Fatal Towplane Accident 5-9-20
Old May 18th 20, 11:11 PM posted to rec.aviation.soaring
2G
Default Fatal Towplane Accident 5-9-20
On Monday, May 18, 2020 at 2:35:39 PM UTC-7, Nick Kennedy wrote:
After reading all the secondary type release options I think I'm with AS.
Either have a Tost Release or a inverted Schweitzer release that could very quickly be operated electrically from a switch on the yoke or control stick..
These kiting accidents happen very fast.
If the Tow pilot IMHO had a electric switch he could actuate by either a button on a switch to dump the rope this could help.
I would imagine it would be fairly easy to engineer a pulling electric solenoid that is attached to the existing release cable, sister-ed on to it. When the tow pilot decides hes had enough, touch the button or slide his hand to activate a switch and release the rope quickly.
Use the existing system your tug has now, just add to it. This system seems so easy maybe I could even build it in a day. Don't try and cut the rope, just release it, very quickly.
Good idea?
Nick
T
A big factor in an electric actuator is the force required to open the tow hook. It will be far more than normal, but how much? And how long of a pull? Solenoids are highly non-linear in their pulling force (it increases geometrically as the gap is reduced). I concluded that a linear actuator would be better. To speed it up just drive it with a higher voltage (it wouldn't have to run for very long). I would junk the Schweitzer hooks altogether and switch to a Tost hook.
Tom
  #162
Old May 19th 20, 12:07 AM posted to rec.aviation.soaring
Come to think of it, if one agrees with the energy loss via the tow rope being the main issue, one could have a very reliable mechanical solution.
Mount the hook on a shock-absorbed sled, sled slides back enough, the release is pulled. One might have to be able to tune the compression and spring reloading based on what you're towing, but that's a very reliable solution.
Not sure how many tow-pilots would realize what's happening fast enough.
  #163
Old May 19th 20, 08:27 PM posted to rec.aviation.soaring
It has been done in Germany during WWII with military gliders. It was called "Hubschlepp". It was tested with a DFS 230 transport glider and a Junkers Ju 87 B-1 as a towplane. The system was very stable, only one of the two pilots had to steer his plane, the other just followed. Climb rate was roughly double that of the normal tow: 5–7 m/s against 2–3 m/s. Service ceiling, autonomy and maximum speed increased also.
https://de.wikipedia.org/wiki/Flugze...epp#Hubschlepp (in German)
See also: Ernst Peter: Der Flugzeugschlepp von den Anfängen bis heute. Motorbuch Verlag Stuttgart, 1981.
  #164
Old May 19th 20, 09:18 PM posted to rec.aviation.soaring
kirk.stant
How about banning all sideways/aft opening canopies from gliders? An unlocked canopy is a non-event in my LS6 with it's forward hinged canopy. Grobs? Deathtraps!
Or, just ban all canopies, period. Open cockpits are much more relaxing, and there is one less thing to mess up prior to takeoff.
OR, we could switch to using helicopters to aerotow...just put a CG hook on the TOP of the glider, lift vertically to 3000', and cut'em loose. Yee Haw! With a Chinook you could even daisy-chain several gliders and take up the whole club at once - just make sure you release from the bottom up...
Seriously:
1. Replace ALL Schweizer tow hooks with TOST releases (or equivalent) with the release lever close to the throttle. This is a no-brainer.
2. DO NOT TOLERATE ANY out of position/out of view flying by ANY glider pilot. At a minimum, talk to them after a flight with an "incident"; worse case, hand them the rope as soon as they get out of position (within gliding range of the field, of course, if possible).
Kirk
66
  #165
Old May 23rd 20, 12:29 AM posted to rec.aviation.soaring
George Haeh
"How about banning all sideways/aft opening canopies from gliders? An unlocked canopy is a non-event in my LS6 with it's forward hinged canopy. Grobs? Deathtraps!"
The problem with a side opening canopy is the overwhelming temptation to save the club $6,000 by holding the canopy down. Unfortunately lack of a third hand can result in a glider write-off or worse. Left rudder can get you back a hand for operating the spoilers, but where is this taught?
With a rear opening canopy, it's gone and your only concern is making a survivable landing, with or without glasses.
Grobs are much less vulnerable to mislatching the canopy than L-33s as the housing to receive the pin is substantially thicker making the gap more obvious. L-33s need a feeler gauge to check if the canopy is actually closed.
  #166
Old June 1st 20, 09:41 PM posted to rec.aviation.soaring
Neal Alders
Howdy all, new here, only second post, and please forgive my bloviating, but this has always been a hot button issue for me. My experience is not as vast as some, but 32 years in aviation, nearly 14,000 hours and 19,000 take offs and landings in everything from Sailplanes, tow planes, single engine, multi-engine land and sea, turboprops, Helo's, and now "Heavy Iron".
I haven't flown sailplanes in, effectively, 2 decades. Did my "return" flight just yesterday.
Disclosure, I am a product of UH and Valley Soaring, with a standard operating procedure of Low Tow.
2 thoughts.
1. My "fear" of High Tow, as both a glider pilot AND as a Tow Pilot, has been a MAJOR factor in my failure to return to the sport sooner, and continues to be a significant deterrent of my potential return. (I feel the same way about Wheel Landings in tail draggers, I know how to high tow and wheel land, just not a fan.)
