Canopy tinting
Old April 22nd 20, 06:08 AM posted to rec.aviation.soaring
2G
Default Canopy tinting
On Tuesday, April 21, 2020 at 2:52:09 AM UTC-7, wrote:
On Tuesday, April 21, 2020 at 12:50:20 AM UTC-4, 2G wrote:
On Monday, April 20, 2020 at 2:26:27 AM UTC-7, wrote:
On Monday, April 20, 2020 at 5:49:26 AM UTC+2, Paul wrote:
Question: Is it possible to tint a canopy like a car, for example, using automotive window tinting material? I know some canopies are tinted a bluish color, but what about a dark black tint?
Thanks,
It's poorly advertised but Mecaplex offers an IR-blocking tint which I've ordered after some hassle.
As a fraction of light blocked:
Colour / Visible / IR
Standard grey / 76% / 74%
IR blocking grey / 77% / 47%
Blue / 78% / 78%
Sunlight is about 45/55 visible/IR(?), so my napkin math suggests assuming 1000W/sqm:
(450 * 0.76) + (550 * 0.74) = 749W
(450 * 0.77) + (550 * 0.47) = 605W
- ~25% cooler than typical tinted for no loss in visibility.
I don't know what fraction of either is blocked by an untinted canopy in comparison? Approximately 0% or more?
You don't need an IR blocking tint as acrylic blocks UV all by itself:
Some UV, not all. Acrylic blocks UV-B, so you don't get a sunburn. But it still lets significant UV-A through, which can cause deeper skin damage. Best to cover exposed areas with opaque material.
UV-A is defined as wavelengths between 315 and 400nm. As can be seen from the transmission plots I provided, acrylic falls off steeply at 400nm. This blocks almost, but not, all UV-A.
Tom
Old April 22nd 20, 06:10 AM posted to rec.aviation.soaring
2G
On Tuesday, April 21, 2020 at 3:23:20 AM UTC-7, wrote:
You miss my point gbfwi. I said nothing about the UV protection characteristics of canopy materials. I was stating that the reason tinted canopies are sold on gliders is not to do with additional UV filtering. For that I always wear full length UV protecting clothing, hat and sun shade gloves + factor 50 when gliding.
That will help you on the ground when you are not in your glider (which IS a very good idea), but is totally unnecessary while flying.
Tom
Old April 22nd 20, 08:37 AM posted to rec.aviation.soaring
Well 2G, it would be rather inconvenient to take off the clothes I am happy with every time I get into the cockpit.
  #24
Old April 22nd 20, 11:32 PM posted to rec.aviation.soaring
2G
And WHY would you want to do that?
Canopy Ejection and Canopy Lanyard Casey[_2_] Soaring 6 April 12th 16 05:09 PM
1-35 Canopy [email protected] Soaring 14 April 30th 08 06:18 PM
Canopy tinting service Udo Soaring 18 December 23rd 06 01:05 AM
CANOPY TINTING Gordon Schubert Soaring 4 February 4th 05 09:35 PM
SGS 2-32 canopy? Gary Boggs Soaring 0 January 6th 04 11:21 PM
