Solar panel controller
Old December 29th 20, 04:42 PM posted to rec.aviation.soaring
krasw
Default Solar panel controller
Any ideas for Strobl controller replacement? The voltage is not enough for LFP battery. Victron SmartSolar MPPT 75/10 looks good, but according to specs Strobl solar cell voltage is not enough to start the unit (!). Genasun has appalling efficiency.
Old December 29th 20, 05:03 PM posted to rec.aviation.soaring
Soartech
We need more info: how many Volts does your cell put out? What is the battery type and size in Watt-hours? What aircraft is this on?
Old December 29th 20, 05:52 PM posted to rec.aviation.soaring
jfitch
I'd be amazed if you had room for a Victron in your glider. Both Victron and Genasun make generally good stuff. From the data sheets, the Victron efficiency is "98% peak" and the Genasun is "94 - 99.85% typical". These are effectively the same. What do you find appalling?
Old December 29th 20, 07:36 PM posted to rec.aviation.soaring
krasw
Genasun consumes 150mA, six times more than Victron (25 mA). My solar panel produces 550mA (via Strobl controller). Genasun robs almost third of the panel produced power.
Old December 29th 20, 08:27 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
krasw wrote on 12/29/2020 10:36 AM:
The Genasum datasheet say 0.150 ma (150 ua), so much less power consumed than the Victron.
Old December 30th 20, 12:59 AM posted to rec.aviation.soaring
Moshe Braner
I've often thought of adding small solar panels in my glider to extend
the battery life, but when I do the math it makes no sense. Most
gliders have very limited room for solar panels (unless you glue the
flexible type outside the cockpit). I am surprised you got 550 mA,
that's about 7 watts. But that's probably peak, when the panel is
perfectly aligned towards the sun, and not under a cloud, and the
average would be much lower, probably 200 mA or less. Meanwhile people
have been loading their gliders with so much electronics that they say
they need TWO 12AH batteries to last a flight. Let's take the example
of a 1-amp average load, i.e., one 12AH LFP battery (or two SLAs) would
last 12 hours. Add a 200mA-average solar charging setup and that
reduces the load on the battery to 0.8 amps, extending the battery life
to 15 hours. Useful?
Old December 30th 20, 04:26 PM posted to rec.aviation.soaring
Brian[_1_]
Old December 30th 20, 04:42 PM posted to rec.aviation.soaring
Brian[_1_]
I put a 10 Watt a panel on my HP16. It averaged 200-250ma charging a 12AH Lead Acid batteries. The real advantage was when I was flying contests or safaris where I left the plane tied down. I could fly about 3 days in a row without needing to charge the battery. If we had a rest day it would pretty much top off the battery. I didn’t use a charge controller, I just used a volt meter. Since I only left it tied down when I was flying almost daily I didn’t figure 200-250 was enough to hurt the battery. But if I didn’t fly for more than a day I would disconnect it.
I loved having the solar panel, most of the time I didn’t need to charge the battery when flying daily. I wish I could come up with a reasonable panel to install on my LS6.
IMO Unless you are leaving the plane outside for extended periods without flying almost daily, my opinion is you don’t need a charge controller for a 20 watt or less solar panel. An appropriately sized and heat sinked Zenor diode would prevent it from overcharging if you did inadvertently leave it connected. If it is connected only when flying then no controller is required.
Old December 30th 20, 05:41 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Brian wrote on 12/30/2020 7:42 AM:
Brian's solution is a good one for gliders with a low enough current drain. Like Moshe, I
struggled to find a good place to put a useful amount of solar panel on my glider, given the
1.5 amp draw while flying. I eventually gave up trying, and installed a 20 AH Life battery,
which is enough capacity for two long flights. Normally, I recharge it after each flight from a
30 AH "donor" battery which is charged during the day by a 40W solar panel on the trailer,
using a DC-DC charger for electric model hobbyists. That's easy enough, and reliable.
Old December 30th 20, 08:39 PM posted to rec.aviation.soaring
2G
Just take out the controller altogether. The only LFP batteries I would consider have an internal BMS (battery management system) that protects against over-charging (which won't happen airborne, anyhow). I passed on solar panels altogether for my new ASH31Mi because their output was so paltry compared to the draw of my full glass panel (2A) that it was just not worth the cost ($2,500). I put in an LFP avionics battery instead (20AHr) and supplemented that with a 12AHr battery. That works fine if I remember to turn off my master.
Tom
Any interference from the Genasun LFP solar charger controller? jfitch Soaring 2 May 18th 18 04:41 AM
Strobl Solar Charge Controller Doug[_9_] Soaring 0 June 22nd 17 10:55 PM
Flexible solar panel deal Soartech Soaring 5 June 15th 16 09:26 PM
Connecting my 2 Batteries to 1 Solar Panel Dan G[_2_] Soaring 14 January 6th 13 12:12 AM
sizing solar panel Udo Rumpf Soaring 18 February 17th 06 02:36 AM
