Updated IGC-approval documents for 11 types of Flight Recorders (FRs) have been published on the IGC and GFAC web sites and take effect from 1 January 2020. These documents lower the Approval level of older types of FR that no longer comply with the current IGC FR Specification. Reductions of level are from Level 1 (world records) to Level 2 (all badges and diplomas) or Level 3 (badges up to Diamonds).
Types of FRs affected are the Aircotec XC Profi, Cambridge 302, ClearNav 1, DSX T-Advisor/Tracer, EW microRecorder, Garrecht Volkslogger, IMI Erixx, NT Easy, Peschges VP8, Scheffel Themi, and Zander/SDI 941. This is the final stage in a process that started in January 2019 with the report of the IGC GFA Committee for the IGC Plenary agenda, followed by a presentation to the Plenary in March 2019, and approval to proceed. Detailed proposals were made to the IGC Bureau, and the IGC FR Technical Specification and Annex B to the Sporting Code (SC3B) were updated. Affected manufacturers were contacted (where they still exist) and given time to submit updates. A similar process happened in 2012 in which 13 types of IGC-approved FR were affected. The general reason for such changes is that advances in computer technology and vulnerability to hacking, is not compatible with retaining the highest levels of IGC-approval for old types of Recorders. To put this in perspective, there are currently 62 main types of IGC-approved Flight Recorders, 71 when different models within types are added. The main table of all these Approvals, and individual IGC-approval documents, can be downloaded from either the GFAC or FAI/IGC web sites, see below, together with other information on Flight Recorders. Ian W Strachan Chairman, IGC GNSS Flight Recorder Approval Committee (GFAC) Notes: 1. For the GFAC web site, see: www.ukiws.demon.co.uk/GFAC the complete table can be viewed directly at: www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf This table lists the name and main characteristics of individual IGC-approvals and in the last column there is a link to individual documents, click the link to call up the document. The table is followed by a list of individual IGC-approval documents in alphabetical order of manufacturer’s name from Aircotec to Zander. These can be called up by clicking the document name. 2. For the IGC web site go to: www.fai.org/igc-documents Scroll down and click "Flight Recorders", look down and click on: "IGC-approved Flight Recorders - Approval Documents" then click on "IGC-approval Documents for all IGC-approved Flight Recorders" This will call up a list of documents, the first one being a table of all IGC-approved FRs with links to Approval documents, followed by a Manufacturer table, List of updates, and History of FRs in IGC. ---------------- If you own, or fly with, any IGC-approved FR, it is recommended that you download its latest IGC-approval document from one of the web sites given below, and note any changes that may affect how you operate it. IGC-approval - GENERAL IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code for gliding and the Technical Specification for IGC-approved GNSS Flight Recorders. The Technical Specification is available through the igc-documents web site above or directly from the GFAC web site: http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf Programs that have been notified to IGC for the analysis of IGC files are listed on the GFAC web site under: "Analysis Programs for IGC Flight DataFiles" The Validation process checks that an IGC file has the correct structure and that the file is the same as initially downloaded from the FR. This is achieved either through the IGC Shell program, or through analysis programs such as SeeYou that include IGC Shell within their overall program. IGC Shell may be downloaded he www.ukiws.demon.co.uk/GFAC/downloads.htm This downloads the file IGCDLL.zip, which when un-zipped, gives the IGC Shell program. This web site also contains the latest FR Manufacturers’ Data Link Library (DLL) files that are used by IGC Shell and other programs to Validate the structure of an IGC file. The IGC file Validate check ensures that the IGC file came from a serviceable and secure FR, and the file is identical to when it was originally downloaded. This check is required before a flight performance recorded in the IGC file can be approved to the standards of IGC. Finally, the Sporting Code for gliding (SC3) and its annexes A-D may be downloaded via: www.fai.org/igc-documents in which "Sporting Code - Section 3: Gliding" is at the top of the list ------------------------ |
Hi Ian,
