Recommendation for Becker radio shop
Old December 4th 20, 01:32 PM posted to rec.aviation.soaring
wpbarnar@bellsouth.net
Default Recommendation for Becker radio shop
Been around aviation a long time but a newbie to the soaring community Helping a friend sort out some issues in a motor glider
The Becker 3200 com radio suddenly failed. Was working fine and on the next flight nothing after starting up the engine. Will not power up. I verified that it is getting power to the radio.
The tach also mysteriously died and the fuse on the vario blew. I suspect an over voltage problem but have not finished diagnostics.
Any recommendations on a shop to send the Becker radio to?
Bill
Old December 4th 20, 03:50 PM posted to rec.aviation.soaring
Dennis Cavagnaro
https://www.becker-avionics.com/
They were great when I had trouble with mine.
DC
Bill
Old December 4th 20, 11:25 PM posted to rec.aviation.soaring
Dave Springford
Becker USA - but I am not certain they can still repair the old 32 series radios!
+1 (954) 450-3137 10376 USA Today Way Miramar, Fl 33025, USA
Old December 5th 20, 01:25 AM posted to rec.aviation.soaring
Jim Lee
The Becker radios have an internal fuse which can easily blow from the surge if you start or stop the engine with the radio turned on. Make sure the radio is off before doing so. When the internal fuse blows, the only option is to send it to Becker at the above listed address. They will replace the fuse and send it back to you pretty fast.
Old December 5th 20, 11:44 AM posted to rec.aviation.soaring
youngbl...@gmail.com
Bill
You have a couple of options, buy a used one, or send it back to Becker down in Ft. Lauderdale. I have been in their shop for service on my Becker transponder, call and speak with Alex. They handled my repair promptly and I walked out the door with a repaired transponder. These people are great and have a history of good service. Bob
Old December 5th 20, 02:19 PM posted to rec.aviation.soaring
Moshe Braner
I am puzzled by that. Why would an overvoltage surge, even if it is up
to, say, 20 volts, blow a fuse? Especially if the radio is not
transmitting at the time. Voltage only causes current if something
accepts it. (Unless that radio has protection circuitry that does that
on purpose.)
The OP said "The tach also mysteriously died and the fuse on the vario
blew". That, together with the radio problem, suggests that something
much worse than an overvoltage surge happened. Or is one supposed to
disconnect the tach too before starting the engine?
"Was working fine and on the next flight nothing after starting up the
engine." - Was it working on the same flight before starting the
engine? If not, I wonder what happened between flights. Battery
briefly connected in reverse polarity?
Once that other issue is (or has been) cleared, then indeed the radio
may need service.
Old December 5th 20, 03:15 PM posted to rec.aviation.soaring
Tim Newport-Peace[_7_]
surge if you start or stop the engine with the radio turned on.Â* Make
sure the radio is off before doing so.Â* When the internal fuse blows,
I am puzzled by that.Â* Why would an overvoltage surge, even if it is up
to, say, 20 volts, blow a fuse?Â* Especially if the radio is not
transmitting at the time.Â* Voltage only causes current if something
accepts it.Â* (Unless that radio has protection circuitry that does that
on purpose.)
blew".Â* That, together with the radio problem, suggests that something
much worse than an overvoltage surge happened.Â* Or is one supposed to
engine."Â* - Was it working on the same flight before starting the
engine?Â* If not, I wonder what happened between flights.Â* Battery
may need service.
There may be over-voltage protection in the form of a Crowbar circuit
which shorts out the input if a set voltage is exceeded.
Old December 6th 20, 11:18 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
I list all the US repair shops that I know of for transceiver/transponder manufacturers in my troubleshooting presentation found at http://aviation.derosaweb.net/presen...s/#transceiver. If you know of any others, please let me know. Thanks.
The Becker repair shops in the US are;
Gulf Coast Avionics Corp.
• http://www.GulfCoastAvionics.com
• 3650 Drane Field Road, Lakeland, FL 33811
• Phone: 863-709-9714
• Email:
Mid Continent Instruments and Avionics
http://www.mcico.com
• 9400 East 34th Street North, Wichita KS 67226
• Phone: 800-821-1212, 316-630-0101
• Email:
Enjoy, John OHM
Old December 6th 20, 11:39 PM posted to rec.aviation.soaring
On Sunday, December 6, 2020 at 6:18:30 PM UTC-5, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
• Email:
• http://www.mcico.com
• Email:
Enjoy, John OHM
Contact Becker in ft. Lauderdale, speak with Alex, these guys are the factor repair station.
Old December 7th 20, 01:36 AM posted to rec.aviation.soaring
Becker USA doesn't seem to do a very good job advertising their repair services for the US. Googling "Becker USA Ft Lauderdale" I get a hit on http://www.beckerusa.com (located in Miramar FL?). Clicking on that I get redirected to https://www.becker-avionics.com/ in Germany. From there clicking on the "International Dealer-Service" link I see only European locations on the map (zooming to the US shows diddly-squat). Digging down further through "Dealer Portal US only" I see a "support" link to http://www.beckerusa.com/support which ... wait for it ... gives me a 404 error. OOPS. Blame it on Covid?
FS: 4 Becker 4201 Radio Ross[_3_] Soaring 3 May 24th 17 09:19 PM
Shop/ Installer recommendation please? andy Piloting 4 April 28th 06 11:23 PM
Becker 3201 Radio rondesilets@earthlink.net Soaring 8 December 8th 05 03:08 PM
Becker radio AD Tom Serkowski Soaring 3 November 2nd 04 01:43 AM
Recommendation for Radio, transponder and Altimeter Ron Natalie Home Built 0 July 8th 03 03:40 PM
