https://en.wikipedia.org/wiki/Cessna_404_Titan
The Cessna Model 404 Titan is an American twin-engined, propeller-driven light aircraft built by Cessna Aircraft. It was that company's largest twin piston-engined aircraft at the time of its development in the 1970s. Its US military designation is C-28, and Swedish Air Force designation Tp 87. History The Cessna 404 was a development of the Cessna 402 with an enlarged vertical tail and other changes. The prototype first flew on 26 February 1975. It is powered by two 375 hp/280 kW turbocharged Continental Motors GTSIO-520 piston engines. Two versions were offered originally; the Titan Ambassador passenger aircraft for ten passengers, and the Titan Courier utility aircraft for passengers or cargo. By early 1982 seven different variants were available, including a pure cargo version, the Titan Freighter. The Freighter was fitted with a strengthened floor, cargo doors, and its interior walls and ceiling were made from impact-resistant polycarbonate materials to minimize damage in the event of cargo breaking free in-flight. Role Light passenger/cargo aircraft Manufacturer Cessna First flight 26 February 1975 Introduction 1976 Status in use Produced 1976–1982 Number built 396 Developed from Cessna 402 Variants Cessna 441 Variants Titan Ambassador – Basic 10-seat passenger aircraft. Titan Ambassador II – Ambassador with factory fitted avionics. Titan Ambassador III – Ambassador with factory fitted avionics. Titan Courier – Convertible passenger/cargo version. Titan Courier II – Courier with factory fitted avionics. Titan Freighter – Cargo version. Titan Freighter II – Freighter with factory fitted avionics. C-28A Titan – Designation given to two aircraft purchased by the United States Navy Specifications (Ambassador I) General characteristics Crew: 2 Capacity: 6–8 passengers Length: 39 ft 6 1/4 in (12.046 m) Wingspan: 46 ft 8 1/4 in (14.230 m) Height: 13 ft 3 in (4.04 m) Wing area: 242.0 sq ft (22.48 m2) Aspect ratio: 9.0:1 Empty weight: 4,816 lb (2,185 kg) Max takeoff weight: 8,400 lb (3,810 kg) Fuel capacity: 340 US gal (280 imp gal; 1,300 L) Performance Maximum speed: 267 mph (430 km/h, 232 kn) at 16,000 ft (4,900 m) Cruise speed: 188 mph (302 km/h, 163 kn) (econ cruise) at 20,000 ft (6,100 m) Stall speed: 81 mph (130 km/h, 70 kn) flaps down, power off Never exceed speed: 274 mph (441 km/h, 238 kn) (Calibrated airspeed) Range: 2,120 mi (3,410 km, 1,840 nmi) Service ceiling: 26,000 ft (7,900 m) Rate of climb: 1,575 ft/min (8.00 m/s) Take-off run to 50 ft (15 m): 2,367 ft (721 m) Landing run from 50 ft (15 m): 2,130 ft (650 m) * |
Cessna 152 pics 2 [2/6] - Cessna150BC-for comparison Cessna 150s produced before 1964, such as this 1962 Cessna 150B, had a straight tail and no rear window.jpg (1/1) | Miloch | Aviation Photos | 0 | February 8th 20 03:03 PM |
Titan T-51 Low pass | Glen in Orlando[_4_] | Aviation Photos | 6 | January 27th 09 01:32 PM |
Titan Tornado | OtisWinslow | Home Built | 0 | May 26th 05 08:26 PM |
Soaring on Titan! | C.Fleming | Soaring | 13 | February 6th 04 08:41 PM |
Titan T-51... | wildcat | Home Built | 1 | July 16th 03 10:36 PM |