Thank you for the work you do for the gliding community. Is there is a list that summarizes the loggers and their approval levels? It seems that one would need to look into each approval document to find the level of approval of each type. A simple list would be helpful. It would include the make and model and approval level. Thanks, Paul Remde _____________________ On Wednesday, January 1, 2020 at 7:54:38 AM UTC-6, Ian Strachan wrote: Updated IGC-approval documents for 11 types of Flight Recorders (FRs) have been published on the IGC and GFAC web sites and take effect from 1 January 2020. These documents lower the Approval level of older types of FR that no longer comply with the current IGC FR Specification. Reductions of level are from Level 1 (world records) to Level 2 (all badges and diplomas) or Level 3 (badges up to Diamonds). Types of FRs affected are the Aircotec XC Profi, Cambridge 302, ClearNav 1, DSX T-Advisor/Tracer, EW microRecorder, Garrecht Volkslogger, IMI Erixx, NT Easy, Peschges VP8, Scheffel Themi, and Zander/SDI 941. This is the final stage in a process that started in January 2019 with the report of the IGC GFA Committee for the IGC Plenary agenda, followed by a presentation to the Plenary in March 2019, and approval to proceed. Detailed proposals were made to the IGC Bureau, and the IGC FR Technical Specification and Annex B to the Sporting Code (SC3B) were updated. Affected manufacturers were contacted (where they still exist) and given time to submit updates. A similar process happened in 2012 in which 13 types of IGC-approved FR were affected. The general reason for such changes is that advances in computer technology and vulnerability to hacking, is not compatible with retaining the highest levels of IGC-approval for old types of Recorders. To put this in perspective, there are currently 62 main types of IGC-approved Flight Recorders, 71 when different models within types are added. The main table of all these Approvals, and individual IGC-approval documents, can be downloaded from either the GFAC or FAI/IGC web sites, see below, together with other information on Flight Recorders. Ian W Strachan Chairman, IGC GNSS Flight Recorder Approval Committee (GFAC) Notes: 1. For the GFAC web site, see: www.ukiws.demon.co.uk/GFAC the complete table can be viewed directly at: www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf This table lists the name and main characteristics of individual IGC-approvals and in the last column there is a link to individual documents, click the link to call up the document. The table is followed by a list of individual IGC-approval documents in alphabetical order of manufacturer’s name from Aircotec to Zander. These can be called up by clicking the document name. 2. For the IGC web site go to: www.fai.org/igc-documents Scroll down and click "Flight Recorders", look down and click on: "IGC-approved Flight Recorders - Approval Documents" then click on "IGC-approval Documents for all IGC-approved Flight Recorders" This will call up a list of documents, the first one being a table of all IGC-approved FRs with links to Approval documents, followed by a Manufacturer table, List of updates, and History of FRs in IGC. ---------------- If you own, or fly with, any IGC-approved FR, it is recommended that you download its latest IGC-approval document from one of the web sites given below, and note any changes that may affect how you operate it. IGC-approval - GENERAL IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code for gliding and the Technical Specification for IGC-approved GNSS Flight Recorders. The Technical Specification is available through the igc-documents web site above or directly from the GFAC web site: http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf Programs that have been notified to IGC for the analysis of IGC files are listed on the GFAC web site under: "Analysis Programs for IGC Flight DataFiles" The Validation process checks that an IGC file has the correct structure and that the file is the same as initially downloaded from the FR. This is achieved either through the IGC Shell program, or through analysis programs such as SeeYou that include IGC Shell within their overall program. IGC Shell may be downloaded he www.ukiws.demon.co.uk/GFAC/downloads.htm This downloads the file IGCDLL.zip, which when un-zipped, gives the IGC Shell program. This web site also contains the latest FR Manufacturers’ Data Link Library (DLL) files that are used by IGC Shell and other programs to Validate the structure of an IGC file. The IGC file Validate check ensures that the IGC file came from a serviceable and secure FR, and the file is identical to when it was originally downloaded. This check is required before a flight performance recorded in the IGC file can be approved to the standards of IGC. Finally, the Sporting Code for gliding (SC3) and its annexes A-D may be downloaded via: www.fai.org/igc-documents in which "Sporting Code - Section 3: Gliding" is at the top of the list ------------------------ |
Hi Paul, Happy New Year!