2. If we instilled the same safety enhancing procedures ("One level of safety")in the sport of Soaring as we do in other aspects of aviation, IE Part 121 or 135, I honestly feel high tow would have been essentially outlawed long ago. I encountered VERY similar attitudes in the skydiving industry where I was working as a chief pilot of a very large jump operation. Outright hostility towards change, even safety enhancing change, was unfortunately the normal attitude. It took my preaching to a group of 200+ skydivers over a PA system, to remind them that continued unsafe behavior would cause them to be nothing more than a huge 12 step meeting with really expensive jet fueled filled lawn ornaments sitting on the airport side of the fence. A drop-zone without its pilot is nothing, same goes for a glider operation without tow pilots.
As UH said early in this thread, over 70,000 essentially trouble free low tows at Valley Soaring over many decades, most with Schweizer tow hooks must say something. Low tow is the standard down in Oz, and apparently a few other places in Europe/Scandinavia according to the gentleman I flew with in the 2-33 yesterday. I honestly know more than a half dozen glider and tow pilots that have left the sport due to local clubs refusing low tow after leaving clubs that did for various reasons like job relocations.
I am convinced low tow is SAFER, more EFFICIENT, and I feel would prevent a vast majority of these types of tragedies. Just adding my opinion to the mix, as well as my condolences to those involved in this tragic accident.
Low tow costs NOTHING to try. When it is done properly, it is FAR easier on the glider pilot AND the tow pilot, and has the amazing side effect of being safer. We must not allow this discussion to diverge down the wrong path. Talking about reinventing the wheel and making wholesale, expensive changes to hardware will not work. When a consistent problem keeps popping up at the airline level, we institute carefully thought out and implemented procedural change first. Changing equipment is horrifyingly expensive, and very time consuming. Procedural changes do not take long. And it usually produces the anticipated result. In my opinion, for what ever it is worth, a simple change to how we do things might produce a significantly lower rate of problems. We did it in the jump flying community. Over the last 20 years ONE MAN, who I am honored to call my friend, created a website, disseminated accident data and proposed solutions to the skydiving industry as it pertained to jump flying. It produced a significant 50% REDUCTION in accidents, and his writings have become policy in over 20 nations around the world to be permitted to operate as a jump pilot. He did all this just by suggesting some new, more thorough, training methods and changing the attitudes of those involved. Even a little.
Change to low tow, make sure students and visiting pilots understand the importance of FLY THE PLANE FIRST. Keep the existing equipment properly maintained, maintain effective training methods and attitudes and make sure they all know open canopies, unlocked spoilers or whatever don't matter when low to the ground. Fly the damn plane first. Deal with the other garbage later.
This reminds me, remember watching R/C gliders do R/C Aero tow? Tow plane had the rope attached on top of the wing on or real close to the CG. The glider flew high tow. Why do you think this is? This is not practical on real aircraft.
Ask yourself, why do most operations here use high tow? Anyone know why? Cause I have no idea. Why do we switch to low tow for cross country tows? I remember hearing people flew high tow because they were afraid if the rope broke near the tow plane on low tow it would somehow fight a 60 mph headwind and wrap itself around the control surfaces. Even my 13 year old mind knew that sounded absolutely absurd. It made no sense as even at 13 I knew enough physics to know that was impossible. I never heard another reason for high tow in all my years.
Sorry for the rant. Condolences to everyone involved.
  #167
Old June 1st 20, 11:08 PM posted to rec.aviation.soaring
Bob Youngblood
2 thoughts.
Good point, and I do appreciate your candor. I was probably the guy that was towing you and as I said, it was a pleasure having someone back there that was as steady as you. I apologize for the extended wait, but things do stack up as you were witness to yesterday. The good news is that we are back in the swing of things and moving forward. Doing the number of tows during the last couple of days was encouraging during these challenging times.
Thanks for coming out and you could certainly lend a helping hand, hope you enjoyed the tow with the Yellow Gorilla. Bob
  #168
Old June 1st 20, 11:22 PM posted to rec.aviation.soaring
Neal Alders
Bob, you did tow me, and you are a gentleman as always. No worries on the wait, it was a wonderful day for me!
  #169
Old June 1st 20, 11:24 PM posted to rec.aviation.soaring
Hightime
I have been flying gliders for a long time and only enter low tow for training to test the students ability to stay in control during aerotow , what I don’t understand is how would low tow be safer . Do you take off and then immediately push down through the prop wash to the low tow position ? 300 AGL is a most critical time due to low level turbulence and height , is this the time to be pushing through propwash to low tow ?
  #170
Old June 1st 20, 11:32 PM posted to rec.aviation.soaring
Bob Youngblood
I was a pleasure towing a guy who had been out of the saddle for a while and Tommy and I both complimented you during the afternoon beer drinking session. Just spoke to my friend Carlos #11 in your group and told him to say hello sometime in the future. Bob
Towplane-Baron accident Jp Stewart Soaring 58 June 11th 18 10:03 PM
Fatal accident in Scotland Ian Soaring 51 September 6th 07 10:55 AM
Another fatal accident Mike the Strike Soaring 0 September 20th 06 11:50 PM
Fatal accident in Italy 2cernauta2 Soaring 1 April 4th 06 05:50 PM
Hawaii Fatal Accident Rocky Rotorcraft 0 July 25th 03 03:01 PM
