Arduino Based Soaring Related Devices
Old December 19th 20, 02:42 PM posted to rec.aviation.soaring
Default Arduino Based Soaring Related Devices
Hi Lauren,
To keep the traffic down on this thread lets start an off line conversation to get you all the info and file and answer questions. Unfortunately I'm not able to reply directly to you. Do you have the same limitation? If so then please include your email on your next post.
Bill
On Saturday, December 19, 2020 at 8:06:21 AM UTC-5, Lauren Rezac wrote:
On Friday, December 18, 2020 at 10:16:46 AM UTC-6, wrote:
Over the last two years I've designed and built three Arduino based soaring related devices.. They a 1) Tow Altitude Recorder with tow plane and ground units, 2) Cockpit Dual Battery Voltage & Temp Monitor, and 3)Trailer Lights Monitor.
Yes I am interested in the battery temp/voltage unit. (info on the other two might also be helpful
Thanks,
Lauren
Old December 19th 20, 03:55 PM posted to rec.aviation.soaring
Dan Marotta
On 12/19/20 6:49 AM, Martin Gregorie wrote:
sin(glider weight)
How do you convert pounds, kilograms, stone, etc. to radians, degrees...?
Dan
5J
Old December 19th 20, 05:15 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dan Marotta wrote on 12/19/2020 7:55 AM:
sin(glider weight)
I think this is easier for the additional load: [(climb rate) x (glider weight)] / (tow speed)
No trigonometry required.
Old December 19th 20, 05:18 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
sin(glider weight)
degrees...?
OK... glider_flying_weight * sin(climb angle)
This factor is needed because the tow rope is supporting a part of the
glider's flying weight - somewhere between zero in level flight to all of
it when a (jet-powered) tug is climbing vertically. At typical climb rate
on tow this amounts to a non-negligible fraction of the tension in the
rope.
Martin | martin at
Gregorie | gregorie dot org
Old December 19th 20, 10:54 PM posted to rec.aviation.soaring
OK guys, let's get this sorted out - and Yes, I will have donned my flame-proof suit by the time you're reading this!
A workable figure for the 'underlying' tension, (D + U), can be arrived at as follows: work out ...
D = (total weight of glider + pilot, etc.) / best glide ratio of that glider, and
U = (total weight of glider + pilot, etc.) / 10
Then add D and U to get the total 'underlying' tension (the steady-state tension, if you prefer).
The theory:
Tension in the aerotow rope in flight comprises 3 components:
D: the drag of the towed glider, dependent on its weight and its glide angle at towing speed
U: the "pulling Uphill" force, which is the weight of the glider x the sine of the angle of climb through the air (normally written as sin(angle))
J: the highly unpredictable and dynamically variable Jerk or "impulse" forces, resulting from bumps in the air, wiggles by the tug pilot, and proper (or otherwise) following behaviour of the glider pilot. These will also be scaled by other factors, such as elasticity and mass per unit length of the tow rope and (to a small extent in practical cases) by the respective total masses of tug and glider.
Note for D: normal towing speed is rarely far from best glide speed
Note for U: typical figures, in UK units:
- for a single-seater: 7kts climb at 70kts airspeed, giving the sine as 7/70 = 1/10
- for a two-seater: 6kts climb at 60kts airspeed, giving the sine as 6/60 = 1/10
- for better two-seaters: surprisingly little difference in climb angle, but ...
Note for J: this is potentially so variable that imprecision in assessment of D and U is unlikely to be of any concern.
Of course, a really powerful tug towing a really light glider will climb more steeply, so 10 may not be appropriate as the divisor in U.
If determining the sine in your own case, you must use identical units for airspeed and rate of climb - any density correction you apply to airspeed must also be applied to rate of climb. Some varios may give you true rates of climb, but the ASI will not give you true airspeed!
Note that extra climb rate caused by flying through lift does not affect the geometry, so does not affect the 'underlying' tension. It may well have an effect on variability of J - particularly in gusty thermals.
Martin's explanation was about right, in principle, but wrong in that the 'Uphill' component is significantly larger that the 'Drag' component for any practical glider (as opposed to hang-glider).
Eric wrote "No trigonometry required." But that *is* trigonometry - just without the frightening name!
Some may think that I have been random in my use of "mass" and "weight" - but no, barring slip-ups, and bearing in mind that it's late here!