Does not http://www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf tell you what you need to know? Tim Newport-Peace. -- At 13:52 02 January 2020, Paul Remde wrote: Hi Ian, Thank you for the work you do for the gliding community. Is there is a lis= t that summarizes the loggers and their approval levels? It seems that one= would need to look into each approval document to find the level of approv= al of each type. A simple list would be helpful. It would include the mak= e and model and approval level. Thanks, Paul Remde _____________________ On Wednesday, January 1, 2020 at 7:54:38 AM UTC-6, Ian Strachan wrote: Updated IGC-approval documents for 11 types of Flight Recorders (FRs) hav= e been published on the IGC and GFAC web sites and take effect from 1 Janua= ry 2020. These documents lower the Approval level of older types of FR tha= t no longer comply with the current IGC FR Specification. Reductions of le= vel are from Level 1 (world records) to Level 2 (all badges and diplomas) o= r Level 3 (badges up to Diamonds).=20 =20 Types of FRs affected are the Aircotec XC Profi, Cambridge 302, ClearNav = 1, DSX T-Advisor/Tracer, EW microRecorder, Garrecht Volkslogger, IMI Erixx,= NT Easy, Peschges VP8, Scheffel Themi, and Zander/SDI 941.=20 =20 This is the final stage in a process that started in January 2019 with th= e report of the IGC GFA Committee for the IGC Plenary agenda, followed by a= presentation to the Plenary in March 2019, and approval to proceed. Detai= led proposals were made to the IGC Bureau, and the IGC FR Technical Specifi= cation and Annex B to the Sporting Code (SC3B) were updated. Affected manu= facturers were contacted (where they still exist) and given time to submit = updates. A similar process happened in 2012 in which 13 types of IGC-appro= ved FR were affected. The general reason for such changes is that advances= in computer technology and vulnerability to hacking, is not compatible wit= h retaining the highest levels of IGC-approval for old types of Recorders. = =20 =20 To put this in perspective, there are currently 62 main types of IGC-appr= oved Flight Recorders, 71 when different models within types are added. Th= e main table of all these Approvals, and individual IGC-approval documents,= can be downloaded from either the GFAC or FAI/IGC web sites, see below, to= gether with other information on Flight Recorders. =20 =20 =20 Ian W Strachan=20 Chairman, IGC GNSS Flight Recorder Approval Committee (GFAC) =20 Notes:=20 =20 1. For the GFAC web site, see: www.ukiws.demon.co.uk/GFAC =20 the complete table can be viewed directly at: www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf This table lists the name and main characteristics of individual IGC-appr= ovals and in the last column there is a link to individual documents, click= the link to call up the document. The table is followed by a list of indi= vidual IGC-approval documents in alphabetical order of manufacturer=E2=80= =99s name from Aircotec to Zander. These can be called up by clicking the = document name. =20 2. For the IGC web site go to: www.fai.org/igc-documents Scroll down and click "Flight Recorders",=20 look down and click on: "IGC-approved Flight Recorders - Approval Documen= ts" then click on "IGC-approval Documents for all IGC-approved Flight Recorde= rs" This will call up a list of documents, the first one being a table of all= IGC-approved FRs with links to Approval documents, followed by a Manufactu= rer table, List of updates, and History of FRs in IGC.=20 =20 ---------------- =20 If you own, or fly with, any IGC-approved FR, it is recommended that you = download its latest IGC-approval document from one of the web sites given b= elow, and note any changes that may affect how you operate it. =20 IGC-approval - GENERAL IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder = Approval Committee (GFAC) in accordance with Annex B to the Sporting Code f= or gliding and the Technical Specification for IGC-approved GNSS Flight Rec= orders. =20 =20 The Technical Specification is available through the igc-documents web si= te above=20 or directly from the GFAC web site: http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf =20 Programs that have been notified to IGC for the analysis of IGC files are= listed on the GFAC web site under: "Analysis Programs for IGC Flight DataF= iles" =20 The Validation process checks that an IGC file has the correct structure = and that the file is the same as initially downloaded from the FR. This is = achieved either through the IGC Shell program, or through analysis program= s such as SeeYou that include IGC Shell within their overall program. =20 IGC Shell may be downloaded he www.ukiws.demon.co.uk/GFAC/downloads.h= tm This downloads the file IGCDLL.zip, which when un-zipped, gives the IGC S= hell program. This web site also contains the latest FR Manufacturers=E2= =80=99 Data Link Library (DLL) files that are used by IGC Shell and other p= rograms to Validate the structure of an IGC file. The IGC file Validate ch= eck ensures that the IGC file came from a serviceable and secure FR, and th= e file is identical to when it was originally downloaded. This check is re= quired before a flight performance recorded in the IGC file can be approved= to the standards of IGC. =20 Finally, the Sporting Code for gliding (SC3) and its annexes A-D may be d= ownloaded via: www.fai.org/igc-documents in which "Sporting Code - Section= 3: Gliding" is at the top of the list =20 ------------------------ |
| IGC-approval for the LX 10000 Flight Recorder | Ian Strachan | Soaring | 1 | November 12th 18 07:14 PM |
| IGC approval for the LX9000HAFR Flight Recorder | Ian Strachan | Soaring | 0 | August 3rd 16 11:29 PM |
| IGC-approval for the FlarmMouse Flight Recorder | Ian Strachan | Soaring | 0 | August 2nd 13 01:37 PM |
| New IGC-approval for GNSS Flight Recorder | Ian Strachan | Soaring | 0 | February 14th 09 09:00 PM |
| IGC-approval levels for some types of Flight Recorders | Ian Strachan | Soaring | 42 | March 19th 05 06:42 PM |
