#71
At 03:00 10 October 2020, 2G wrote:
On Friday, October 9, 2020 at 10:40:20 AM UTC-7, B BRIONES wrote: On Friday, October 9, 2020 at 7:55:04 AM UTC-7, kinsell wrote: Why are so many topics getting threaded under "Another E glider concept"? Happens both on my newsreader, as well as when just viewing R.A.S. on Google. On 10/9/20 8:44 AM, Adrian Morgan wrote: I have an LX 5000, which I want to interface with a Red Box Flarm. The LX has four ports (five including the vario display connection) labelled: 1. Power (wired to battery main switch) 2. Hold (wired to flip switch. No idea what it does!) 3. DataComm (a previous owner had "hot wired" two of its leads into a Garmin LX12 cable. No Garmin now fitted) 4. Meter ( RJ 12 6 pin phone type port. Not connected.) The LX presumably has a built in GPS, but needs an aerial. The LX is not finding a GPS fix, as there is no aerial. I assume the Garmin had been used to give the LX data via the DataComm hot wires. Now, with no Garmin, I assume the Flarm GPS aerial could do the job. Question, how to wire it all up. Must be simple for anyone other than an electronic imbecile like myself. here's another ![]() engine, glider looking but short winged-- https://www.desertaerospace.com/extreme-light-jet--xlj- That doesn't even rise to the level of a concept - more like wishful thinking. Tom Which does nothing to answer the original poster's question. Shame on you! Quite simply, LX5000 and Flarm cannot exchange Spatial Data. Both the LX5000 and Flarm are IGC Flight Recorders and as such can only receiver Spatial Data via the antenna. The dataports can transfer Task Declarations (prior to Take-Off). They may also output NMEA data, but not receive it. The LX5000 can control a suitable Radio via a Radio Bridge. Waypoint and similar files can be received via the dataport. IGC files can be downloaded. Dataports have their uses, but receiving Spatial Data is not one of them. What the poster wants to do is not possible. Tim. |
#72
Just bought an ASK 14 motorglider and reading the flight manual
etc. The fuel required is noted as octane 80 normal gasoline mixed with two stroke oil at a ratio of 20/1. The chap that owned it before me ran it on normal unleaded with shell vsx at a ration of 30/1. I’m sure this is ok but I wanted to see what anyone else currently uses? Thanks G |
#73
On Sunday, October 18, 2020 at 1:00:07 PM UTC-7, Graham Stanford wrote:
Just bought an ASK 14 motorglider and reading the flight manual etc. The fuel required is noted as octane 80 normal gasoline mixed with two stroke oil at a ratio of 20/1. The chap that owned it before me ran it on normal unleaded with shell vsx at a ration of 30/1. I’m sure this is ok but I wanted to see what anyone else currently uses? Thanks G The oil to gas ratio is function of oil type and not fundamental to a 2 stroke engine design. The 20:1 ratio sounds like conventional oil and not synthetic. Most pure synthetics are 50:1. A down side to conventional oil is they burn very dirty with lots carbon buildup in the cylinder, ports and are very prone to fouling the plug Synthetics burn much cleaner though not perfect. Buzz |
#74
At 17:01 19 October 2020, BG wrote:
On Sunday, October 18, 2020 at 1:00:07 PM UTC-7, Graham Stanford wrote: Just bought an ASK 14 motorglider and reading the flight manual=20 etc. The fuel required is noted as octane 80 normal gasoline mixed=20 with two stroke oil at a ratio of 20/1.=20 =20 The chap that owned it before me ran it on normal unleaded with=20 shell vsx at a ration of 30/1.=20 =20 I=E2=80=99m sure this is ok but I wanted to see what anyone else currentl= y=20 uses?=20 =20 Thanks=20 =20 G The oil to gas ratio is function of oil type and not fundamental to a 2 str= oke engine design. The 20:1 ratio sounds like conventional oil and not syn= thetic. Most pure synthetics are 50:1. A down side to conventional oil is= they burn very dirty with lots carbon buildup in the cylinder, ports and = are very prone to fouling the plug Synthetics burn much cleaner though no= t perfect. Buzz Thanks Buzz G |
#75
Just got an email about my W&W ad for a PowerFlarm Portable
from a "Frank Taylor" in the MN area (area code 507). The grammar is just a little off, he asks what my asking price is even though it is right in the ad, and he wants to pay with a Bank of America certified check. Has anyone else out there been contacted by this guy? I checked the SSA member directory, and there are no matches for a Frank Taylor. I smell a scam. RO |
#76
At 16:01 26 October 2020, Michael Opitz wrote:
Just got an email about my W&W ad for a PowerFlarm Portable from a "Frank Taylor" in the MN area (area code 507). The grammar is just a little off, he asks what my asking price is even though it is right in the ad, and he wants to pay with a Bank of America certified check. Has anyone else out there been contacted by this guy? I checked the SSA member directory, and there are no matches for a Frank Taylor. I smell a scam. RO W&W just answered. Scammer. P3 got the identical email in response to his ad as well. RO |
#77
On Monday, 26 October 2020 10:15:06 UTC-6, Michael Opitz wrote:
Just got an email about my W&W ad for a PowerFlarm Portable from a "Frank Taylor" in the MN area (area code 507). The grammar is just a little off, he asks what my asking price is even though it is right in the ad, and he wants to pay with a Bank of America certified check. Has anyone else out there been contacted by this guy? I checked the SSA member directory, and there are no matches for a Frank Taylor. I smell a scam. RO I got the same email, wording was obvious it was a scammer! |
#78
There is a new you tube video of a NZ glider entering cloud, you
should all watch it.Sorry posting the link defeated me but some one will.I suggest you pour a stiff drink before watching.It is only 3mins. |
#79
At 19:28 20 November 2020, Jonathon May wrote:
There is a new you tube video of a NZ glider entering cloud, you should all watch it.Sorry posting the link defeated me but some one will.I suggest you pour a stiff drink before watching.It is only 3mins youtube.comGlider IMC, Manawatu New Zealand.webloc |
#80
On Friday, November 20, 2020 at 11:45:08 AM UTC-8, Jonathon May wrote:
At 19:28 20 November 2020, Jonathon May wrote: There is a new you tube video of a NZ glider entering cloud, you should all watch it.Sorry posting the link defeated me but some one will.I suggest you pour a stiff drink before watching.It is only 3mins youtube.comGlider IMC, Manawatu New Zealand.webloc https://www.youtube.com/watch?v=8djWfNmJlKo |
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [4/5] - "Eclipse Concept Jet 4.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 04:02 PM |
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [3/5] - "Eclipse Concept Jet 3.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 04:02 PM |
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [2/5] - "Eclipse Concept Jet 2.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 04:02 PM |
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (0/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 04:02 PM |
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 04:02 PM |
