COBRA Anti-Sway Coupler
Old September 3rd 20, 07:00 PM posted to rec.aviation.soaring
Default COBRA Anti-Sway Coupler
Anybody have experience in using this? Would it help towing a COBRA trailer with a small car?
Old September 3rd 20, 07:34 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Define 'small car'. Cobra and Avionic trailers are like a rock behind my VW Golf TDI Wagon (relatively small car).
Old September 3rd 20, 08:40 PM posted to rec.aviation.soaring
Small car as in a 2015 VW GTI
Old September 4th 20, 12:39 AM posted to rec.aviation.soaring
I've installed three or four of these on Cobra trailers. Very well made and nicely designed. I put them on both single place and two seat glider trailers. They are pretty effective at controlling sway, even though the customers all tow with full-size pickups or SUVs. It definitely helps when towing with a short wheelbase vehicle.
I can't say how effective they are with something like a VW Golf, (but I consider that to be too small to tow a glider anyway. Maybe the wagon, with the longer wheelbase will work better.) I know they tow with tiny vehicles in Europe, but the glider trailers all have an 80 kph limit over there. Here in the US, 75 mph freeway speeds, crosswinds and passing eighteen wheelers are going to make towing a pretty "sporty" adventure. Keep an eye on the rear view mirror. If the trailer changes lanes, try to stay in front of it ;-)
You do have to use an actual 50 mm ball. A two inch ball is too big for the clamping action and 1 7/8" is too small. Remember that it's unlikely that anyone else will be able to tow your trailer unless they also have a 50 mm ball. Order an un-plated (stainless steel) ball if possible. Chrome plating has a tendency to start flaking off under the clamping loads while turning.. Lubrication is NOT permitted, as it negates the clamping friction that controls sway. Another issue is making sure the ball CANNOT turn and loosen the nut! No matter how much torque you put on the nut, it can still get loose. In Europe, the ball must be welded to the hitch plate. I usually machined a flat spot on the base of the ball just above the threaded shank and welded a piece of steel bar stock to the hitch plate.
Hope this helps.
Old September 4th 20, 01:43 AM posted to rec.aviation.soaring
2G
You do have to use an actual 50 mm ball. A two inch ball is too big for the clamping action and 1 7/8" is too small. Remember that it's unlikely that anyone else will be able to tow your trailer unless they also have a 50 mm ball. Order an un-plated (stainless steel) ball if possible. Chrome plating has a tendency to start flaking off under the clamping loads while turning. Lubrication is NOT permitted, as it negates the clamping friction that controls sway. Another issue is making sure the ball CANNOT turn and loosen the nut! No matter how much torque you put on the nut, it can still get loose. In Europe, the ball must be welded to the hitch plate. I usually machined a flat spot on the base of the ball just above the threaded shank and welded a piece of steel bar stock to the hitch plate.
Hope this helps.
80 kph is about 50 mph. Do that on Nevada's 80 mph freeways and they will be scraping you off some 18-wheeler's grill guard.
Tom
Old September 4th 20, 02:12 AM posted to rec.aviation.soaring
Andrzej Kobus
Hope this helps.
Mark, very informative, great post.
Old September 4th 20, 02:19 AM posted to rec.aviation.soaring
AS
Hope this helps.
Tom
Most modern trailers are exempt from the 80 km/h limitation and are allowed to go 100 km/h. Still not the speed some 18-wheelers do here but a big improvement for the German Autobahn.
Uli
'AS'
Old September 4th 20, 05:45 AM posted to rec.aviation.soaring
2G
I can't say how effective they are with something like a VW Golf, (but I consider that to be too small to tow a glider anyway. Maybe the wagon, with the longer wheelbase will work better.) I know they tow with tiny vehicles in Europe, but the glider trailers all have an 80 kph limit over there.. Here in the US, 75 mph freeway speeds, crosswinds and passing eighteen wheelers are going to make towing a pretty "sporty" adventure. Keep an eye on the rear view mirror. If the trailer changes lanes, try to stay in front of it ;-)
Hope this helps.
Tom
Uli
'AS'
100 kph is 62 mph - pretty slow by US standards (but not California which has a 55 mph speed limit while towing that nobody obeys).
Tom
Old September 4th 20, 04:43 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Hope this helps.
Tom
Uli
'AS'
Tom
I have lived in California for 35 years. I am unaware of this "I can't drive 55" while towing law/suggestion.
Old September 4th 20, 04:46 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
For those that may not be familiar with the "Cobra" anti-sway coupler I believe that this thread is about the coupler manufactured by Al-Ko - https://wingsandwheels.com/cobra-anti-sway.html.
Al-Ko makes most (all?) of the "trailering" components for your Cobra trailer, tongue, surge brake, coupler, jockey wheel, axle assembly, brakes, cables, etc, etc. Primo stuff! I don't believe that Al-Ko has anything to do with the lights and wiring.
Hope this helps.
Thanks, John OHM Ω
trailer sway mitigation TSM princiar[_2_] Soaring 67 December 26th 19 05:14 PM
AL-KO Cobra Trailer Coupler Keyhole Slot? OHM Ω http://aviation.derosaweb.net Soaring 8 October 23rd 17 10:59 PM
Dual axle sway glider[_2_] Soaring 7 March 2nd 10 04:36 AM
GS antenna coupler [email protected] Home Built 3 July 19th 05 09:40 AM
trailer sway [email protected] Soaring 14 June 19th 05 09:02 AM
