Thank you
Old November 14th 20, 05:16 PM posted to rec.aviation.soaring
jp
Default Thank you
Thank you to all who have offered me help with setting up Thunderbird as a reader for rec.aviation.soaring. In spite of the help I have not been able to figure out how to set it up. I don't mind really. Google Groups is good enough for me.
Old November 14th 20, 06:53 PM posted to rec.aviation.soaring
Dan Marotta
Default Thank you
I don't know what you've tried previously, but these instructions will
work for thunderbird:
https://support.mozilla.org/en-US/kb...sgroup-account
Sorry, I can't seem to make this work as a hyperlink but you can copy
and paste it into your browser.
I set the newsgroup to: news.eternal-september.org, port 119 which was
the default
If you use eternal-september.org as your newsreader, you need to go to
their website and set up an account. There's further information there
to make it all work.
Eventually, you'll have to subscribe to the newsgroup during the setup.
Look out! When first set up, you'll be presented with close to 100,000
threads. You'll have to mark as read most of them to clean up. It
doesn't take too long...
Good luck!
Dan
5J
Old November 14th 20, 09:05 PM posted to rec.aviation.soaring
jp
Default Thank you
the default
Good luck!
Dan
5J
Thank you Dan. I gave it another try, using your suggestions. It seemed to set up ok but when I clicked on "Get Messages" nothing seemed to happen. Maybe I didn't wait long enough. I'll try again.
Old November 14th 20, 10:18 PM posted to rec.aviation.soaring
Dan Marotta
Default Thank you
the default
Good luck!
Dan
5J
As I recall there was some detail that I found on eternal-september.org
that made the difference. It was one setting. I'll take another look
and see if I can find it.
Dan
5J
Old November 14th 20, 10:27 PM posted to rec.aviation.soaring
Dan Marotta
Default Thank you
the default
Good luck!
Dan
5J
Thank you Dan.Â* I gave it another try, using your suggestions.Â* It
seemed to happen.Â* Maybe I didn't wait long enough.Â* I'll try again.
that made the difference.Â* It was one setting.Â* I'll take another look
First off, I right clicked on the newly created Soaring Newsgroup that
I'd created and selected "Subscribe", then entered rec.aviation.soaring.
Question: Did you register on eternal-september.org?
And this is the last thing I picked up from eternal-september.org:
Client Settings
Server name: news.eternal-september.org
Port : 119 (NNTP)
Port : 563 (encrypted connection NNTPS)
Hope all of that helps!
Dan
5J
Old November 14th 20, 10:51 PM posted to rec.aviation.soaring
jp
Default Thank you
the default
Good luck!
Dan
5J
Client Settings
Port : 119 (NNTP)
Dan
5J
Thank you again Dan. I'm working on it.
Old November 15th 20, 01:49 AM posted to rec.aviation.soaring
kinsell
Default Thank you
the default
Good luck!
Dan
5J
Client Settings
Port : 119 (NNTP)
Dan
5J
You're trying to use Thunderbird on a Mac. Last I heard, it had been
supported on only 10.6, 10.7, and 10.8, but now even that support has
ended. That was only for Thunderbird 45.
Maybe there's something better suited for Macs these days.
-Dave
Old November 15th 20, 05:57 AM posted to rec.aviation.soaring
David Walsh[_3_]
Default Thank you
jp,
I've been using Google Groups for years now, but have been wanting to
switch to an email client interface.
Eric Greenwell suggested nntp.aioe.org. I Googled " how to set up
nntp.aioe.org in Thunderbird ", , the second link found was "
https://support.mozilla.org/en-US/kb...sgroup-account "
The process took all of 3 minutes, and worked first time. You can open
both your browser and Thunderbird, side by side, to make configuration
easy. You can put " nntp.aioe.org " in your mouse buffer for your
cutting and pasting pleasure, and finally you will have to sift through
all the Usenet accounts to find " alt.recreation.soaring " and check
that Check Box.
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Old November 15th 20, 04:05 PM posted to rec.aviation.soaring
Dan Marotta
Default Thank you
On 11/14/20 6:49 PM, kinsell wrote:
You're trying to use Thunderbird on a Mac.Â* Last I heard, it had been
ended.Â* That was only for Thunderbird 45.
-Dave
I've been told that Ubuntu will work on a newer Mac that has Intel or
AMD processors but, not being a Mac guy, can't say for sure. A friend
is going to give me an older Mac to try it out on. If it works, I'll
report back.
Dan
5J
