DG303 elevator bolt retainer clip
Old May 15th 20, 12:32 AM posted to rec.aviation.soaring
Default DG303 elevator bolt retainer clip
Previous owner? You didn't rig before buying?
Old May 15th 20, 12:42 AM posted to rec.aviation.soaring
There’s a special tool that holds the spring clip out as you tighten the bolt. A socket wrench should do the same thing, anything that holds the clip away from the bolt will work. Look in the trailer, believe it is a 4 in one tool that looks like an +................long time since I owned a 300!
JJ
Old May 15th 20, 01:01 AM posted to rec.aviation.soaring
I’ve got the tool.
It does not appear the clip is in the correct position however, after the bolt is screwed in. It does not align with the groove in the bolt head nor Is it preventing It from backing out. The original post has a link to photos with my retainer clip’s position.
Old May 15th 20, 01:11 AM posted to rec.aviation.soaring
Ron Gleason
On Thursday, 14 May 2020 18:01:13 UTC-6, wrote:
I’ve got the tool.
Jason, been 10 years since I had a 303 but I believe that spring clip should lift up and swivel to fit in the groove
Ron Gleason
Old May 15th 20, 01:51 AM posted to rec.aviation.soaring
Not unusual for the clip to get bent way out of alignment, I used needle-nose pliers to put the clip in the groove, after securely tightening the bolt.
JJ
Old May 15th 20, 05:10 AM posted to rec.aviation.soaring
Larry Suter
JJ
On my DG-300 the wire slides in and out along an axis that's parallel to the slot in the bolt. Your pictures suggest yours has been bent about 90 degrees to that axis, in the horizontal plane, just where it comes out of your horizontal stabilizer. Suggest following JJ's needle-nose suggestion.
Larry
Old May 15th 20, 04:35 PM posted to rec.aviation.soaring
NMD
JJ
Larry
Thanks very much! This makes sense now. I wanted to confirm alignment before I started bending the wire around.
Grob 103 AD note for bolt, USA [email protected] Soaring 2 March 2nd 09 05:47 PM
Cobra trailer wingtip retainer dowel - lost detent pin Frank[_1_] Soaring 0 May 27th 08 06:43 PM
Grob wing retainer bearings Tim Soaring 3 September 3rd 06 02:55 PM
DG303 Acro Ron Gleason Soaring 8 April 12th 06 04:47 AM
Bolt torque Neal Fulco Home Built 1 October 16th 04 06:57 AM
