Updated IGC-approval documents for 35 types of Flight Recorders (FRs) have been published on the IGC and GFAC web sites with a date of effect on 1 February 2020. These documents standardise references to web pages, email addresses, and details of manufacturers, and there are no changes to IGC-approval levels.
This follows 11 changes of IGC-approval level that were published on 1 January. As a result of the above, all current IGC-approval documents now have this year’s date. Ian W Strachan Chairman, IGC GNSS Flight Recorder Approval Committee (GFAC) Notes: 1. For the GFAC web site, see: www.ukiws.demon.co.uk/GFAC the complete table can be viewed directly at: www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf This table lists the name and main characteristics of individual IGC-approvals and in the last column there is a link to individual documents, click the link to call up the document. The table is followed by a list of individual IGC-approval documents in alphabetical order of manufacturer’s name from Aircotec to Zander. These can be called up by clicking the document name. 2. For the IGC web site go to: www.fai.org/igc-documents Scroll down and click "Flight Recorders", look down and click on: "IGC-approved Flight Recorders - Approval Documents" then click on "IGC-approval Documents for all IGC-approved Flight Recorders" This will call up a list of documents, the first one being a table of all IGC-approved FRs with links to Approval documents, followed by a Manufacturer table, List of updates, and History of FRs in IGC. ---------------- If you own, or fly with, any IGC-approved FR, it is recommended that you download its latest IGC-approval document from one of the web sites given below, and note any changes that may affect how you operate it. IGC-approval - GENERAL IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code for gliding and the Technical Specification for IGC-approved GNSS Flight Recorders. The Technical Specification is available through the igc-documents web site above or directly from the GFAC web site: http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf Programs that have been notified to IGC for the analysis of IGC files are listed on the GFAC web site under: "Analysis Programs for IGC Flight DataFiles" The Validation process checks that an IGC file has the correct structure and that the file is the same as initially downloaded from the FR. This is achieved either through the IGC Shell program, or through analysis programs such as SeeYou that include IGC Shell within their overall program. IGC Shell may be downloaded he www.ukiws.demon.co.uk/GFAC/downloads.htm This downloads the file IGCDLL.zip, which when un-zipped, gives the IGC Shell program. This web site also contains the latest FR Manufacturers’ Data Link Library (DLL) files that are used by IGC Shell and other programs to Validate the structure of an IGC file. The IGC file Validate check ensures that the IGC file came from a serviceable and secure FR, and the file is identical to when it was originally downloaded. This check is required before a flight performance recorded in the IGC file can be approved to the standards of IGC. Finally, the Sporting Code for gliding (SC3) and its annexes A-D may be downloaded via: www.fai.org/igc-documents in which "Sporting Code - Section 3: Gliding" is at the top of the list ------------------------ |
| Thread Tools | |
| Display Modes | |
| ASK 21B receives FAA Approval of Standard Type Certificate G47EU Rev.2 | Noelle Mayes[_2_] | Soaring | 1 | July 12th 19 04:09 AM |
| IGC-approval documents - latest updates 10 August 2012 | Ian Strachan | Soaring | 1 | August 14th 12 12:32 AM |
| Approval document issued for IGC Position Recorder | Ian Strachan | Soaring | 16 | February 19th 10 01:40 PM |
| IGC-approval document issued for NT Easy GNSS recorder | Ian Strachan | Soaring | 0 | January 10th 07 10:31 PM |
| Updates to IGC approval documents for GNSS flight recorders | Ian Strachan | Soaring | 2 | September 27th 04 02:32 PM |
