Ham Radio In The Airplane
Old July 5th 03, 02:27 AM
Doug Carter
Default Ham Radio In The Airplane
97.101 says:
§97.101 General standards.
(a) In all respects not specifically covered by FCC Rules each amateur
station must be operated in accordance with good engineering and good
amateur practice.
(b) Each station licensee and each control operator must cooperate in
selecting transmitting channels and in making the most effective use of the
amateur service frequencies. No frequency will be assigned for the exclusive
use of any station.
I don't see any constraint regarding connection to anything so long as its
operated in 'accordance with good engineering and good amateur practice.'
Doug Carter WA5QGN Pitts S2-C
"Jim Weir" wrote in message
There was a question the other day about an amateur radio (or any other
two-way
radio, for that matter) aboard the airplane. At least for amateur radio
(part
97) I got an answer back from an old time FCC person who was in this
business
for a whole bunch of years. Names are omitted for reasons of privacy.
Herewith the exchange...my questions, his answers.
97.101(b) says that an amateur station aboard an aircraft must be
"...independent of all other radio equipment...".
Old July 5th 03, 03:09 AM
Cy Galley
Why not wire one ear cup for your aviation and the other cup for ham
operations? If there are no connections then you should be able to hear
both. Use a hand held mic for one or the other.
Cy Galley - Bellanca Champion Club
Newsletter Editor & EAA TC
www.bellanca-championclub.com
Actively supporting Aeroncas every day
Quarterly newsletters on time
Reasonable document reprints
1-518-731-6800
two-way
(part
business
I've been having some discussions about this, especially my PERSONAL
discussion because of what I do for a living (manufacture aircraft
electronic devices).
My interpretation of RADIO devices means that I can't run my 2-meter ham
rig
audio through a RADIO (transceiver) or use the RADIO audio to modulate
rig.
That is about the extent of the "separation". It's not a real
problem for most small aircraft where the aircraft (VHF) radio is AM
and the 2 meter rig is FM. Where it becomes a problem is when the
a/c is equipped with a HF rig and it gets tuned to the ham bands.
More than one ham-licensed air transport pilot has done that and
openly bragged that that's what is necessary to relieve the boredom
of flying a large plane over the ocean.
It does NOT preclude me from using my aircraft headset and microphone,
even
if that headset and microphone goes through an audio switching device
(audio
panel) to switch select between the aircraft RADIO and the ham rig.
That's how I see it as well.
As a matter of fact, it would seem to me dangerous to design a system
where
I would have to pull the headset plugs out of the aircraft radio and plug
them in to the ham rig. This, of course, prevents me from monitoring any
of
the aircraft radios while using the ham rig. Not good, especially in a
crowded environment where monitoring the aircraft radio is an item of
safety.
Agreed.
I guess the question really is where the aircraft RADIO equipment stops
and
the rest of the aircraft systems start. Battery? Audio?
The common sense definition of "the radio" would include the COMM
transceiver(s) and any NAVAID devices. Electrical and audio panels
should be excluded.
http://www.rst-engr.com
Old July 5th 03, 03:28 AM
H. Adam Stevens
When using a handheld I just connect an ear plug headset and wear it under
my normal headset.
As far as HF, I worked KJ5CB on 14.347 MHz from my mobile in Austin while he
was driving a Boeing over the Amazon.
HK3SA was aboard the Amazon Queen on the Amazon River and they even flashed
lights at each other.
Aeronautical mobiles check into the Maritime Mobile Net on 14.3 MHz
frequently.
I think the problem is connecting non-TSO'd radios to an aircraft's system,
not operating an aircraft HF radio on a ham frequency.
H.
N502TB, NQ5H
"Cy Galley" wrote in message
news:PrqNa.105458$R73.12132@sccrnsc04...
1-518-731-6800
two-way
(part
business
ham
rig
rig.
even
(audio
where
plug
any
of
safety.
Agreed.
and
should be excluded.
Old July 5th 03, 05:12 AM
Justin Case
Speaking on this subject, is there a conglomeration of hams that meet
at OSH? What about freqs for the HT?
On Fri, 04 Jul 2003 17:31:17 -0700, Jim Weir wrote:
There was a question the other day about an amateur radio (or any other two-way
radio, for that matter) aboard the airplane. At least for amateur radio (part
97) I got an answer back from an old time FCC person who was in this business
My interpretation of RADIO devices means that I can't run my 2-meter ham rig
audio through a RADIO (transceiver) or use the RADIO audio to modulate the
rig.
It does NOT preclude me from using my aircraft headset and microphone, even
if that headset and microphone goes through an audio switching device (audio
As a matter of fact, it would seem to me dangerous to design a system where
them in to the ham rig. This, of course, prevents me from monitoring any of
safety.
Agreed.
I guess the question really is where the aircraft RADIO equipment stops and
should be excluded.
Old July 5th 03, 08:34 AM
Roger Halstead
I think we have the same "take" in that I can mount it in the pane and
even run it through the audio panel.
I can't for the life of me imagine why some one would want to take the
audio from the aircraft rig to modulate the ham rig, or vice versa.
OTOH, I have worked both military and civilian flights on the HF bands
using both the military equipment (FB-111) and ham band equipment for
the HF aviation work...(non certified) but they were using it
transoceanic.
Roger Halstead (K8RI EN73 & ARRL Life Member)
www.rogerhalstead.com
N833R World's oldest Debonair? (S# CD-2)
Old July 5th 03, 09:02 AM
Paul Millner
system,
I wouldn't think so, since Part 91, not even the NavComs need be TSO'd.
Case in point... KX170B, not TSO'd; KX175, TSO'd (IIRC)
Paul
Old July 5th 03, 03:27 PM
H. Adam Stevens
good point
there are ham rigs wired in with field approval IIRC
probably depends on the FSDO
H
"Paul Millner" wrote in message
system,
Paul
Old July 5th 03, 04:34 PM
Jim Weir
146.52 simplex is used on the field. There aren't enuf of us back there to make
any sort of pileup. If you WANT to have a ragchew after meeting on .52, go to
..53 or .54 or...
If you want the repeater frequencies, offset, and all that good stuff, download
the Oshkosh Frequencies chart from www.rstengineering.com
Justin Case
-Speaking on this subject, is there a conglomeration of hams that meet
-at OSH? What about freqs for the HT?
Old July 5th 03, 11:15 PM
Barry S.
Jim, when you fly with a 2m hand held, what kind of range do you get
and is it incorporated into you audio panel?
__________________
Note: To reply, replace the word 'spam' embedded in return address with 'mail'.
Old July 6th 03, 12:53 AM
Justin Case
Thanks Jim, see you there.
.53 or .54 or...
Justin Case
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 January 1st 05 07:29 AM
What airplane would fill this mission? John B Aerobatics 23 January 5th 04 09:10 PM
Marine Radio using Aviation Antennae Jim Weir Home Built 13 August 12th 03 10:05 PM
