Wood glider outdoor storage
Old July 8th 20, 07:39 PM posted to rec.aviation.soaring
Sky Surfer
Default Wood glider outdoor storage
Random question (kinda): Can an all-wood homebuilt glider be tied down outside year-round in a dry climate (e.g., Colorado) and be weather-protected by padded covers? The glider's plywood skin is covered by a layer of thin fiberglass, then painted. I guess I'm asking for actual experience or knowledge from anyone who has sucessfully done so. The glider's owner would be willing to periodically remove/dry-out/put back the covers after rain/snow/hail, etc. Being assembled and tied down is the only practical way this particular glider would be flown.
Old July 8th 20, 10:36 PM posted to rec.aviation.soaring
Scott Williams[_2_]
I've owned a wooded glider, a dry trailer would be a vast improvement over your proposal.
even an open sided tin roofed "T" hangar would be better.
Scott
Old July 8th 20, 11:40 PM posted to rec.aviation.soaring
Fly it as much as you can because it won’t last long
Old July 8th 20, 11:46 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
No
It will turn to junk very quickly
Nick
T
Old July 9th 20, 01:07 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
over your proposal.
Scott
Good suggestion. Eden Soaring, in Eden Valley on the foothills of the
western side of the Pennines, so not the driest part of the UK, keep a
pair of ASK-13's rigged under open-sided tin roofed T-hangars during the
soaring season. That setup looked pretty good last time I was there. Here
are the co-ordinates if you're interested: 41.590833, -93.620833
The most recent image, dated 19 July 2016, shows both T-hangars, anmd no
I don't know why its black&white when all the other images of the field
are in colour. Its a winch-only site with a guaranteed crosswind if the
hill is working.
Martin | martin at
Gregorie | gregorie dot org
Old July 9th 20, 09:29 AM posted to rec.aviation.soaring
Eric Munk
Long time ago saw the result of leaving a wooden glider outside in
the weather for considerable time, in covers. Water got into the
airbrakes box damaging spar longerons. Wing folded on take off.
Don’t leave a wooden glider outside in the weather please.
tied down
out=
weather-protected
layer of thin
experience or
know=
owner would
be=
rain/snow=
way this
p=
articular glider would be flown.=20
Old July 9th 20, 04:08 PM posted to rec.aviation.soaring
AS
tied down
out=
weather-protected
layer of thin
experience or
know=
owner would
be=
rain/snow=
way this
p=
I saw a Duster stored derigged inside a reasonably rain-tight hangar in PA for many years. Even under these seemingly benign conditions, the annual changes in temperature and humidity did a number on the plywood! It started to delaminate all over the place. I would have not stood under the wing had it been rigged let alone flown it no matter how desperate I needed a glider-fix!
Wooden gliders need to be taken care of by storing them in a dry and somewhat humidity controlled place.
Uli
'AS'
Old July 9th 20, 07:14 PM posted to rec.aviation.soaring
Sky Surfer
The opinions are unanimous about keeping a wood airframe dry. Admittedly it's tough to do that outside. Moisture can come from unobvious places, like the ground below the glider. I was hoping that someone had already demonstrated a solution, like installing a shallow platform on the ground (with a vapor barrier) and a removable rain/hail glider cover that leaves generous air gaps and cross ventilation around the glider. That, along with frequent inspections and being in a drier environment, may work. Does one want to be that pioneeringly "experimental", though. Thanks for everyone's inputs.
Old July 9th 20, 07:50 PM posted to rec.aviation.soaring
AS
Have you looked into the 'Ensign Sailplane Hangars'?
http://ensignhangars.com/15meter.html
Uli
'AS'
Old July 9th 20, 08:10 PM posted to rec.aviation.soaring
Sky Surfer
I didn't know its brand name but am aware of that hangar type. So far as I know, permanent structures aren't allowed at the intended location, judging by their complete absence.
Winter glider storage? soartech[_2_] Soaring 10 November 14th 11 07:49 PM
Preparing glider for storage Ben C Soaring 6 September 27th 11 02:13 AM
tube and fabric and outdoor storage Robert Loer Home Built 23 June 2nd 08 10:20 PM
wood in aircraft manufacturing, was First Glider stephanevdv Soaring 2 October 3rd 04 08:41 PM
Wood glider plans? Scott Soaring 4 January 18th 04 05:04 PM
