Real-Time U.S. Composite Satellite Imagery: Large Animation
Old June 2nd 20, 06:29 PM posted to rec.aviation.soaring
Craig Funston[_3_]
Default Real-Time U.S. Composite Satellite Imagery: Large Animation
I don't know if anyone else is using this site, but it's nice to see the US weather patterns in a visual summary.
https://www.ssec.wisc.edu/data/us_comp/large/
Craig
JN
Old June 2nd 20, 07:26 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Craig Funston wrote on 6/2/2020 9:29 AM:
Craig
JN
I like this site because it offers CONUS down to state level views, with better
than 1km resolution, so I can see even small cu.
https://weather.cod.edu/satrad/?parm...rbar=undefined
Old June 2nd 20, 07:50 PM posted to rec.aviation.soaring
Kerry
Great point. Been using the last 2 GOES hi-res satellites since, I think, Walt Wx posted them. Some beta sites for those are still active and offer additional weather and navigational overlays.
Any cleaver techies out there that could find a way to stream this product into a glider at altitude? I looked into Stratus, Sirius and direct satellite (ADS-B?) but don't see they offer this.
Old June 2nd 20, 09:47 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Kerry wrote on 6/2/2020 10:50 AM:
I sometimes get my referenced high resolution satellite image website in the air
on my phone, but Verizon isn't always available, or isn't fast enough (though
texts might still work).
Old June 2nd 20, 11:53 PM posted to rec.aviation.soaring
matthew@skysight.io
You can already get the realtime GOES high-res satellite photo on an LX9000 (with the wifi module, tethered to your phone) via the SkySight integration.
Even if the signal is very poor, it will keep trying until it gets through. Don't put your phone in the side pocket against your carbon fuselage though, mount it somewhere clear of the canopy rail.
Old June 3rd 20, 02:33 AM posted to rec.aviation.soaring
phlyingals@gmail.com
Fine subscription product, but it also relies on the same cell phone reception which is, at best, iffy above ~4,000ft agl. One can buy small cell "booster" units that marginally improve reception. Ideally, you'd want a satellite phone or small sat receiver that can process the raw GOES data on board.. Unless someone knows that Stratus/Siriius already provides this capability. And, yes, I would pay a chunk of money to know if that cumulus street I'm in extends more than the couple miles I can see ahead. Wouldn't have to worry so much about firing up the turbo.
Old June 3rd 20, 08:41 AM posted to rec.aviation.soaring
matthew@skysight.io
On Wednesday, 3 June 2020 02:33:24 UTC+2, wrote:
Fine subscription product, but it also relies on the same cell phone reception which is, at best, iffy above ~4,000ft agl. One can buy small cell "booster" units that marginally improve reception. Ideally, you'd want a satellite phone or small sat receiver that can process the raw GOES data on board. Unless someone knows that Stratus/Siriius already provides this capability. And, yes, I would pay a chunk of money to know if that cumulus street I'm in extends more than the couple miles I can see ahead. Wouldn't have to worry so much about firing up the turbo.
Iffy is typically enough - really, try mounting it above the canopy rail and you'll see reception frequently enough to download a satellite image in almost all flying sites every half hour.
I've heard all manner of theories as to why it doesn't work in region X because the cell phone towers point down or there's too many cells etc etc, but the majority report it actually does work when they actually no longer keep their phone in the side pocket or only pop it out occasionally, see no signal then put it back.
In some regions I've had better results disabling 2G on my phone (4G/3G only).
Tested personally in Europe at FL200, in Namibia/South Africa/Minden at FL180, in Australia at FL160.
Some users have bought satellite wifi units but they're prohibitively expensive unfortunately.
I hope that in the future we'll see decent 4G antennas in the tail plumbed directly to instruments so that this isn't an issue any more.
A ground-based ADS-B solution would be great but will likely only ever be a regional setup.
Old June 4th 20, 10:14 PM posted to rec.aviation.soaring
5Z
Maybe a Starlink base station will be compact enough to carry in the glider...
https://www.starlink.com/
5Z
Old June 4th 20, 10:16 PM posted to rec.aviation.soaring
5Z
https://spacenews.com/spacex-plans-t...vices-in-2020/
5Z
Old June 12th 20, 05:41 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Hey Craig and Eric
Thanks for posting those links to those satellite images.
I've added both to my bookmarks and I really like them!
Nick
T
GOES-16 Site for Satellite Imagery and Animation- realearth.ssec.wisc.edu WaltWX[_2_] Soaring 3 July 31st 17 06:38 AM
Source for previous (24 hour) visible satellite imagery archerzulu@gmail.com Soaring 10 August 14th 15 08:32 PM
Satellite Imagery of Eastern US user Soaring 13 January 23rd 07 08:28 PM
Keyhole satellite imagery and GA Patrick Pohler Piloting 10 November 27th 04 11:03 PM
Real-time real world air traffic in flight sims Marty Ross Simulators 6 September 1st 03 05:13 AM
