trailer sway mitigation TSM
Old December 25th 19, 05:40 PM posted to rec.aviation.soaring
George Haeh
Default trailer sway mitigation TSM
So should we put zigzag tape on the fin?
  #62
Old December 25th 19, 05:46 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
wrote on 12/24/2019 9:07 PM:
On Tuesday, December 24, 2019 at 9:06:36 AM UTC-6, Eric Greenwell wrote:
Don Johnstone wrote on 12/24/2019 2:20 AM:
At 15:35 23 December 2019, Eric Greenwell wrote:
Don Johnstone wrote on 12/23/2019 1:36 AM:
What is worth remembering is that the cause of the sway is aerodynamic.
Loading, tyre pressure, fiction dampers can only ensure that the sway
is damped out and does not increase.
Trailers
with less vertical surface area aft of the wheels suffer less from
snaking than those with equal or greater vertical surface area
behind
the wheels. You may not be able to change the aerodynamics of
trailer but a good friction damper and proper loading will
normally
ensure that the snaking is damped. I have been a passenger in a car
towing a Cobra trailer at over 100mph, scared the crap out of me but it
was completely stable,
but
only when loaded with the glider. Empty it was a different story.
How did you decide aerodynamics was the important factor, and
not other
factors like tongue length, tires, etc? That's counterintuitive and, for
example,
it's at significant variance with Nelson Funston's paper on towing
glider
trailers,
which does not include aerodynamic factors.
http://journals.sfu.ca/ts/index.php/...wnload/779/737
From observation of driving trailers over many years. Aerodynamic forces
are almost always the initial cause of the onset of snaking, the other
factors take over in damping out, or increasing the initial disturbance. I
can be towing at say 60mph in clear air. If I am overtaken, especially by a
large vehicle I fist notice that as the vehicle is alongside the trailer is
drawn towards the other vehicle, when the vehicle has passed the trailer
moves away and this is where the snake starts. From that point on the other
mentioned factors take over, which, almost without exception, we all use
stabilisers, mostly ALKO type
As you state, swaying typically starts with a "trigger" event, and crosswinds
or large trucks are common triggers; however, it can also be a twitch on the
steering wheel from inattention, dodging road debris, moving away from
another vehicle drifting too close beside you, uneven road surfaces, higher
speeds while passing another vehicle, etc. The trigger is not important, but
the trailer's inherent stability is.
On the other hand, there are reports of trailer aerodynamics directly
affecting the trailer stability. The two I know about were both the older
Komet style trailers with "doghouses" or "tail fins" that were airfoil shaped
like vertical stabilizers without the rudder. Both owners reported
significant reduction in swaying by putting "spoilers" near the leading edge
on each side of the fin. The spoilers were about 1/2" high and a few inches
back from the leading edge.. The now common Cobra trailers have blunt leading
edges and flat, truncated trailing edges that apparently don't produce the
lift the Komet fins did.
My main concern is with trailer dynamics is safety, and for that, an
aerodynamic disturbance can initiate a major oscillation that can be dangerous.
Once started, the dynamics of the system is primary and aerodynamics is
secondary.
However, for comfort while towing, one would like to deal with small-amplitude
oscillations that are not dangerous, just annoying. For this, aerodynamics is
important. In general, fins near the back of the trailer could be useful,
however, most lack the finesse of a good airfoil and will have some separation.
They tend to have a larger than desired thickness to chord ratio, and the
closure angle of airfoil to the trailing edge can also be high.. Both of these
design 'features' can lead to separation on the sides of the fin.
When separation occurs, it causes a change in the side force and an accompanied
small change in yaw angle of the trailer. For a thick fin, the separation
point can migrate forward and back on each side of the fin and this can lead to
a small yaw oscillation. By forcing separation at a fixed point forward of
max thickness (with spoilers or other devices), the drag goes up a bit, but the
oscillation in side force is eliminated. Vortex generators at max thickness or
other aerodynamics widgets could provide a similar fix.
I did test my Cobra trailer with and without spoilers on the fin. I could not
detect a difference in stability, suggesting to me the fin is producing
insignificant lift when yawed.
  #63
Old December 25th 19, 07:56 PM posted to rec.aviation.soaring
Too thin. Zigzag tape is used to force transition and avoid a long-bubble separation as the flow goes from laminar to turbulent.
This paper describes some different vortex generators (figure 2):
https://pdfs.semanticscholar.org/517...170.1577303063
These types are less likely to cut someone than simple swept sheet metal ones. If you google 'wheeler vortex generators' you can find several of them for sale. Large trucks use them as well.
  #64
Old December 25th 19, 08:09 PM posted to rec.aviation.soaring
2G
Trailers
behind
normally
but
not other
example,
glider
trailers,
secondary.
