Where's the "X" in the registration of a Ventus 2bx?
Old June 25th 20, 07:24 PM posted to rec.aviation.soaring
Stephen Coan
Default Where's the "X" in the registration of a Ventus 2bx?
The FAA Registry has a heading for V2bx as well as V2ax but indicates that none are in the U.S. What gives?
Old June 26th 20, 12:45 AM posted to rec.aviation.soaring
Frank Whiteley
https://registry.faa.gov/aircraftinq...TUS+2&PageNo=1
Imported, then exported? Who knows? I think it's more interesting that the Ventus 2A models are listed as having 2 seats. These types of errors in the FAA aircraft database download version make querying, for example, for a count of two seat gliders in the US challenging, as other MFR/MDL CODES for gliders are similarly in error with some two-seaters listed as having only one seat.
Kind of like finding an ASG29 on the registry.
YMMV
Old June 26th 20, 04:02 AM posted to rec.aviation.soaring
Tim Taylor
The Ventus 2 was certified under standard airworthiness. To change the official designation would likely trigger recertification.
All x's are registered as Ventus 2 a and b's. If you are seaching the database you just need to look for the later serial numbers for the x models.
Spare Ventus"A" gear doors (new) for sale [email protected] Soaring 0 September 8th 18 12:23 PM
What are the Pros and Cons of using the "ForeFlight Mobile EFB" appin Sailplanes as opposed to, say, "iGlide" or "navITer" ? jstodaro Soaring 4 March 26th 17 05:04 PM
JS1 Registration in the USA rianmonnahan Soaring 27 October 9th 16 02:04 AM
"VideO Madness" ( Soldiers...) "GoD Hates FAGS!!! (He sO righteOusly DoES)" Colonel Jake Naval Aviation 0 March 1st 10 12:14 AM
OLC Registration [email protected] Soaring 7 April 17th 07 04:10 PM
