Attention Glasflugel Libelle Pilots
Old October 29th 20, 06:58 PM posted to rec.aviation.soaring
AS
Default Attention Glasflugel Libelle Pilots
Well, if you hook it up as labeled, it works just fine. The vario is not TE compensated, though. The airspeed should have been correct. Sometimes, you have to think back and forth between MPH on the SFG, and Knots on your ASI.
I have one sitting on my shelf, too, Frank. If you don't think yours doesn't work, you could always send it to Steve's Home for Wayward Glider Stuff. :-)
Steve Leonard
Steve - I have to correct myself he the TE was plumbed to Static and I think that will throw off the ASI.
Uli
'AS'
Old October 30th 20, 10:06 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
Steve Leonard
Uli
'AS'
Yes, that would through it off. Would read high by about 40%.
If you have a spot in the panel, give it a go! STF would not be correct for the Caproni, but a cool addition to the panel!
Steve Leonard
Old November 7th 20, 12:59 AM posted to rec.aviation.soaring
Tony[_7_]
Steve Leonard
Uli
'AS'
Steve Leonard
80mm?
Old November 11th 20, 03:45 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Steve Leonard
Uli
'AS'
Steve Leonard
80mm?
Yes, the instrument is 80 mm.
Steve Leonard
Old November 11th 20, 08:44 PM posted to rec.aviation.soaring
son_of_flubber
Literal Google translation
SOLLFAHRTGEBER -- SHOULD SPEED SENSOR
Glasflugel Libelle H-301/-301B POH thermalrider[_2_] Soaring 0 December 6th 12 12:23 AM
Attention US Standard Class Pilots [email protected] Soaring 51 February 13th 12 10:44 PM
Attention Region 12 Pilots! [email protected] Soaring 0 January 4th 12 06:19 AM
USA: Attention New York State Pilots Tim Hanke Soaring 0 June 28th 06 08:06 PM
Attention French Pilots! MK Soaring 1 November 8th 04 06:10 PM
