Estimating Wind Speed with a GPS
Old June 3rd 20, 10:10 PM posted to rec.aviation.soaring
Default Estimating Wind Speed with a GPS
On Wednesday, April 26, 2000 at 9:00:00 PM UTC-10, Eric Greenwell wrote:
An alternative method I've used takes one circle. During one circle,
-note the maximum GPS ground speed
-note the minimum GPS ground speed
-wind speed = (max - min)/2
Eric Greenwell
Eric:
I use your approach as well. During the circle run, I focus on GPS ground speeds and approximate direction where the max or min ground speed was observed. I then fly the direction where I thought I had the minimum ground speed. This is my guess at the head wind direction. I then vary my heading left or right to hone in on a better indication of the actual wind direction (It has the lowest ground speed).
When heading out to land, as I approach the LZ area, I will vary my course to find the minimum ground speed direction. That direction is the true wind direction at that moment. If it varies significantly from previous info, then it is concerning. I then am looking much harder at all the wind indicators on the ground that I can find. Question is there an active thermal in the LZ area, or did the wind just shift? Either way you know more by checking.
Wind powered land speed record. [email protected] Soaring 1 March 31st 09 09:02 AM
Wind speed and direction bobcaldwell Soaring 3 December 11th 07 12:02 AM
ATC speed instructions, wind and altimeter indications Mxsmanic Piloting 27 October 25th 06 09:05 AM
Kestral 1000 Wind Speed Meter NEW IN BOX on eBay Cecil E. Chapman Products 0 November 24th 03 12:10 AM
Kestral 1000 Wind Speed Meter NEW IN BOX Cecil E. Chapman Products 0 November 7th 03 07:56 PM
