Importing unregistered ASK-21
Old February 22nd 21, 05:10 PM posted to rec.aviation.soaring
ProfJ
Default Importing unregistered ASK-21
OK, idle fantasies on a winter day here - if I was to buy an ASK-21 in Australia that had never been registered there (see https://www.pickles.com.au/trucks/it...der/1020118632) how painful would it be to register it in the US?
Old February 22nd 21, 05:12 PM posted to rec.aviation.soaring
ProfJ
Oh yeah, can I point out it says "No CoA" in the listing?
Old February 22nd 21, 07:10 PM posted to rec.aviation.soaring
John Galloway[_2_]
OK, idle fantasies on a winter day here - if I was to buy an ASK-21 in Australia that had never been registered there (see https://www.pickles.com..au/trucks/i...der/1020118632) how painful would it be to register it in the US?
I can't comment on Oz to USA registration issues but my immediate thought is - "has the rotary engine been sitting unused and un-preserved for a long time?" I'd want an expert pre-purchase assessment of the glider by an inspector knowledgeable about the type.
Old February 22nd 21, 07:31 PM posted to rec.aviation.soaring
Tony[_7_]
The Mi is not certified in the US, so you're looking at importing it and registering as experimental - racing/exhibition. No instruction or rides for hire. An export CofA is of no value anyway.
Old February 22nd 21, 07:35 PM posted to rec.aviation.soaring
[email protected][_2_]
The process is spelled out on the FAA website he https://www.faa.gov/licenses_certifi...port_aircraft/ The process is pretty straightforward if you can obtain an Export CofA from Australia. I'd start by asking that question. If it can only be registered "Experimental" in the US, there are restrictions that go along with that (91.319, for example).
I would also worry about unapproved modifications if its been in the military, or any damage that has been repaired to military vs. civilian standards..
Old February 22nd 21, 07:38 PM posted to rec.aviation.soaring
Frank Whiteley
See my PM.
Frank Whiteley
Old February 22nd 21, 11:41 PM posted to rec.aviation.soaring
John Sinclair[_5_]
See my PM.
Frank Whiteley
I have imported a glider that didn’t have an Airworthiness For Export because it wasn’t airworthy (broken) and to further complicate things, it was de-registered (destroyed), in its old country! Took some letter writing and inspections, but after 6 months, I got it registered in the US with Experimental cert.
Note, I don’t believe an Experimental , 2 - seater can be used for instruction or giving rides and any non-factory modifications will further complicate the issue!
JJ
Importing glider from Canada [email protected] Soaring 2 January 24th 08 02:59 AM
Importing from Canada to US-revisited Frank Whiteley Soaring 1 November 30th 07 11:30 PM
Importing a gliger from Canada [email protected] Soaring 5 April 15th 07 05:35 PM
Importing Aircraft DaJhaDiKiDut Simulators 1 February 16th 07 03:18 AM
Importing a glider Gus Rasch Soaring 7 August 13th 03 10:34 PM
