Contact Approach
Old February 11th 05, 04:41 AM
Stan Gosnell
"Steven P. McNicoll" wrote in
nk.net:
I guess the next question is, "reported to whom?".
To ATC.
No, to the pilot. ATC doesn't necessarily get weather reports, because
they're not the National Weather Service. We have weather observers in
lots of places, and their reports don't necessarily get into the system,
especially if we call up and ask for the weather at odd times.
If your FBO has a certified weather observer on staff ATC will have
that observation.
Not necessarily, and in some cases, not even likely. Weather is not
reported to ATC, it's reported to the NWS, if anyone. ATC isn't at the
front of the line. In fact, my home base has weather reporting via ASOS
and much of the time ATC is far behind on the weather. They don't even
know when it goes from VMC to IMC and vice versa unless we tell them.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
Old February 11th 05, 04:48 AM
Steven P. McNicoll
"Ron Rosenfeld" wrote in message
Steve,
What's your take on this situation?
There was an accredited weather observer on the ground at KEPM. KEPM
rarely in the past would report weather to Bangor Radio, but did not on
this particular day.
I contacted this observer on 122.8 and obtained the visibility from him.
I
then relayed this information to ATC and told them it was from an
accredited observer.
I was then cleared for a contact approach.
My take is there's no point in making an observation and not reporting it.
If an observation is made but not reported then the requirement for reported
ground visibility has not been satisfied.
Old February 11th 05, 04:53 AM
Steven P. McNicoll
"Stan Gosnell" wrote in message
You just tell him that you have the weather. I do this all the time,
flying approaches to slimeholes in the backwaters of south Louisiana,
using weather from company observers, under Part 135. They're certified,
and do make supplemental observations to the NWS, but mostly they just do
observations for us when needed. It's the same as any other weather
report, and the same as if you get it from a tower. The ATC specialist
doesn't care where the weather came from, or how you got it. All he
cares about is that you can get on the ground and out of his airspace.
Tell him you have the Podunk weather, want to fly the approach, and he'll
give you a clearance.
That's not good enough for a contact approach. The reported ground
visibility must be at least one mile for the controller to issue a clearance
for a contact approach. There's no minimum visibility required to issue
clearance for an IAP.
  #24
Old February 11th 05, 04:58 AM
Steven P. McNicoll
No, to the pilot.
No, to ATC. Really.
The subject is contact approaches. Where ATC does not get weather reports
contact approaches are not available.
That is unlikely.
  #25
Old February 11th 05, 05:10 AM
Stan Gosnell
nk.net:
reports contact approaches are not available.
That may well be. I'm prohibited from requesting or flying contact
approaches, so I've never done it, nor studied the requirements that
closely.
the front of the line. In fact, my home base has weather reporting
via ASOS and much of the time ATC is far behind on the weather. They
don't even know when it goes from VMC to IMC and vice versa unless we
tell them.
That is unlikely.
No, that's the everyday reality.
Regards,
Stan
  #26
Old February 11th 05, 11:18 AM
raphaël langumier
Yes,
Ground visibility should be at least 1 SM and the pilot have to request
the contact approach.
Raf
"Steven P. McNicoll" a écrit dans le message de
news: t...
"Stan Prevost" wrote in message
Can ATC clear an aircraft for a contact approach to an airport which
has
no weather reporting?
No, a contact approach requires a reported ground visibility of at least
one
mile.
  #27
Old February 11th 05, 11:40 AM
Steven P. McNicoll
That may well be.
It's a certainty.
You do not appear to be in a position to know the everyday reality.
  #28
Old February 11th 05, 12:28 PM
On Fri, 11 Feb 2005 04:48:05 GMT, "Steven P. McNicoll"
It was reported. The pilot was the conduit.
Where is it written that this is not allowed?
  #29
Old February 11th 05, 12:30 PM
Well, somewhere along the line ATC has to get the reported weather in
order to issue the clearance.
ink.net:
To ATC.
that observation.
  #30
Old February 11th 05, 12:32 PM
Thiw may be true of SIAP's, since ATC often doesn't know or care about
what the weather is when they clear you for an approach.
We are discussing contact approaches, however. It's a different
animal.
Regards,
Stan
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 03:54 AM
Contact approach question Paul Tomblin Instrument Flight Rules 114 January 31st 05 06:40 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
