Flarm, Flarmnet, What?
Old March 8th 20, 05:00 PM posted to rec.aviation.soaring
Dan Marotta
Default Flarm, Flarmnet, What?
Yesterday, while flying with two friends, I noticed the following:
I'm equipped with a Flarm portable, ClearNav II, Flarmview, and ADS-B
In/Out.
One was equipped with transponder and Flarm.
The other (Two) was equipped with ADS-B Out only.
My indications were as follows:Â* On the Flarm portable, either showed as
a triangle symbol with delta altitude.Â* On the Flarmview, either was
displayed and identified by his ICAO code.Â* But, on the ClearNav, One
showed as a glider symbol with his call sign and Two displayed as a
glider symbol with the last two characters of his ICAO code.Â* All other
ADS-B targets were displayed only as what I'd describe as a B-52 symbol
with no codes.
Any ideas?
Dan, 5J
Old March 8th 20, 06:24 PM posted to rec.aviation.soaring
Ramy[_2_]
Every flarm display behaves differently. Some displays are more intelligent than others. So this explains the different in symbols.
As for call sign, you should see the contest number if the flarm or ADSb is registered on flarmnet.org. Yes you can and should register your ADSB on flarmnet if you don’t have flarm. Flarmnet converts your ICAO code to recognizable contest number. Both flarm and ADS-B transmits you’re ICAO code. I wish every pilot register their device on flarmnet. It takes 1 minute.
Ramy
Old March 8th 20, 06:46 PM posted to rec.aviation.soaring
That way u know who to follow lol, I wish all identities were hidden.
Old March 8th 20, 08:33 PM posted to rec.aviation.soaring
Dan Marotta
Thanks, I'll pass that information along to Number Two.Â* He has a PF
portable which is not yet installed and he plans to change to a brick in
6 months or so.Â* I'll ask him to register today.
Ramy
Dan, 5J
Old March 8th 20, 10:58 PM posted to rec.aviation.soaring
George Haeh
The appropriate FlarmNet data file must also be installed to your display and/or flight computer.
PowerFLARM Portable does not handle FlarmNet files.
Old March 9th 20, 03:18 AM posted to rec.aviation.soaring
Ramy[_2_]
Not everyone is racing. The racing population is a small percentage of pilots. The rest of us enjoy soaring cross country without having to worry that god forbid someone is leeching. To the contrary.
Ramy
Flarmnet Karl Kunz[_2_] Soaring 40 March 7th 20 01:42 PM
FLARM/Flarmnet question Hartley Falbaum[_2_] Soaring 2 June 23rd 16 12:36 PM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
