iGlide
Old February 12th 20, 10:14 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default iGlide
On Wednesday, February 12, 2020 at 12:37:25 PM UTC-5, kinsell wrote:
On 2/11/20 11:09 PM, John Foster wrote:
On Tuesday, February 3, 2015 at 12:15:06 PM UTC-7, Ben S wrote:
If you are an Air Avionics iGlide user, please share your evaluation.
Also interested in knowing if you are happy with the sunlight
readability of your iPhone. Is iPhone 6 brighter than iPhone 5?
Is iGlide "secure" enough to use for badge flights here in the US? I have the basic version, which will show your flight path on the map, but doesn't offer much more than that, and am thinking of upgrading to a better version this season. I'll be running it on either an iPhone 6 Plus or an iPhone XS Max.
Nope. From page two of this guide:
https://www.ssa.org/files/member/b&rguide.pdf
SC3 provides for individual countries to approve
off-the-shelf GPS Position Recorders for recording Silver or Gold
Badge flights. As of 15 May2010, no such recorders have been
approved for use in the US.
According to the list at http://www.ukiws.demon.co.uk/GFAC/po..._recorders.htm, which is maintained on the web site of the Chairman of the GNSS Flight Recorder Approval Committee (GFAC) of the International Gliding Commission of FAI, the Soaring Society of America has only approved the "FlyWithCE" and the "FlyWithCE FR300" as position recorders (updated 2018). I've OO'd a number of Silver badge legs with FR300's in Canada.
Old February 12th 20, 10:29 PM posted to rec.aviation.soaring
kinsell
Default iGlide
Looks like the SSA has updated info that matches what you postd. Page 7
of this:
https://www.ssa.org/files/member/B&RGuide_2019.pdf
I'll see if the record keeper can get the obsolete info removed.
Dave
Old February 13th 20, 01:15 AM posted to rec.aviation.soaring
Default iGlide
Top Hat https://www.tophatsoaring.org/ is another excellent glide computer (glide computer only, not a logger). Impressive on a Samsung S10 and its free.
Old February 13th 20, 03:49 PM posted to rec.aviation.soaring
6PK
Default iGlide
Top Hat as well as XCSoar has a logging function..
Old February 13th 20, 05:23 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default iGlide
S10 and its free.
So does the other clone, LK8000. It writes G records at the end of a log,
so I suppose that means that XCsoar and TopHat do too.
But AFAIK none of these are accepted anywhere as equivalent to a secure
FR or PR, which means they can't be used for badge claims. They're fine
for the BGAladder and similar national league tables. I don't use OLC so
don't know if they will accept logs from them.
Martin | martin at
Gregorie | gregorie dot org
Old February 13th 20, 05:37 PM posted to rec.aviation.soaring
kinsell
Default iGlide
S10 and its free.
Yes OLC will accept them. Unless you're a motorglider, they don't
record engine noise.
Old February 14th 20, 12:43 AM posted to rec.aviation.soaring
Dan Marotta
Default iGlide
Top Hat igc files are acceptable for OLC flights, but not for badges.
Top Hat
Dan, 5J
  #28
Old February 14th 20, 02:04 AM posted to rec.aviation.soaring
jfitch
Default iGlide
Top Hat
Dan, 5J
iGlide will upload your IGC file directly to OLC from the phone, no intermediate steps at all.
  #29
Old February 14th 20, 02:34 AM posted to rec.aviation.soaring
kinsell
Default iGlide
Top Hat
Dan, 5J
Does iGlide record engine noise level? Flying a Stemme, he would need that.
  #30
Old February 15th 20, 05:52 AM posted to rec.aviation.soaring
Wade G
Default iGlide
No engine noise level with iGlide sadly. I fly a ASH-26e and have inquired about this. I really like iGlide but all of my flights using it are not qualified for OLC.
iPad mini/iGlide Ross Whittle Soaring 10 July 28th 14 03:46 AM
Butterfly iGlide App now available in the US Marc - Butterfly Avionics Soaring 25 June 2nd 14 08:10 AM
iglide [email protected] Soaring 1 June 2nd 13 05:07 PM
Announcing the iGlide Software Give-Away! [email protected] Soaring 0 February 25th 13 01:14 PM
Butterfly iGlide Reed von Gal Soaring 4 May 2nd 12 06:00 PM
