Locating Transponder Antenna on top of the fuselage instead of under it.
Old January 1st 20, 09:08 PM posted to rec.aviation.soaring
Default Locating Transponder Antenna on top of the fuselage instead ofunder it.
From the Aircraft Spruce website, the drag spec on a rod and ball transponder antenna is listed as 0.41 lbs. at 250 kts. The blade type lists as 0.09 lbs. at 250 knots. Drag increases by the square of the speed, so at half the speed (125 knots), the drag is around 1/4 the numbers listed. If you are concerned about the .0225 lbs. in extra drag vs. the .01025 lbs., buy the blade type and keep the yaw string straight. You will probably increase your final glide numbers by at least a couple of yards.
  #62
Old January 1st 20, 09:56 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
On Wed, 01 Jan 2020 06:32:46 -0800, India November wrote:
I am thinking of the theoretical advantage in drag coefficient of a
blade vs rod antenna which holds for any speed.
I found this: https://www.grc.nasa.gov/www/k-12/airplane/shaped.html
which may help sort things out for you, though these numbers are for 3D
shapes while what you really want is drag comparisons for 2D shapes with
the shape extending right across the wind tunnel or (better) with one end
attached to a side wall that's in the airstream.
Other, less well written web pages, suggest that a teardrop shape with a
blunt LE and max thickness at around 30% chord and slightly convex
surfaces behind max thickness that terminate at a sharp TE should have
about half the drag of a cylinder with the same frontal area.
As others have said, drag will rise sharply if the AOA of the streamlined
shape isn't zero and this will get worse as the max thickness moves back
toward 50% and/or the LE becomes sharper.
If you're really worried, find a University with an aerodynamics dept and
try to persuade a student to write a term paper based on wind tunnel
tests on a rod antenna and the best shaped blade antenna you can find.
Now, you can calculate your glider's drag at, say, best glide and max
cruise (easy to do from its flying weight and glide polar) and then
calculate how much each adding each antenna would affect the glide angle
at those speeds.
We'll all be interested to see just how much effect the antenna has.
Martin | martin at
Gregorie | gregorie dot org
  #63
Old January 1st 20, 10:33 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Martin Gregorie wrote on 1/1/2020 1:56 PM:
at those speeds.
A 50:1 900 lb glider at best L/D has 18 lb of drag; the rod antenna at 62 knots
has a drag of 0.41lb/16 = 0.025, or 0.14%. That's about 0.07 L/D loss.
The rod drag quadruples at 125 knots, but the drag of the glider would increase
substantially, also, so maybe the percentage doubles, which is still only 0.3% of
total drag.
  #64
Old January 1st 20, 11:06 PM posted to rec.aviation.soaring
with the shape extending right across the wind tunnel or (better) with
one end attached to a side wall that's in the airstream.
a blunt LE and max thickness at around 30% chord and slightly convex
streamlined shape isn't zero and this will get worse as the max
thickness moves back toward 50% and/or the LE becomes sharper.
and try to persuade a student to write a term paper based on wind
tunnel tests on a rod antenna and the best shaped blade antenna you can
find.
angle at those speeds.
62 knots has a drag of 0.41lb/16 = 0.025, or 0.14%. That's about 0.07
L/D loss.
increase substantially, also, so maybe the percentage doubles, which is
still only 0.3% of total drag.
I thought it was likely to be a pretty small effect. Thanks for
confirming.
Martin | martin at
  #65
Old January 2nd 20, 01:14 AM posted to rec.aviation.soaring
MNLou
Thank you Eric!
Putting it in perspective like that was very helpful.
Lou
  #66
Old January 2nd 20, 01:25 AM posted to rec.aviation.soaring
Mark Mocho wrote:
"If you are concerned about the .0225 lbs. in extra drag vs. the .01025 lbs.., buy the blade type and keep the yaw string straight. You will probably increase your final glide numbers by at least a couple of yards."
But Mark, the blade type just looks cool! Especially when mounted on top! 😛😂😵
  #67
Old January 2nd 20, 03:44 AM posted to rec.aviation.soaring
But I have flown with you, Cliff, and the drag from the antenna is only low when aligned with the airflow. Your yaw string looks like a windshield wiper! You don't go faster by using the rudder pedals like bicycle pedals.
  #68
Old January 2nd 20, 05:41 AM posted to rec.aviation.soaring
Thanks. I needed a laugh.
  #69
Old January 2nd 20, 11:44 PM posted to rec.aviation.soaring
Chris Behm
Just mount the blade antenna by the front lug only, leave it loose a bit. Cut a slight smile slot for the coax, use a bit of grease, and,voila!
Now your blade style antenna can feather with the wind, netting you the least amount of drag possible.
  #70
Old January 3rd 20, 01:50 AM posted to rec.aviation.soaring
jfitch
Why not mount it on the side of the fuselage and use it as an angle of attack sensor as well?
PowerFlarm Antenna Locations on Carbon Fuselage Dan Marotta Soaring 9 August 15th 19 08:38 PM
ASW27 Trasponder Antenna Installation Inside Fuselage. Paul Birkett Soaring 45 January 8th 18 03:31 AM
ASW-24 - Transponder Cable Routing in Fuselage [email protected] Soaring 6 February 3rd 15 05:00 PM
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 19th 15 11:00 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
