Powersonic "Smart Battery" tested
Old September 9th 20, 05:15 AM posted to rec.aviation.soaring
jfitch
Default Powersonic "Smart Battery" tested
It seems like a nice concept and I was recommending others try so I thought I should too.
https://www.power-sonic.com/batterie...etooth-series/
I bought the 12120 which is 12.5AH to replace my StarkPower 12AH (which after 6 years use still tests at 11.9 AH). The Powersonic is available in the typical glider sizes. You can find them at almost any price, I purchased the 12120 at Battery Web for $106. Could be had elsewhere for over $400. So shop.
What is "smart" about it? It has a BMS with shunt and Bluetooth radio, a free app for iPhone or Android gives you some basic info: voltage, current, and State Of Charge. Each battery has a unique address and the app will let you access several so multiple battery installs are possible.
I tested it though a couple of cycles with the Western Radio battery tester and some lab equipment. The voltage and current reported by the app were accurate (both reported in tenths). The SOC (reported as a percentage of capacity) was also accurate compared to actual AH drawn or delivered from/to the battery. This SOC is not a guess from voltage, but a real measurement from Coulomb counting. The AH capacity was at least as claimed (my battery ran 501 minutes at 1.5A draw, terminated at 11.5V). I flew a few days with it as well.
Why would you want this? They are no more expensive than others (perhaps less). With a couple of clicks on your phone you can determine the SOC. Also current draw, which can be useful for in situ diagnostics. One day I flew, I noticed that the voltage (reported on other instruments) was low, brought up the app on my phone and confirmed that I had taken off with it at 54% SOC - due to an operator error in charging overnight. But I at least knew I could fly the rest of the day, guessed what I'd done wrong, etc. More information is always better than less. It would be even better with a more sophisticated app, like Victron has for there stuff, but it is interesting as it is.
Old September 9th 20, 08:43 AM posted to rec.aviation.soaring
krasw
This is just fantastic idea. What I would like to have is a bluetooth/processor chip unit that you mount on any battery (SLA, LFP, whatever), and then monitor all your batteries status via app. There is no reason to built it inside battery. Integrate fuse holder, quality connector and you have everything.
Old September 9th 20, 01:30 PM posted to rec.aviation.soaring
I've been flying with the Powersonic PSL-BTL-1290 Iron Phosphate battery for about 6 months now. Same size as a 9 AHr Lead Acid battery so it fits in a Dittel battery box. It's rated at 9 AHr but tested on a Western Radio battery tester it achieves 10.4 Ahr (which is what the battery is reporting.) I especially like that it can measure and report discharge rate so you can anticipate run time. You can give each battery a unique name so that when using the app, you can select your battery from the others on the line. I've set 2 of our club gliders up with these batteries and a number of club members are beginning to use them. The battery uses a TI Bluetooth system (as determined by the MAC address) and likely a TI Battery Management Unit. As reported it the measurement system seems to be quite accurate.
Danny Brotto
LS-8/18 "P6"
Old September 9th 20, 06:42 PM posted to rec.aviation.soaring
jfitch
There are advantages to having it in the battery: it can report SOC per battery, the BMS is already there doing the measurements, and the cost is essentially free. However there is a device which does exactly what you want:
https://www.thornwave.com/collection...dc-power-meter
I also have one of these. One drawback is it must be powered to retain the history, so if you remove the battery from your glider you lose that history. Another advantage of having it in the battery. They are claiming to fix this in a future firmware release.
Old September 10th 20, 12:37 AM posted to rec.aviation.soaring
I wonder how much of a current draw the bluetooth feature is.
Old September 10th 20, 01:56 AM posted to rec.aviation.soaring
Probably very little. If you turn on Bluetooth in your phone, do you notice much of a reduction in the battery life? And this is a much larger battery.
But yeah the only advantage of having this feature, to my mind, is the (potential) ability to monitor the individual cells within the battery. Other than that, I use a charger that tells me how much charge (amp-hours) go into the battery, and it should correspond to how long I used it in the glider.. And my current 12 amp-hour LiFePO4 battery has so much capacity relative to my avionics' needs that even if I forgot to charge it since the last flight it would still easily last for the current flight. Your situation may differ, especially if you have a transponder.
Old September 10th 20, 05:48 AM posted to rec.aviation.soaring
The bluetooth feature is a gimmick. What really makes these attractive is that they are about 1/2 the price of equivalent the K2 battery!
Old September 10th 20, 12:08 PM posted to rec.aviation.soaring
What charger do you use??
Thanks
Kevin
92
Old September 10th 20, 12:45 PM posted to rec.aviation.soaring
The Bluetooth feature in the battery is BLE (Bluetooth Low Energy) and works by sending out small packets of data every few seconds. The infrequency of these transmission results in a very low overall current drain, probably on the order of 10 micro amps.
The phone app "listens" for these pings and can make a connection to the battery. While that connection is held, the current consumption typically goes up to the 10 milliamp range. These connections happen when the user uses the app to check the battery status. Eventually the connection is broken and the current consumption reverts to the 10 micro amps.
When the app is active on the phone, it has to constantly scan (listen) for transmitted packets so the Bluetooth is on and consuming energy from the phone battery. So yes, the phone battery is affected when the app is running.. After the app goes into the background the phone operating system typically suspends the BLE scanning so the current consumption due to the scanning goes away.
Danny Brotto
Old September 10th 20, 02:32 PM posted to rec.aviation.soaring
Thanks
Kevin
92
Imax B6. There are various versions, you can find one on ebay for $30 or so. It is a very versatile device, can handle batteries of various chemistries, test discharge capacity, etc. Thanks T8 for the tip.
Battery Charger for PowerSonic SLA/AGM batteries John Foster Soaring 9 May 23rd 20 02:52 AM
Wellington bombers being tested after returning from the raid on Heligoland in 1939 - Wellington bombers being tested.jpg Miloch Aviation Photos 0 August 7th 18 03:06 AM
Werker SLA batteries? (... better than PowerSonic?) 2NO Soaring 29 May 13th 16 03:46 PM
Interesting behavior from PowerSonic battery Steve Leonard[_2_] Soaring 14 May 24th 13 05:38 PM
SMART-1 Mission robert arndt Military Aviation 0 September 28th 03 05:05 AM
