Engine bay fire detection with video camera
Old October 10th 20, 06:54 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Engine bay fire detection with video camera
I don't trust the heat sensor on the right side of the engine bay to activate soon
enough to land safely, especially for fires caused by the bearings of the lower
propeller belt drive. It'd be easy to install a small video camera at the front of
the engine bay, and run the wires to a small display in the cockpit where it's
easily seen. This could be used on gas power and FES (for the battery compartment)
gliders. Has anyone tried this?
Old October 10th 20, 09:09 PM posted to rec.aviation.soaring
Kenn Sebesta
That's an intriguing idea. How would you monitor the video feed? Would it be part of your active scan during takeoff?
You might do better with a FIR camera than an EO one. I'm just guessing here, but it's probably easier to do background subtraction to highlight heat changes than to see smoke in a very well-ventilated compartment.
Old October 10th 20, 10:21 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Kenn Sebesta wrote on 10/10/2020 12:09 PM:
I think glancing at it just before you start the takeoff roll, then again after
you reach a safe height (300 feet, say) and every 20-30 seconds after that would
be adequate. But - I think you are right that detecting the smoke or flame might
be very difficult in the engine bay, which is my problem (The FES pilots might
have success in the battery compartment, though). Probably need to do some smoke
tests on the ground and inflight with the engine running.
I have a FLIR ONE for my iPhone, but mounting it in the engine bay with a
Lightning cable to the front isn't practical, since it can't be turned on remotely.
I couldn't find a cheap camera ($200) online that could be used the way I'd like
to, either.
Old October 10th 20, 11:46 PM posted to rec.aviation.soaring
George Haeh
How about a battery powered home smoke detector?
Old October 11th 20, 12:38 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
George Haeh wrote on 10/10/2020 2:46 PM:
I don't know how it would respond to the high temperatures in the engine bay during normal
operation (ambient temperature in summer + engine heat), or the effect of air turbulence on the
detector, so I suspect it'd take a lot more testing than I'm interested in doing.
Old October 11th 20, 01:18 AM posted to rec.aviation.soaring
to, either.
Possibly a camera and display like used for rear view in RV's might be adaptable.
FWIW
UH
Old October 11th 20, 01:26 AM posted to rec.aviation.soaring
jfitch
Eric, the search terms "ir flame sensor" typed into Amazon or Google yields hundreds of results, starting at less than $5. They seem to have a broad angle of detection, a typical claim is sensing the flame from a cigarette lighter at 80 or 100 cm. Seems like it might be worth a try. I think a detector with an alarm is going to be more useful than having to scan a video during an already busy time.
Here for example, are 10 of them for $12 - a lifetime supply!
https://www.amazon.com/LGDehome-Infr...tronics&sr=1-1
Old October 11th 20, 02:47 AM posted to rec.aviation.soaring
Dave Nadler
I don't trust the heat sensor on the right side of the engine bay...
Nor should you, it didn't go off in at least one fire I discussed in Feb.
It'd be easy to install a small video camera at the front of the engine bay...
More likely to let you know somethings wrong.
Paul Mander had this setup in his ASH-25J, but obviously it wasn't enough.
An inerting system is a great idea, except the airflow through the engine bay...
I don't know if there's a really good solution.
Fires are bad.
Old October 11th 20, 04:32 AM posted to rec.aviation.soaring
kinsell
I believe those things are intended for indoor operation, where the
ambient light isn't strong. Outside, with the engine bay doors open,
you're likely to be getting lots of false alarms.
Old October 11th 20, 01:03 PM posted to rec.aviation.soaring
Ian Molesworth
You can buy a car reversing camera that will run off a USB-to-go connector on just about any modern phone.
Install the cable ( usual 4mm USB size ) into the engine box to the cockpit. Perhaps low down and angled up. Plug in to your phone. If it's right you could even see the engine erect so leave it out if there's something wrong.
Some even have an LED light to illuminate a dark engine compartment.
Best HD Video Camera for Flight Videos KiloKilo[_2_] Soaring 66 February 15th 14 08:20 PM
Video camera mount(s)? Terry Pitts Soaring 9 October 26th 13 08:41 AM
Another video using the cheap '808 Keychain camera' Grider Pirate Soaring 12 November 19th 10 03:37 AM
Very Nice Camera for Glider...Stills or HD Video [email protected] Soaring 17 June 16th 09 11:28 PM
Apache gun camera video Andrew Military Aviation 34 January 17th 04 03:48 PM
