https://en.wikipedia.org/wiki/Sikorsky_S-97_Raider
The Sikorsky S-97 Raider is a high-speed scout and attack compound helicopter based on the Advancing Blade Concept (ABC) with a coaxial rotor system under development by Sikorsky Aircraft. Sikorsky planned to offer it for the United States Army's Armed Aerial Scout program, along with other possible uses. The S-97 made its maiden flight on 22 May 2015. Background Sikorsky's earliest attempt at a fast compound helicopter with stiff coaxial rotors was the Sikorsky S-69 (XH-59A) flown in the 1970s. Its top speed was over 260 knots but its excessive fuel consumption, vibration and complexity requiring the full-time attention of two pilots led to the program's cancellation. These problems were largely solved on another attempt by the Sikorsky X2 technology demonstrator in 2010. First proposed in response to a Request for Information for the Armed Aerial Scout (AAS) program in March 2010, the S-97 was formally launched on 20 October 2010. It was intended as a contender for a United States Army's requirement to replace the Bell OH-58D Kiowa Warrior. Other military roles are possible, the U.S. Special Operations Command having expressed interest in the S-97 as a replacement for the MH-6 Little Bird, and the possibility of adapting it for civilian applications also exists. Design The S-97 design includes variable speed rigid coaxial main rotors and a variable-pitch pusher propeller, making the S-97 a compound helicopter. Like the X2, it has fly-by-wire control and dynamic anti-vibration actuators to cancel out shaking. The main rotors have hingeless hubs and stiff blades, to improve low-speed handling and efficiency of hover. At high speeds, the close spacing of the hubs reduces drag. The stiff blades allow each rotor to have low lift on the retreating side of its rotor disk (reducing drag), whereas each rotor on a conventional coaxial rotor with "floppy" blades needs nearly equal lift distribution. The propeller relieves the rotor of propulsion, further reducing drag. Maneuverability is improved compared with earlier helicopters because of the ability to tilt the coaxial rotors together or tilt each one differently, and because of the variable pitch propulsor and active elevons. At low speed the S-97 maneuvers by differential torque of the upper and lower rotor, at high speed it uses rudders. The S-97 will be capable of carrying up to six passengers, in addition to a flight crew of two in a side-by-side cockpit. However, the production S-97 is projected to be capable of flying with either one or two pilots, or autonomously. Space for a targeting sensor has been reserved, however it will not be installed in the prototype aircraft. Based on the technology from the Sikorsky X2 demonstrator, the prototype S-97s will be powered by a General Electric YT706 turboshaft (the same engine used on the MH-60M Black Hawk). A more powerful engine, developed under the Improved Turbine Engine Program, is expected to become available. Compared to the OH-58D Kiowa, the S-97 has significantly increased performance goals, such as cruising speeds upwards of 200 knots while carrying weapons, turning at three times the force of gravity at 220kt, and a high hover efficiency (Figure of merit). Sikorsky also aims for an operating cost of $1,400 per flight hour. Role Reconnaissance and attack compound helicopter National origin United States Manufacturer Sikorsky Aircraft First flight 22 May 2015 Status Under development Number built 3 Program cost US$200 million Unit cost US$15 million, projected Developed from Sikorsky X2 Developed into Sikorsky Raider X Operational history The first flight of the S-97 occurred on 22 May 2015. It flew for 1 hour instead of the planned 30 minutes, completing three takeoffs and landings; forward, rearward and sideward. For this initial flight, the Raider was flown with its triplex fly-by-wire flight control system in backup degraded mode so as to focus on basic airworthiness in the low-speed regime. This begins a year-long flight test program of about 100 flight-hours to expand the flight envelope to meet Sikorsky's key targets of 220-knot cruise speed carrying weapons, hover at 6,000 feet on a 95F day and 3g maneuverability at speed. Toward the end of Phase 1 testing, software will be upgraded to Block 2, bringing in the propulsor and articulating tail to increase speed and enable the full flight envelope. The second prototype (P2) was displayed to the public in October 2015. After two flight hours and a few months of testbench validation of the propulsion drivetrain, P1 is scheduled for higher speed some time in 2016. On 3 August 2017, an S-97 prototype suffered what Sikorsky described as a hard-landing at their flight test facility in West Palm Beach, Florida; both airline transport pilots received minor injuries. The NTSB factual report on the incident stated that the helicopter lifted into a low hover and immediately experienced excessive roll oscillations which lead to intermeshing of the counter-rotating coaxial rotor system, and a hard landing. Damage to the helicopter included collapsed landing gear, structural cabin damage, and dynamic component damage, including rotor blade tip separation of all rotor blades. Video of the accident sequence showed aircraft roll oscillations exceeding 60–degree angle of bank during the course of 5 seconds, during which the upper and lower rotors collided at the 1 o'clock position. On 25 June 2019, the S-97 returned to flight testing and reached a speed of 190 knots. Specifications General characteristics Crew: 0-2 pilots Capacity: 6 troops Length: 35 ft (11 m) Gross weight: 8,945 lb (4,057 kg) Max takeoff weight: 11,000 lb (4,990 kg) Powerplant: 1 × General Electric YT706 , 2,600 shp (1,900 kW) Main rotor diameter: 1 (2 coaxial)× 34 ft (10 m) Propellers: 6-bladed variable-pitch, clutchable pusher propeller, 7 ft (2.1 m) diameter Performance Cruise speed: 250 mph (410 km/h, 220 kn) (with external weapons) Never exceed speed: 280 mph (440 km/h, 240 kn) Range: 350 mi (570 km, 310 nmi) Endurance: 2hr40min Service ceiling: 10,000 ft (3,000 m) at 95 °F (35 °C) Armament Guns: .50 cal gun w/500 rounds Rockets: 7-shot rocket pod(s) * |
| Thread Tools | |
| Display Modes | |
| Northrop YC-125 Raider pics 3 [5/5] - YC-125-Raider 3v.gif (1/1) | Miloch | Aviation Photos | 0 | December 16th 19 03:31 PM |
| Northrop YC-125 Raider pics 2 [2/7] - Northrop_YC-125C Sea Raider.jpg (1/1) | Miloch | Aviation Photos | 0 | December 16th 19 03:26 PM |
| Northrop YC-125 Raider pics [7/7] - Northrop_YC-125 Raider.jpg (1/1) | Miloch | Aviation Photos | 0 | December 16th 19 03:24 PM |
| Northrop YC-125 Raider pics 2 [07/10] - YC-125 Raider on the ice near Kenora Water Aerodrome 1950.JPG (1/1) | Miloch | Aviation Photos | 0 | October 22nd 17 04:37 PM |
| Northrop YC-125 Raider pics 2 [06/10] - U.S. Air Force Northrop YC-125 Raider at Kenora Water Aerodrome (CJM9) in 1950 2.jpg (1/1) | Miloch | Aviation Photos | 0 | October 22nd 17 04:37 PM |
