Thanks guys n thanks Roy. I enjoyed Reichmans book and did remember his use of the 15 as a standard for illustrating his points, thats part of my interest in the bird, all the numbers have been worked out lol.
Question: libelle vs 15, does either have a climb advantage? And in the run how does the 15 compare to the libelle below 70 and above 70k , anyone have knowledge? I can compare polars but thats not always real life. Dan |
On Sun, 05 Apr 2020 15:01:24 -0700, uneekcowgirl wrote:
Question: libelle vs 15, does either have a climb advantage? Pass - I've never flown my 201 with an ASW-15. And in the run how does the 15 compare to the libelle below 70 and above 70k , anyone have knowledge? I can compare polars but thats not always real life. Dan My (early, balsa winged) 201 is happy and not obviously throwing height away at 80 kts indicated, but its wings have full-span under surface zigzag turbulator strip fitted and that's supposed to improve high speed cruise performance. It was on the glider when I got her, so I have no unturbulated experience to compare it with. -- Martin | martin at Gregorie | gregorie dot org |
I had an ASW-15b for a few years when I was younger. Here are some things that I remember:
1) It rigged very easily. My trailer wasn't great, but the glider was still a joy to put together. 2) Pitch forces are light because of the all-flying tail, but you get used to it. 3) It seemed to do well in weak conditions. I don't think you can really go wrong with a Cirrus, Libelle, or ASW-15. Pick the Libelle if you really love how it looks. Avoid the Libelle if you have wide shoulders. Other than that, I'd recommend looking at all three and picking the one with the best trailer, gel coat, and instruments. |
Hi,
the 15 does well in weak conditions. In a faster glide, the Standard Cirrus is slightly better. ASW19 and LS1-f are significantly better at 150kph and above. The 15 easier gets damaged at outlandings due to the low elevator and the airbrakes below the wings. If you have the choice, go for a B. It has a larger rudder, simplifying aerotows on the CG hook, also improving the agility and control balance. The B has a larger main wheel and a higher MTOW. Many 15s have a rather low payload below 90kg. Christoph |
I have a 15 (s/n 15151) and a Pegasus with very little time in the Peg and 300 hours or so in the 15. I'm not into racing so can't really comment on how it compares to other gliders of that vintage performance-wise. I know at one time both it and the Cirrus had a 1.0 handicap.
It is very easy to rig. It has manual connections. If equipped with safety sleeves, they are simple to hook up and easy to test. Using safety pins was a bit harder. The all flying tail is a non-issue.The top and bottom air brakes are very effective. Some have an off-center CG release that can, apparently, be an issue in cross wind take-offs. Mine has what some call a "chin" release so no problems there. There is an AD concerning fungus on the balsa that, once completed, requires only a visual check at each annual. I can't imagine that there any that still have not had the initial AD completed. Other than the original glider that crashed that created the need for the AD, I've never heard of any other 15 having the problem. I'm not saying its never happened, just that I'm unaware of it. I bought the Pegasus because I wanted to step up in performance. It is also a great glider and is certainly in a different class than the 15. I intended to sell my 15 but could find no takers, presumably due to its low max pilot weight (185 lbs). (I'm also 6'1" and, with the seat back removed and a chute on, my head is probably about an inch from the canopy.) As I can't afford two gliders, the Peg is back on the market. Its on W&W for anyone interested. In my biased opinion, the ASW 15 is a great glider for the price. Easy to fly and rig. Excellent handling. |
Arcus - first impressions | Andreas Maurer | Soaring | 1 | July 7th 09 01:35 PM |
First impressions of flight | Mxsmanic | Piloting | 37 | April 10th 07 02:24 AM |
MSFS X impressions | Robert M. Gary | Piloting | 37 | January 8th 07 03:13 PM |
AFTER BURNER CLIMAX impressions | Air Raid | Simulators | 1 | August 30th 06 01:37 AM |
AvMap EKP-IV portable GPS - any impressions? | Neil Gould | Piloting | 16 | August 19th 04 09:10 PM |
