Oudie gear warning?
Old April 1st 20, 08:20 PM posted to rec.aviation.soaring
Dennis Cavagnaro
Default Oudie gear warning?
Got it Thx
Mine is checked for landing gear
Now what exactly will happen if I forget my gear during a landing? Will I see a message or hear a sound?
DC
Old April 1st 20, 09:34 PM posted to rec.aviation.soaring
Scott Williams[_2_]
On Wednesday, April 1, 2020 at 2:20:17 PM UTC-5, Dennis Cavagnaro wrote:
Got it Thx
DC
while I have not flown since this update, the previous posts by others seem to indicate that if I get to an altitude of 660feet in close proximity to my launch gps location, the oudie will announce or have a popup window something like "check landing gear"
I suppose this may or may not be the case, maybe it compares altitude and ground elevation? be interesting to see how it works!
Scott
Old April 1st 20, 09:35 PM posted to rec.aviation.soaring
Scott Williams[_2_]
Got it Thx
DC
Scott
I'll try it out with condor.
Old April 1st 20, 11:12 PM posted to rec.aviation.soaring
NG[_2_]
On Tuesday, March 31, 2020 at 1:51:42 PM UTC-4, wrote:
Hey all - I just acquired an original Oudie and I have noticed a gear warning in the profile setup. Not mentioned in the manual and the previous 2 owners do not know about it. I have not noticed it trying to get my attention in the pattern either. I will ask Naviter next unless youze can fill me in.
Old April 6th 20, 03:06 PM posted to rec.aviation.soaring
I finally heard back from Naviter, they confirm it is visual only. Not worth the code! I don't think I will be making the Oudie part of my scan below pattern altitude.
Old April 6th 20, 04:53 PM posted to rec.aviation.soaring
MNLou
Hmmm - that brings up an interesting situation. I am definitely getting an audio warning in addition to the banner warning on the Oudie.
I've got a Flarm - S8 - Oudie set up. Perhaps the audio warning is coming from the S8? I was pretty sure it was coming from the Oudie but if Naviter says not so??????
Lou
Old April 6th 20, 04:58 PM posted to rec.aviation.soaring
Tony[_5_]
Weird because on mine, there is a chime i'm pretty sure and I think the lady says "Check Gear" along with the message on the screen...
Old April 6th 20, 05:43 PM posted to rec.aviation.soaring
SoaringXCellence
Depending on how you have configured the S8, it can give all kinds of verbal warnings. Even without a gear sensing switch it will remind you to check gear 5 minutes after you're airborne.
Old April 6th 20, 07:03 PM posted to rec.aviation.soaring
Well the guy at Naviter did not seem on top if the issue...is anyone getting an aural without other gadgets involved?
Old April 7th 20, 02:26 AM posted to rec.aviation.soaring
It's been far too long since I've flown but I was surprised to start getting an aural "check gear" on downwind, even when landing out at a nearby field, and know that there's also an indication on the Oudie although I didn't really look at it.
Chuck Werninger
Soaring Club of Houston
LS-4 "VL"
Cessna 172 gear warning Paul Kassel Owning 0 March 27th 17 04:29 PM
Gear Warning Gadget Guy Soaring 118 November 30th 05 10:43 PM
Gear Warning Gordon Schubert Soaring 11 November 22nd 05 03:27 AM
Gear Warning Gordon Schubert Soaring 0 November 18th 05 08:22 PM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 08:33 AM