More detailed explanation could be given, but are you still awake? Do you still have the will to live?
Happy Christmas, J.
Old December 19th 20, 11:20 PM posted to rec.aviation.soaring
Mark Mocho
Several years ago, one of our more "scientifically" inclined tow pilots rigged up a strain gauge at the tow hook and a laptop in the Pawnee cockpit to try to record loads and forces on the rope. I don't recall the actual numbers for my Pegasus, but the "scatter" in the data rendered the information virtually unusable. The "J" factor referenced above as the glider and tow plane encountered turbulence, reactions to control movements and out-of-position and/or uncoordinated flight made the load on the rope go from zero (slack line) to the weight of the glider. And it did it in such random steps that you couldn't make any sense of it. Maybe a more sophisticated system with more controlled conditions (i.e., smooth air) might reveal relevant results, but based on that one test, (as well as the data from several other tows with other gliders), I doubt any really usable information can be gleaned. The tow plane, tow rope and glider are in a very dynamic situation that is tough to quantify accurately. Good luck, as it would be interesting to see tests with better results.
Old December 20th 20, 12:24 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Mark Mocho wrote on 12/19/2020 3:20 PM:
As we all know, tow ropes do not break in steady flight! It's dynamic loads from turbulence and
piloting that put the peak loads on the rope; nonetheless, the average load (say, over 1
minute) will be close to the simple physics of lifting the weight of the glider at the rate of
climb. That number doesn't have much value in our operational choices, I think.
Old December 20th 20, 02:52 AM posted to rec.aviation.soaring
loads from turbulence and piloting that put the peak loads on the rope;
nonetheless, the average load (say, over 1 minute) will be close to the
simple physics of lifting the weight of the glider at the rate of climb.
Yep. I only made an attempt at calculating it a while back because I was
curious about the tension in the tow rope under during normal operating
conditions.
I think there are other towing factors that are probably more important
to understand. For instance, the aerodynamics of towing our gliders with
our typical tow planes are quite different from those of the majority of
military glider tows because almost for virtually all military towing the
tow plane has a bigger wingspan than the glider. This was the case for
all British and US operations in WW2 and for most German towing too.
In fact, the only cases I've found where the military glider was bigger
span than the tug was the ME 321 Gigant (the Gigant was bigger than its
He-111Z towplane) and the DFS 230 when it was being towed by a BF-109 or
Bf-110.
Conversely the only civilian gliders I'm aware of that are smaller than
their towplane are Perlan 2 when the Grob G520 Egrett is towing it
and an SGS 1-26 behind a Piper Cub.
This can matter, because if the glider is smaller than its tug, its
entire wing is operating in the downwash from the tug's wing, while if
the glider is bigger than its tug, then, while the inner part of its wing
is in the downwash behind the tug's wing, the outer parts of its wing
project through the tug's tip turbulence and into the upwash created by
the outer parts of the tug's tip vortex and may well give an tendency for
the glider to tip stall if the tow speed is too slow.
Martin | martin at
Old December 20th 20, 04:22 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Martin Gregorie wrote on 12/19/2020 6:52 PM:
conditions.
Bf-110.
Doesn't the majority of the wash or downflow from the wing pass under the glider if it tows at
the same altitude as the tug? For example, I used to demonstrate the ease of positioning behind
the towplane to students by banking to left until the glider was way off center line, and I
never noticed any significant difference in the airflow from center to far out to the left.
This was with a 200' long towrope; perhaps, with a much shorter rope, the experience would be a
lot different.
Old December 20th 20, 12:46 PM posted to rec.aviation.soaring
Lauren Rezac
On Saturday, December 19, 2020 at 8:42:08 AM UTC-6, wrote:
Hi Lauren,
Bill
Thanks,
Lauren
Bill,
It is
Thanks,
Lauren Rezac
Great New Product Not Related to Soaring Dan Marotta Soaring 5 April 7th 20 03:52 AM
ADS-B, Not Soaring Related, But... Dan Marotta Soaring 0 March 17th 18 04:11 PM
Not Soaring but still aviation related GM Soaring 1 December 20th 13 03:28 PM
50 years of space (Not related to soaring) Bill Daniels Soaring 3 August 10th 07 11:20 PM
Posting of Soaring-Related Ads Mike Soaring 1 November 27th 05 12:06 PM
