https://en.wikipedia.org/wiki/British_Aerospace_146 The British Aerospace 146 (also BAe 146) is a short-haul and regional airliner that was manufactured in the United Kingdom by British Aerospace, later part of BAE Systems. Production ran from 1983 until 2002. Manufacture of an improved version known as the Avro RJ began in 1992. A further-improved version with new engines, the Avro RJX, was announced in 1997, but only two prototypes and one production aircraft were built before production ceased in 2001. With 387 aircraft produced, the Avro RJ/BAe 146 is the most successful British civil jet airliner programme. The BAe 146/Avro RJ is a high-wing cantilever monoplane with a T-tail. It has four turbofan engines mounted on pylons underneath the wings, and has retractable tricycle landing gear. The aircraft has very quiet operation, and has been marketed under the name Whisperjet. It sees wide usage at small, city-based airports such as London City Airport. In its primary role, it serves as a regional jet, short-haul airliner, or regional airliner, while examples of the type are also in use as private jets. The BAe 146/Avro RJ is in wide use with several European-based carriers such as CityJet. The largest operator of the type, Swiss Global Air Lines, retired its last RJ100 in August 2017. The BAe 146 was produced in -100, -200 and -300 models. The equivalent Avro RJ versions are designated RJ70, RJ85, and RJ100. The freight-carrying version carries the designation "QT" (Quiet Trader), and a convertible passenger-or-freight model is designated as "QC" (Quick Change). A "gravel kit" can be fitted to aircraft to enable operations from rough, unprepared airstrips. In August 1973, Hawker Siddeley launched a new 70-seat regional airliner project, the HS.146, to fill the gap between turboprop-powered airliners such as the Hawker Siddeley HS.748 and the Fokker F.27 and small jet airliners such as the BAC One-Eleven and Boeing 737. The chosen configuration had a high wing and a T-tail to give good short-field performance, while the aircraft was to be powered by four 6,500 lbf thrust Avco Lycoming ALF 502H turbofan engines. There were several reasons why a twin engine configuration was not chosen. Certainly, a major factor would have been that no manufacturer was producing a 13,000-lbf-thrust-class high-bypass ratio turbofan engine at the time. The programme was initially launched with backing from the UK government, which agreed to contribute 50% of the development costs in return for a share of the revenues from each aircraft sold. In October 1974, all work on the project was halted as a result of the world economic downturn resulting from the 1973 oil crisis. British Aerospace promoted the BAe 146 to airlines as a "feederliner" and short-haul regional airliner. The airframe of the aircraft and many other key areas were designed to be as simple as possible. The engines lack thrust reversers due to their perceived reduced effectiveness in anticipated conditions. Instead, the BAe 146 features a large airbrake with two petals below the tail rudder at the rear of the fuselage, which has the advantage of being usable during flight and allowing for steep descent rates if required. In addition, the aircraft has full-width wing spoilers, which are deployed immediately on landing. The aircraft proved to be useful on "high-density" regional and short-haul routes. In economy class, the BAe 146 can either be configured in a standard five-abreast layout or a high-density six-abreast layout, making it one of few regional jets that can use a six-abreast layout in economy class. Reportedly, the aircraft is profitable on most routes with only marginally more than half the seats occupied. The BAe 146 is also renowned for its relatively quiet operation, a positive feature that appealed to those operators that wanted to provide services to noise-sensitive airports within cities. The aircraft is one of only a few types that can be used on flights to London City Airport, which has a steep approach and short runway; for several years, the BAe 146 was the only conventional jet aircraft capable of flying from London City Airport. Role Airliner National origin United Kingdom Manufacturer British Aerospace BAE Systems Avro International First flight 3 September 1981 Introduction May 1983 Status In Service Primary users CityJet Airlink Mahan Air SkyJet Airlines Produced 1978–2001 Number built 387 (Avro RJ: 166; BAe 146: 221) Program cost £350 million Unit cost 146-200: £11 million (1981) The type was widely used for passenger services in Australia from the late 1980s until the early 2000s, where the aircraft was suited for long-distance, low-volume routes; 18 were in service with Ansett Australia in 1999. The BAe 146 was also operated by East-West, taking delivery of eight from 1990, until the company was absorbed into Ansett. Cobham Aviation Services Australia began operations under the Airlink brand on behalf of Australian Airlines (and later Qantas) in 1990 using the type until 2005. As of 2012, Cobham continue to operate 15 BAe 146 and Avro RJ variants for scheduled cargo and passenger charter operations, including the second production airframe, a -100 model converted to QT specification, which first flew in January 1982 as part of the testing and certification program. The initial customer for the BAe RJ85 series was Crossair, which took delivery of its first aircraft on 23 April 1993. Several major cargo operators have operated the type. As of 2012, the BAe 146 QT is the most numerous aircraft in TNT Airways's air freighter fleet. In 2012, the Royal Air Force (RAF) announced it would acquire the BAe 146M as an interim transport aircraft between the retirement of the Lockheed C-130 Hercules and the introduction of the larger Airbus A400M Atlas, to supplement its air transport activities in Afghanistan. In 2013, the RAF acquired two converted BAe146-200s, designated BAe146C Mk3, capable of carrying 10.6 tons of load, and fitted with a large 3.33- × 1.93-m side door. The RAF also operates the BAe146 CC Mk2 in No. 32 Squadron RAF. Specifications Crew 2 Seats 70–82 Length 26.19 m (85.9 ft) Height 8.61 m (28.2 ft) Max. Payload 8,612 kg (18,990 lb) Engines (4×) BAe 146 : Lycoming ALF 502R-5 Speed Mach 0.739 (426 kn; 789 km/h) Max, Mach 0.7 (404 kn; 747 km/h) cruise Ceiling 35,000 ft (11,000 m) Range 82 pax: 3,870 km (2,090 nmi) * |
| British Aerospace Hawk 200 pics 2 [2/5] - British Aerospace Hawk 200.jpg (1/1) | Miloch | Aviation Photos | 0 | September 4th 18 04:29 PM |
| British Aerospace Hawk 200 pics [6/8] - British Aerospace Hawk 200 5.jpg (1/1) | Miloch | Aviation Photos | 0 | September 4th 18 04:28 PM |
| British Aerospace Hawk 200 pics [5/8] - British Aerospace Hawk 200 4.jpg (1/1) | Miloch | Aviation Photos | 0 | September 4th 18 04:28 PM |
| British Aerospace Hawk 200 pics [4/8] - British Aerospace Hawk 200 3.jpg (1/1) | Miloch | Aviation Photos | 0 | September 4th 18 04:28 PM |
| British Aerospace Hawk 200 pics [3/8] - British Aerospace Hawk 200 2.jpg (1/1) | Miloch | Aviation Photos | 0 | September 4th 18 04:28 PM |
