoaringXCellence
Here's an article written by JJ Sinclair about a mountain phenomenon that is not that unusual:
https://www.dg-flugzeugbau.de/en/lib...k-the-mountain
My father's name is at the top of the list.
Mike
  #136
Old December 10th 19, 05:00 PM posted to rec.aviation.soaring
Dan Marotta
I've been upset as described, but it was rotor, not a thermal.
There's no substitute for training...
- Rogue thermals
Tom
Dan, 5J
  #137
Old December 10th 19, 05:15 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Tom
We'll make sure that gets printed on your tombstone. Back when I was a young pilot and working toward my multi-engine instrument I read a story in NTSD briefs or reports or one of the bi-weekly pamphlets publications I was reading about fly/IFR, regarding a 7,000 hour ATP that stalled a Beech Baron on short final. I thought how could you be so dumb. That evening I was doing a night instrument training flight in a rent-a-wreck piper Semihole. This particular evening the buzzing in the headsets had been louder than normal. This was my first night flight after the airport installed a displaced threshold. While on long final, I thought I heard tower clear an aircraft to taxi onto the active runway and hold. I was gentling pulling myself up, by the yoke, to look over the cowling. The stall horn went off and to me it was lost in the background buzzzing noise in the electrical system. The instructor put his palm on the yoke and pushed it forward enough for the horn to stop. I was still concentrated on looking over cowling pull myself up by the yoke, the horn went off for a second time and the instructor said" I got it. " It was not until then I understood what I had been doing and what I had been ignoring. I never again thought I was beyond making a mistake! I try to stay very alert, I keep learning and I keep flying. Could I make an airmanship mistake, you bet I could. Because I know I can screw up, I keep up with training, flying, Condor, reading about flying, and staying fit to fly. When The above don't come together I am fast to ground myself. I think only a foolish pilot would think they can't make a mistake.
Stay safe out there,
Jon
  #138
Old December 10th 19, 06:27 PM posted to rec.aviation.soaring
Ramy[_2_]
As Jonathan said. You will never hear me say that the typical glider accident is direct result of poor airmanship. Sure some of them were, but many aren’t. We are human and human make fatal mistakes, including, and perhaps especially, the best pilots. This is the ultimate price some of us pay for the thrill that soaring gives us. Life is either an adventure or not at all, just a bunch of birthdays strung together.
I am ok if this will be written on my tombstone.
Ramy
  #139
Old December 10th 19, 11:48 PM posted to rec.aviation.soaring
Dan Marotta
I went to the dictionary and looked up "****ing contest".* There was a
link to this thread.
Ramy
Dan, 5J
  #140
Old December 11th 19, 04:29 AM posted to rec.aviation.soaring
Ramy
Dan, 5J
Ha! I think that link is actually to the "15 Hour Wonders" thread.
This one is listed under the Circular Reasoning entry in wikipedia. It goes something like this:
All aspects of flying, with perhaps the exception of an elevator connected improperly at the factory, are within the definition of airmanship. Crashes happen. Therefore crashes happen because of poor airmanship.
YOUR safety is at risk BR549 Instrument Flight Rules 0 December 13th 07 12:21 AM
At risk of starting a religious war. Bruce Soaring 14 August 20th 07 08:41 AM
NGA US navigational data at risk? Doug Vetter Piloting 16 April 19th 07 01:46 AM
Safety at risk in FAA Peterpan Piloting 7 February 24th 05 08:58 PM
U.S. SCHOOLKIDS AT RISK Cribsheet Piloting 0 December 5th 04 05:29 PM