Here is a couple of compilations of trailer towing accidents:
https://www.youtube.com/watch?v=CJtmOPdWrlE
https://www.youtube.com/watch?v=Z7Kfl97b57s
These accidents involve trailers of all types: travel trailers, utility trailers, and car hauling trailers. The number one common denominator is speed: most were passing the truck recording the video. Another factor is small vehicles towing larger travel trailers. A third factor is improper loading of the trailer.
A car-trailer combination is a very complex spring-mass-damper control system. Like any control system, there exists what is called a stability margin.. This is the margin you have to handle disturbances and still keep the system stable. Here is a paper I found that discusses this:
https://tinyurl.com/sux9ph9
The take-home message is Fig. 3; as the speed increases the stability margin decreases until it becomes zero (you are inherently unstable). So, the faster you drive, the smaller your stability (safety) margin. This paper confirms those findings by experimentation with an actual instrumented car-trailer combination:
https://pdfs.semanticscholar.org/e8e...b8065c44c2.pdf
Improper loading dramatically reduces the stability (safety) margin. We can control this by the tongue weight: higher tongue weights are more stable, lower weights are less stable. The most direct way to change this is moving the axle. Other significant factors are vehicles purpose-built for towing will have suspensions that are stiffer than passenger cars. Effects due to aerodynamics will be third-order and not significant compared to these primary causes of instability. So, don't think that you can put vortex generators on your trailer and drive 80 mph safely.
Tom
  #65
Old December 26th 19, 03:19 PM posted to rec.aviation.soaring
Mike N.
Wow, great examples of the tail wagging the dog.
On a less scientific note, and maybe more to the point of simple common sense, I have trailered my glider in a tube style trailer using a V6 Toyota Rav 4 from California to Utah going over the Sierra Nevada's and it was an easy comfortable trip.
To mitigate trailer sway issues I simply noted the speed at which trailer sway started when doing simple lane changes or getting passed by a large vehicle, and set myself a top speed limit of roughly 7 to 10 mph below that. Problem solved.
  #66
Old December 26th 19, 03:42 PM posted to rec.aviation.soaring
Thanks! A good practical solution!
  #67
Old December 26th 19, 04:06 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
wrote on 12/26/2019 7:42 AM:
A lower speed provides another advantage: tire longevity. I'm reminded of a
motorglider pilot towing his trailer from Florida to Parowan years ago, suffering
four blowouts along the way. That meant four separate tire changes, and purchasing
four tires, one at a time. His wife said she couldn't get him to slow down, even
though it was obvious (at least to her) they'd arrive sooner if he did so! At
least it wasn't unstable at the 75+ tow speeds.
  #68
Old December 26th 19, 05:14 PM posted to rec.aviation.soaring
BobW
it was an easy comfortable trip. To mitigate trailer sway issues I simply
This (now-lengthy) thread has (IMHO) numerous
sensible/informative/potentially-useful informative bits, and I'm not actually
clear why I'm (only-now) moved to chime in, but...
Slowing down is obviously (not?) the most-immediately-direct thing Joe Driver
can do...'simple common sense' indeed.
Perhaps like many readers, years'-worth (decades, sigh...) of trailering all
manner of gliders/trailers behind a short-wheelbase, 2600-lb car, yielded
bouts of empirical evidence (for all my above assertions), which - for the
record - were gained mostly throughout the intermountain west,
accident-free...interspersed with incidents of (never-per-trailer-repeated)
alarm, pulling variously-problematic examples. One of the worst was a
heavy-tongued (required 3 people to lift onto the towball), twin-axle,
'standard' open Schweizer trailer bearing a 2-32 in the 'standard'
back-end-loading, wing-root/fuselage-facing forward orientation. Slowing
*always* worked/works (in reductio ad absurdum vein, it's hard to become
unstable when motionless...duh).
My worst instability memory involves back-seat riding in a 4-seat 1980-ish
Honda Civic (the little, squarish-backed version) towing a Komet-enclosed AS-W
19) on 2-lane, flat, roads from McCook (NE) to Boulder (CO), just purchased by
2 buddies in the front seats. Joe Driver thought it humorous to play around on
both sides of the boundary defining violent towing-combo-instability. Talk
about 'playing on the freeway'. I never again allowed him to play Joe
Trailer-Driver with me...
Bob W.
Do trailers with coil springs and shock absorbers sway at higher speeds? son_of_flubber Soaring 35 July 8th 14 10:30 PM
Dual axle sway glider[_2_] Soaring 7 March 2nd 10 04:36 AM
US - 2009 explorer - trailer sway control Gary Emerson Soaring 1 October 15th 08 06:27 AM
Attention SkyLune: FAA To Fund Noise-mitigation Measures Larry Dighera Piloting 1 July 8th 06 05:36 PM
trailer sway [email protected] Soaring 14 June 19th 05 09:02 AM
