Affordable Oxygen
Old January 25th 20, 01:48 AM posted to rec.aviation.soaring
Default Affordable Oxygen
On Friday, January 24, 2020 at 3:50:11 PM UTC-5, wrote:
The vets my wife and I deal with are better doctors than the doctors we deal with.
Med school is way easier to get in than Veterinary school.
Old January 25th 20, 05:20 AM posted to rec.aviation.soaring
Jonathan St. Cloud
On Friday, January 24, 2020 at 2:21:35 PM UTC-8, Bob Kuykendall wrote:
On Friday, January 24, 2020 at 12:44:33 PM UTC-8, Jonathan St. Cloud wrote:
Using medical O2 for aviation...
I thought we settled this twenty years ago.
https://www.avweb.com/features/pelic...elders-oxygen/
Medical, welding, and aviator's breathing oxygen are all produced using the same processes and equipment. Not just similar. They're all the exact same stuff from the same tap.
The only differences are what they're dispensed into and how they're used.. The requirements for purity and cleanliness in all compressed oxygen applications are such that the baseline specifications for all are the same.
--Bob K.
I mis-spoke, I meant to say jury rigging med O2 equipment for a purpose not intended, could be hazardous to one's health. Kind of thought that was implied, forgot an engineer or two populates these pages. I have had hypoxia before during a contest out of INYK. I later realized I had mixed equipment from Aerox and MH. Aerox oxyisaver cannula cannot be used with MH equipment. I would strongly encourage anyone to use the equipment from the manufacturer, read the instructions and not attempt to jury rig a mix of med O2 and aviation O2 equipment.
Old January 25th 20, 06:54 PM posted to rec.aviation.soaring
Tom BravoMike
The only differences are what they're dispensed into and how they're used. The requirements for purity and cleanliness in all compressed oxygen applications are such that the baseline specifications for all are the same.
--Bob K.
What/where is INYK? Sorry, can't find it.
Old January 25th 20, 08:20 PM posted to rec.aviation.soaring
Jock Proudfoot
St. Cloud
wr=
ote:
=20
=20
=20
https://www.avweb.com/features/pelic...3getting-high-
on-welders=
-oxygen/
=20
produced
using=
the exact
=20
they're
us=
oxygen
ap=
same.
=20
--Bob K.
=20
a purpose
n=
that was
had
hypox=
equip=
used with MH
equ=
from the
ma=
of med
Inyokern Airport (IATA: IYK, ICAO: KIYK, FAA LID: IYK)
Old January 25th 20, 08:24 PM posted to rec.aviation.soaring
Jock Proudfoot
St. Cloud
wr=
ote:
=20
=20
=20
on-welders=
-oxygen/
=20
produced
using=
the exact
=20
they're
us=
oxygen
ap=
same.
=20
--Bob K.
=20
a purpose
n=
that was
had
hypox=
equip=
used with MH
equ=
from the
ma=
of med
Old January 25th 20, 08:39 PM posted to rec.aviation.soaring
Jock Proudfoot
St. Cloud
wr=
ote:
=20
=20
=20
on-welders=
-oxygen/
=20
produced
using=
the exact
=20
they're
us=
oxygen
ap=
same.
=20
--Bob K.
=20
a purpose
n=
that was
had
hypox=
equip=
used with MH
equ=
from the
ma=
of med
  #28
Old January 25th 20, 11:58 PM posted to rec.aviation.soaring
Tom BravoMike
Got it, thanks!
  #29
Old January 27th 20, 12:23 AM posted to rec.aviation.soaring
ABO is tested for moisture on an individual cylinder basis. Medical O2 is tested for purity on a sample basis (usually one cylinder out of a 20 cylinder line). Industrial O2: each cylinder is sniff tested prior to filling to make sure no flammable gas or other stinky thing is loitering in the cylinder. No testing of industrial grade after filling.
Yes, all are filled from the same liquid O2 tank, all are pumped on the same manifold. However, the compliant filling facility does the above steps because either FAA, FDA, or CGA says that is how to do it.
It's reasonably easy to play safe: have a CGA 540 tank, get a fill from an ABO cascade manifold at the airport. It is not reasonably easy to get a "great price", especially if you fly where there is no ABO manifold available..
  #30
Old January 27th 20, 01:11 AM posted to rec.aviation.soaring
Andrew Ainslie
Ask anyone who has ever done a decent physics class what happens to moisture when you compress a wet gas. It drops out. That’s why air compressors have moisture traps.
This nonsense about testing for moisture/adding moisture in medical oxygen etc etc never goes away. Compressed oxygen is incredibly dry. Any moisture in a compressed oxygen cylinder would be rolling around the bottom, not in the gas.
Easy and affordable IGC logger Senna Van den Bosch Soaring 26 May 1st 18 09:05 AM
Looking for an affordable glider.... xTrainwrecKx Soaring 4 August 17th 11 12:03 PM
Looking for an affordable glider.... xTrainwrecKx Soaring 1 August 9th 11 05:07 PM
Affordable Glider K Smith Soaring 20 July 23rd 09 07:13 AM
Affordable planes Tom Home Built 4 November 6th 08 08:59 PM
