File from PowerMouse - IGC?
Old May 22nd 20, 08:17 PM posted to rec.aviation.soaring
Dave Springford
Default File from PowerMouse - IGC?
Does anyone have an IGC file from an IGC approved PowerMouse?
I am seeking approval for the non-IGC version as a Position Recorder from our NAC. My club put them in our K-21B's where they will do the occasional 5 hr and 1000 m height gain silver badge legs.
I am trying to ascertain how to identify from the IGC file whether an individual PowerMouse has the IGC upgrade or not.
So, if someone has an IGC approved PowerMouse, can you please either email an IGC file to me, or reply here with a link to where the file has been uploaded (OLC, dropbox,etc)
TIA,
Dave
dave "at" foxonecorp "dot" com
Old May 22nd 20, 10:16 PM posted to rec.aviation.soaring
Dan Daly[_2_]
TIA,
Dave
Hi Dave. From the IGC approval document (at http://www.ukiws.demon.co.uk/GFAC/ then select the IGC approvals link ):
"2. FIRMWARE. The internal firmware is a Flarm module that provides the GPS recorder function, creation of IGC files, after-flight validation of IGC file integrity using IGC Shell or related programs (see para 3.1), and other Flarm
features (see para 1.7.1). This approval is for Flarm firmware version 6.5 or later. Earlier firmware versions are not IGC approved and apply to units made before IGC-approval. The firmware version is listed in the header record of IGC files in the form:"HFRFWFirmwareVersion:FLARM6.51". This can be seen by using a text editor to view the start of the IGC file."
Old May 22nd 20, 10:38 PM posted to rec.aviation.soaring
Dave Springford
Thanks Dan,
The PowerMouse approval document gives me a pretty good idea as to how ascertain the difference, but I am still looking for an IGC file from an Approved PowerMouse to confirm my hypothesis as to how the approved and unapproved units are differentiated within the IGC files they produce.
Tim Newport-Peace[_6_]
occasional
email
TIA,
Dave
If you open the IGC file with a text editor (I use Wordpad) and examine the
first record, that will tell you if it is approved.
The first character will always be "A".
If the next character is "X" then it is not an approved model.
Otherwise the next three characters will be "FLA", for example:
AFLAxxx
where xxx is the serial number.
Or download http://www.newportpeace.co.uk/softwa...i_approved.exe and use
that.
Tim.
Old May 22nd 20, 10:43 PM posted to rec.aviation.soaring
TIA,
Dave
Does this apply to all FLARM devices or only the PowerMouse? In my Portable PowerFLARM the IGC approval has its own line in the header portion of the IGC file, separate from the firmware version.
Old May 22nd 20, 11:04 PM posted to rec.aviation.soaring
Dave Springford
@moshe: For this thread, I am concerned only with the PowerMouse by LX Nav, not the other flarm units.
Tim, thanks for the X indication - that helps clarify the differences.
I would still like to get a copy of a file from an approved PowerMouse to verify the differences for the Position Recorder Application .
PowerFLARM Core or LXNAV PowerMouse Installation in Towplane Paul Remde Soaring 1 October 2nd 19 04:58 PM
LXNAV PowerMouse - U.S. F.C.C. Approved Paul Remde Soaring 11 August 24th 19 05:18 PM
PowerMouse vs Power Flarm - Updates by March? hardware/software -ADS-R, TIS-B WaltWX[_2_] Soaring 14 March 27th 19 06:33 AM
IGC-approval for the LXNAV PowerMouse-IGC Flight Recorder Ian Strachan[_3_] Soaring 0 February 19th 18 11:48 AM
Assorted Militaria (read the Zero file) - File 35 of 37 - AG-Fighter__47.rar.vol0+1.PAR2 (2/2) Br'er Rabid[_2_] Aviation Photos 0 April 27th 09 01:34 AM
