Commodious Rodent Entrance in Grob 103
Old June 19th 20, 10:52 AM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
The most simple effective mouse trap . Use antifreeze in winter.
Put one in your hangar.
https://www.youtube.com/watch?v=6SIlYiiCGLI
Old June 20th 20, 12:25 AM posted to rec.aviation.soaring
Shaun Wheeler
Default Commodious Rodent Entrance in Grob 103
On Saturday, June 13, 2020 at 9:28:05 PM UTC-5, George Haeh wrote:
Last year we cleaned out and restored our club G-103.
For rodent proofing we:
* stuffed part of a stainless steel pot scrubber around the brake hose where it comes out of the gear well
* made a magnetic cover for the CG hook, and
* a diaper to fit over the bottom of the the fin and rudder junction
* left Fresh Cab mouse repellent in the cockpit over the winter
Doing the annual after Covid19 delay, we found abundant mouse droppings in several areas along with one dead and one live field mouse caught by the vacuum.
I had another look inside the gear well and discovered an open tube about an inch in diameter below and towards the center from the brake hose.
Inside that tube supports the brake reservoir. Said tube now has a stainless scrubber stuffed into both ends.
Perhaps the tube is there for the retraction mechanism of the earlier model.
Mice will actually come after salt. Even if you eliminate foodstuffs from the cockpit the sweat in straps and belts is probably going to draw them in.
Old June 20th 20, 03:29 AM posted to rec.aviation.soaring
2G
They also want dry, sheltered places (particularly from predators) to make nests.
Old June 20th 20, 04:53 PM posted to rec.aviation.soaring
George Haeh
Once one mouse finds a way in, every other mouse in the vicinity can/will follow the scent trail.
Rodent proofing CG Hook George Haeh Soaring 14 March 7th 19 07:21 PM
Rodent Deterrent? rlovinggood Soaring 20 January 7th 08 05:22 AM
Commodious Sailplane? Jim[_6_] Soaring 19 October 11th 06 04:16 AM
Commodious Sailplane? James Hamilton Soaring 0 October 9th 06 09:37 AM
commodious sailplane Andy Davey Soaring 0 October 8th 06 08:02 PM
