Upgrading panel
Old January 30th 20, 05:47 PM posted to rec.aviation.soaring
Jonathan Foster
Default Upgrading panel
On Thursday, January 30, 2020 at 10:24:52 AM UTC-7, Dan Marotta wrote:
I saw a refurbished Dell Streak 5 on eBay for under $60.Â* The Sony
Experia Z3 is also a very good platform (Android) and can be had for
significantly less than a purpose built soaring computer.Â* And XCSoar,
LK8000, and Tophat soaring software are...Â* FREE.
On 1/30/2020 7:09 AM, Nick Kennedy wrote:
Colton
The CAI 302 + 303 display is a fantastic value. Connect it to a Oudie and your all set.
You have to be able to "talk" to it using the CAI Utility software.
This is to put in setting and waypoints.
I used to be able to do this with SeeYou Mobile Connect, from the Oudie, but for some reason I cannot anymore.
I have the CAI Utility software and waypoint files stored on a older hand held computer, a device called a Ipaq. This goes into a cradle that plugs into the 302.
I know this sounds daunting, and the first time it is. But all this stuff is Cheap. And when working, works great.
You can easily configure the 302 to use a probe for TE or Electronic TE..
I recommend trying both ways over time, one way or another might work better with your ship.
Good Luck
Fly Safe in 2020
Dan, 5J
Add an IOIO board from http://www.soartronic.net/ and you can combine your 302 and flarm data into xcsoar or lk8000. Awesome combo.
Old January 30th 20, 06:44 PM posted to rec.aviation.soaring
Roger your advice T8, I would not ask the 302 to run a half or fully depleted oudie. In my system, In this years system I start with my oudie fully charged and the 302 interconnect cable is just keeping the oudie topped up. I have about 30 hours on the new system and no issues whatsoever so far. My oudie igc will run easily for 7 hours on its internal battery, but I like the insurance of having some power going to her for the longer flights.
Upgrading a used Homebuilt... [email protected] Home Built 5 August 25th 06 02:57 AM
Upgrading your Strikefinder? Peter MacPherson Owning 2 September 1st 04 02:32 PM
Upgrading your Strikefinder? Peter MacPherson Instrument Flight Rules 0 August 31st 04 03:45 PM
Upgrading your Strikefinder? Peter MacPherson Piloting 0 August 31st 04 03:45 PM
Upgrading System Anthony Acri Simulators 1 July 17th 03 03:18 AM
