https://en.wikipedia.org/wiki/MBB/Kawasaki_BK_117
The MBB/Kawasaki BK 117 is a twin-engined medium utility–transport helicopter. It was jointly developed and manufactured by Messerschmitt-Bölkow-Blohm (MBB) of Germany and Kawasaki of Japan. MBB was later purchased by Daimler-Benz and eventually became a part of Eurocopter, which was later rebranded as Airbus Helicopters. On 25 February 1977, MBB and Kawasaki signed a cooperative agreement to abandon their independent efforts to design twin-engined general purpose helicopters in favour of a collaborative venture to development of a new rotorcraft for that role. While the programme's costs were shared equally, the workshare was divided into certain areas of the design. MBB utilised their expertise with the rigid rotor system used on the earlier Bo 105 to develop the majority of the dynamic systems and flight controls, while Kawasaki focused on the airframe, structural elements, and various other components. On 13 June 1979, MBB's flying prototype conducted its maiden flight at Ottobrunn, Bavaria, Germany; months later, it was followed by the Kawasaki prototype at Gifu, Chubu region, Japan on 10 August 1979. Each company established their own final assembly line, producing the BK 117 for their respective regions. The BK 117 has proven to be popular for passenger services and VIP-transport, the cabin can be outfitted with various seating configurations, seating between seven and ten passengers. It is also used for a diverse range of operations, such as aerial crane and sling work, law enforcement, and military transport, and is exceptional as an air ambulance and search and rescue platform. During the 1990s, due to its popularity, a refined derivative, initially marketed as the BK 117 C-2 before being rebranded as the EC 145 and later as the H145, was developed from the BK 117 C-1 version; this improved version of the rotorcraft has since succeeded the original BK 117 in production. Design The MBB/Kawasaki BK 117 is a twin-engined medium utility–transport helicopter. It possessed several attributes that lend itself to performing many different roles, such as twin-engine redundancy, sizable clamshell-shaped rear-facing double doors, and a relatively spacious cabin; one mission to which it was deemed to be particularly suitable was the emergency medical services (EMS). The airframe is composed of rivetted metal, making minimal use of composite materials, and machined to a high standard; in order to free up internal space, both the engines and transmission are positioned above the main cabin. Considerable efforts were made to reduce the weight of the aircraft were possible albeit without compromising the aircraft's structural integrity. The cabin could be outfitted with various interiors in order to suit its purpose, or to incorporate greater comfort levels, which included measures to dampen both noise and vibration. Early versions of the BK 117 is powered by a pair of Lycoming LTS101 turboshaft engines, rated to generate 550 shp at takeoff with considerable reserve power to guard against a single engine failure. While each engine possesses sufficient power to maintain flight and even takeoff in the event of a single engine being rendered inoperable, the type also has favourable autorotation capabilities. In order to extend their operational lifespan and increase their reliability, MBB tuned the engines to operate at lower-than-standard revolutions per minute (RPM). The engines are regulated using a specialised control system which smoothly and evenly regulate RPM and torque between both engines, even during vigorous manoeuvers. Power management has been greatly eased via the addition of an automatic engine-governor system, allowing pilots to simply monitor the torque and engine temperature gauges. The aircraft can be suitably equipped for flight under instrument flight rules (IFR) as well as for single-pilot operations. Role Utility/transport National origin Germany/Japan Manufacturer Messerschmitt-Bölkow-Blohm (MBB)/Kawasaki Heavy Industries First flight 13 June 1979 Introduction 9 December 1982 Status in production, in active service Primary users DRF ADAC Produced 1979–present Number built 443 Developed from MBB Bo 105 Developed into Eurocopter EC145 Operational history (see "Operators") A single BK 117 A-3 (c/n 7106) was leased by the Canadian Forces Air Command for a test program and designated as the CH-143. When the program was over, the aircraft was returned to MBB Canada. A BK117 helicopter contracted by the New South Wales Rural Fire Service to fight fires crashed on 17 August 2018, the pilot died in the crash. Specifications (BK 117 B-2) General characteristics Crew: 1 Capacity: up to 10 passengers Length: 9.91 m (32 ft 6 in) (fuselage length) Height: 3.85 m (12 ft 8 in) (rotors turning) Empty weight: 1,727 kg (3,807 lb) Max takeoff weight: 3,350 kg (7,385 lb) Fuel capacity: 697 L (183 US Gallons, 153 Imp Gallons) internal fuel Powerplant: 2 × Textron Lycoming LTS 101-750B-1 turboshaft, 442 kW (593 hp) each Main rotor diameter: 11.00 m (36 ft 1 in) Main rotor area: 95.03 m2 (1,022.9 sq ft) Performance Maximum speed: 250 km/h (160 mph, 130 kn) at sea level Never exceed speed: 278 km/h (173 mph, 150 kn) Range: 541 km (336 mi, 292 nmi) Service ceiling: 4,575 m (15,010 ft) (max certified altitude) Hover Ceiling: 3,565 m (11,700 ft) (in ground effect) Rate of climb: 11.00 m/s (2,165 ft/min) * |
Kawasaki Ki-61 pics 2 [4/7] - Kawasaki-Ki-61-Hien-allied-code-name-Tony-14.jpg (1/1) | Miloch | Aviation Photos | 0 | November 13th 19 03:02 PM |
Kawasaki Ki-48 pics [3/8] - KAWASAKI Ki-48 LILY Japanese Army Air Force Bomber.jpg (1/1) | Miloch | Aviation Photos | 0 | September 15th 19 03:24 PM |
Kawasaki Ki-100 pics 2 [9/9] - the-cockpit-of-kawasaki-ki-100-type-5-imperial-japanese-army-fighter-AE9NNM.jpg (1/1) | Miloch | Aviation Photos | 0 | March 13th 18 12:24 PM |
Kawasaki Ki-100 pics 2 [8/9] - the-cockpit-of-kawasaki-ki-100-type-5-imperial-japanese-army-fighter-AE9NMG.jpg (1/1) | Miloch | Aviation Photos | 0 | March 13th 18 12:24 PM |
Kawasaki Ki-100 pics 2 [7/9] - the-cockpit-of-kawasaki-ki-100-type-5-imperial-japanese-army-fighter-AE9NKP.jpg (1/1) | Miloch | Aviation Photos | 0 | March 13th 18 12:24 PM |
